赛灵思
直播中
刘嘉佳
8年用户 138经验值
私信 关注
[问答]
无法生成比特流
我们拥有适用于HDMI 1.4 / 2.0发送器子系统的有效硬件仿真许可证。虽然生成IP,但我们收到了严重警告,下面给出了相同的警告。
[IP_Flow 19-651] IP许可证密钥'hdcp@2015.09'未经许可.IPCP功能在IP GUI上也不可用(灰显)。忽略此严重警告后,我们能够生成,合成,放置和路由
知识产权。
但无法生成比特流。
错误是:[Common 17-69]命令失败:此设计包含一个或多个不允许生成比特流的单元:hdmi_tx_inst / inst / v_hdmi_tx / inst(bd_8746_v_hdmi_tx_0_v_hdmi_tx_v1_1_0)我们尝试重新生成IP并尝试从头开始
但仍然面临着这个问题。部分:xc7v2000tflg1925-2Vivado 2016.4IP:HDMI 1.4 / 2.0发送器子系统(2.0)我们注意到IP的许可证状态显示为Design_Linking。
但许可证管理器显示'v_hdmi'的硬件评估。我们的目标是确定是否可以使用许可证生成比特流。非常感谢您对此的任何帮助。如果您需要我的更多信息,请告诉我。
谢谢。谢谢。
以上来自于谷歌翻译
以下为原文
We have a valid Hardware Emulation License for HDMI 1.4/2.0 Transmitter Subsystem.
While generating the IP, we are getting a critical warning and the same is given below.
    [IP_Flow 19-651] IP license key 'hdcp@2015.09' is unlicensed.
The HDCP features are not available (grayed-out) on IP GUI also.
After ignoring this critical warning, we were able to generate, synthesis, place and route the IP. But could not generate bitstream. The error is:
      [Common 17-69] Command failed: This design contains one or more cells for which bitstream generation is not permitted:
       hdmi_tx_inst/inst/v_hdmi_tx/inst (bd_8746_v_hdmi_tx_0_v_hdmi_tx_v1_1_0)
We have tried regenerating the IP and tried starting from the scratch, but still facing the issue.
Part: xc7v2000tflg1925-2
Vivado 2016.4
IP: HDMI 1.4/2.0 Transmitter Subsystem (2.0)
We noticed one more thing that the License status of the IP is shown as Design_Linking. But the License Manger shows Hardware Evaluaion for 'v_hdmi'.
Our target is to make sure whether the bitstream can be generated using the license or not.
Any help on this is highly appreciated.
Please let me know if you need any more information from my side.
Thanks in advance.
回帖(5)
胡燕珍
2019-1-3 11:14:15
你好@ ssampath
请检查此AR:
https://www.xilinx.com/support/answers/58758.html
问候
罗希特
--------------------------------------------请注意 - 请注明
如果提供的信息有用,请回答“接受为解决方案”。
将Kudos发送给您认为有用且回复的帖子.------------------------------------
RegardsRohit -------------------------------------------------
---------------------------------------------请注意 - 请注明
答案为“接受为解决方案”,如果提供的信息是有帮助的。给予您认为有用并回复导向的帖子。感谢K--
以上来自于谷歌翻译
以下为原文
Hi @ssampath
Please check this AR:
Regards
Rohit
Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful.
Give Kudos to a post which you think is helpful and reply oriented.
Regards
Rohit
举报
周蕊
2019-1-3 11:27:34
你好@ thakurr
实际上也是这样,我在加载许可证后重置了IP并生成了输出产品。
我是这样的:
1)加载许可证并重新启动vivado
2)验证了许可证状态(没关系)
3)然后生成IP并重置IP
4)生成输出产品
5)合成然后实现
以上来自于谷歌翻译
以下为原文
Hi @thakurr
Actually  did the same way, i reset the IP and generated output products after loading licens.
i did like this :
1) loaded licens and restarted vivado
2) verified the license status (it is ok)
3) then generate IP and reset the IP
4) generated output products
5) synth and then implementation
举报
吕钢格
2019-1-3 11:46:24
嗨@ ssampath,
这是旧设计吗?
如果是这样,请尝试使用新设计,看看问题是否仍然存在。
谢谢,Arpan -----------------------------------------------
-  -  -  -  -  -  -  -  -  -  -  -  -  -  -  -  -  -  -  -  -  -  - -请注意-
如果提供的信息有用,请将答案标记为“接受为解决方案”。给予您认为有用且回复的帖子。感谢Kudos .--------------------
以上来自于谷歌翻译
以下为原文
Hi @ssampath,
Is it an old design? If so can you please try with a new design and see if the issue persists.
Thanks,
Arpan
举报
周蕊
2019-1-3 11:56:39
嗨@ arpansur,
这不是一个旧设计。
创建该设计是为了测试是否可以使用现有许可证生成比特流。
该设计包含HDMI Tx IP和相同的包装。
它不包含任何其他IP或逻辑。
我已经尝试重置IP。
尝试从头开始生成IP。
问候,
萨姆帕斯
以上来自于谷歌翻译
以下为原文
Hi @ arpansur,
It is not an old design. The design is created to test whether it is possible to generate the bitstream with the existing license or not. The design contains the HDMI Tx IP and a wrapper for the same. It does not contain any other IP or logic.
I have already tried resetting the IP. Tried generating the IP from scratch also.
Regards,
Sampath
举报
更多回帖
