@syedz
输出命令:
report_property -all [get_ips v_cresample *]警告:[Vivado 12-3670]只应在表示此IP的文件对象上查询generate_synth_checkpoint属性。
使用get_files命令访问文件对象。警告:[Vivado 12-3672]只应在表示此IP的文件对象上查询is_managed属性。
使用get_files命令访问文件对象。属性类型只读ValueALLOWED_SIM_TYPES string * true rtlBOARD string trueCLASS string true ipCONFIG.ACLK_INTF.FREQ_HZ string false 148500000CONFIG.Component_Name string false v_cresample_0CONFIG.S_AXI_ACLK_INTF.FREQ_HZ string false 100000000CONFIG.active_cols string false 1920CONFIG.active_rows
string false 1080CONFIG.chroma_parity string false oddCONFIG.convert_type string false 1CONFIG.field_parity string false oddCONFIG.has_axi4_lite string false falseCONFIG.has_debug string false falseCONFIG.has_intc_if string false falseCONFIG.interlaced string false falseCONFIG.m_axis_video_format string false 3CONFIG.max_cols string false 1920CONFIG.num_h_taps
string false 2CONFIG.num_v_taps string false 0CONFIG.s_axis_video_data_width string false 8CONFIG.s_axis_video_format string false 2CORE_REVISION int true 13DELIVERED_TARGETS string * true cmodel testbench changelog simulation synthesis instantiation_templateDESIGN_TOOL_CONTEXTS string
*真正的HDL IPI SysgenIPDEF串真xilinx.com:ip:v_cresample:4.0IP_CORE_CONTAINER串真正的C:/Projet_Vivado/project_Optsys_NB_50fps_multilayer/project_Optsys_NB_50fps_multilayer.srcs/sources_1/ip/v_cresample_0.xcixIP_DIR串真正的C:/Projet_Vivado/project_Optsys_NB_50fps_multilayer/project_Optsys_NB_50fps_multilayer.srcs/
sources_1 / IP / v_cresample_0IP_FILE串真正的C:/Projet_Vivado/project_Optsys_NB_50fps_multilayer/project_Optsys_NB_50fps_multilayer.srcs/sources_1/ip/v_cresample_0/v_cresample_0.xciIS_LOCKED布尔真0KNOWN_TARGETS串*真正cmodel测试平台的changelog模拟合成instantiation_templateNAME串真v_cresample_0PART串真xc7a50tfgg484-2REQUIRES_VIP布尔trueSCOPE串
trueSELECTED_SIM_MODEL string false rtlSTALE_TARGETS string * trueSUPPORTED_TARGETS string * true cmodel testbench changelog simulation synthesis instantiation_templateSUPPORTS_MODREF bool true 1SW_VERSION string true 2018.1UNSUPPORTED_SIMULATORS string * trueUPGRADE_RESULT
string trueUPGRADE_VERSIONS string * trueUSED_LICENSE_KEYS string * true {{cmodel {v_cresample@2013.03 hardware_evaluation}} {testbench {v_cresample@2013.03 hardware_evaluation}} {changelog {v_cresample@2013.03 hardware_evaluation}} {simulation {v_cresample@2013.03 hardware_evaluation}} {synthesis {v_cresample @
2013.03 hardware_evaluation}} {instantiation_template {v_cresample@2013.03 hardware_evaluation}}} USER_LOCKED bool false 0
许可证文件位于.zip中。
xinfo.txt 74 KB
Xilinx.zip 1 KB
以上来自于谷歌翻译
以下为原文
@syedz
Output of the command :
report_property -all [get_ips v_cresample*]
WARNING: [Vivado 12-3670] The generate_synth_checkpoint property should only be queried on the file object representing this IP. Use the get_files command to access file objects.
WARNING: [Vivado 12-3672] The is_managed property should only be queried on the file object representing this IP. Use the get_files command to access file objects.
Property Type Read-only Value
ALLOWED_SIM_TYPES string* true rtl
BOARD string true
CONFIG.active_rows string false 1080
CONFIG.num_h_taps string false 2
DELIVERED_TARGETS string* true cmodel testbench changelog simulation synthesis instantiation_template
DESIGN_TOOL_CONTEXTS string* true HDL IPI Sysgen
IPDEF string true xilinx.com:ip:v_cresample:4.0
IP_CORE_CONTAINER string true c:/Projet_Vivado/project_Optsys_NB_50fps_multilayer/project_Optsys_NB_50fps_multilayer.srcs/sources_1/ip/v_cresample_0.xcix
IP_DIR string true c:/Projet_Vivado/project_Optsys_NB_50fps_multilayer/project_Optsys_NB_50fps_multilayer.srcs/sources_1/ip/v_cresample_0
IP_FILE string true c:/Projet_Vivado/project_Optsys_NB_50fps_multilayer/project_Optsys_NB_50fps_multilayer.srcs/sources_1/ip/v_cresample_0/v_cresample_0.xci
IS_LOCKED bool true 0
KNOWN_TARGETS string* true cmodel testbench changelog simulation synthesis instantiation_template
NAME string true v_cresample_0
PART string true xc7a50tfgg484-2
REQUIRES_VIP bool true
SCOPE string true
STALE_TARGETS string* true
SUPPORTED_TARGETS string* true cmodel testbench changelog simulation synthesis instantiation_template
UNSUPPORTED_SIMULATORS string* true
UPGRADE_RESULT string true
UPGRADE_VERSIONS string* true
USED_LICENSE_KEYS string* true {{cmodel {v_cresample@2013.03 hardware_evaluation}} {testbench {v_cresample@2013.03 hardware_evaluation}} {changelog {v_cresample@2013.03 hardware_evaluation}} {simulation {v_cresample@2013.03 hardware_evaluation}} {synthesis {v_cresample@2013.03 hardware_evaluation}} {instantiation_template {v_cresample@2013.03 hardware_evaluation}}}
Licence file is in the .zip.
xinfo.txt 74 KB
Xilinx.zip 1 KB
@syedz
输出命令:
许可证文件位于.zip中。
xinfo.txt 74 KB
Xilinx.zip 1 KB
以上来自于谷歌翻译
以下为原文
@syedz
BOARD string true
SCOPE string true
xinfo.txt 74 KB
Xilinx.zip 1 KB
举报
