赛灵思
直播中
吴樵
7年用户 232经验值
私信 关注
[问答]
Pynq Z1是否适用于Vivado 2018.2 WebPACK?
嗨,我复制了电路板文件并插入了Pynq,但硬件管理器什么都没看到。
Pynq使用早期(2017.4?)许可的Vivado版本,能够使用它。
以上来自于谷歌翻译
以下为原文
Hi, I copied the board files and plugged in the Pynq, but the hardware manager sees nothing. The Pynq works with an earlier (2017.4 ?) licensed Vivado version, was able to use it.
回帖(1)
李建设
2019-1-8 10:10:24
Webpack安装支持它。
您是否可以确认Vivado安装在安装时是否启用了zynq?
Vivado>帮助>添加设计工具&
设备>
如果安装了zynq部件,也尝试重新安装驱动程序。
按照第30页上的步骤进行操作:http://www.xilinx.com/support/documentation/sw_manuals/xilinx2018_2/ug973-vivado-release-notes-install-license.pdf
谢谢
Harshit
-----------------------不要忘记回答,kudo,并接受为解决方案.-------------
以上来自于谷歌翻译
以下为原文
It is supported with webpack installation. Can you confirm if Vivado installation has zynq enabled when installed?
Vivado > Help> Add Design tools & devices >
Also try to reinstall the drivers if zynq parts are installed.
Follow the steps on page#30 https://www.xilinx.com/support/documentation/sw_manuals/xilinx2018_2/ug973-vivado-release-notes-install-license.pdf
Thanks
Harshit
Don’t forget to reply, kudo, and accept as solution.
举报
更多回帖
