对于混音器,所有功率设置均可在SOUR:POW树下使用。
RF和LO功率可以通过SENS:MIX树设置,但是对于更复杂的事情,你需要去SOUR:POW树。
所以,鉴于此,可以直接解耦功率:SOUR:POW:COUPle OFF并设置IF端口的电源,SOUR:POW2 -40可以让衰减器保持自动。
对于n5242a的-40dBm功率电平,自动衰减器将衰减器设置为30dB。
但是,如果要覆盖该设置,可以设置自己的衰减器值:SOUR:POW2:ATT 20设置衰减器后,自动衰减器设置将关闭。
这将确保PNA尊重您所做的设置。
以上来自于谷歌翻译
以下为原文
For mixers, all the power settings are available under the SOUR:POW tree. The RF and LO powers can be set through the SENS:MIX tree, but for anything more complicated, you need to go the SOUR:POW tree.
So, given that, it is straightforward to decouple the powers:
SOUR:POW:COUPle OFF
And to set the power on the IF port,
SOUR:POW2 -40
you can leave the attenuator at auto. For a power level of -40dBm on a n5242a, the auto attenuator will set the attenuator to 30dB.
But, if you want to override that setting, you can set your own attenuator value:
SOUR:POW2:ATT 20
Once you set the attenuator, then the auto attenuator setting is turned off. That will make sure that the PNA respects the setting that you made.
这将确保PNA尊重您所做的设置。
以上来自于谷歌翻译
以下为原文
SOUR:POW:COUPle OFF
SOUR:POW2 -40
SOUR:POW2:ATT 20
举报
