赛灵思
直播中
王娟
7年用户 462经验值
私信 关注
[问答]
无法为Ultrascale设计生成位文件使用TEMAC核心
我们在尝试在Ultrascale设计中使用TEMAC核心时遇到了问题。
我们购买并安装了核心的PROJ许可证,该许可证显示在我们的许可证管理器证书许可证中(参见附件),但是当我们尝试构建一个位文件时,我们收到以下消息......
错误:[通用17-69]命令失败:此设计包含一个或多个不允许生成比特流的单元:ethernet_mac / trimac_fifo_block / trimac_sup_block / tri_mode_ethernet_mac_i / U0 / tri_mode_ethernet_mac_core(tri_mode_ethernet_mac_tri_mode_ethernet_mac_v9_0_4)
关于我们做错了什么的任何想法?
Doc1.docx 152 KB
以上来自于谷歌翻译
以下为原文
We are encountering a problem in trying to use the TEMAC core in an Ultrascale design.  We have purchased and installed a PROJ license for the core which shows up in our license manager certificate based licenses (see attachment), but when we attempt to build a bit file we get the following message...
ERROR: [Common 17-69] Command failed: This design contains one or more cells for which bitstream generation is not permitted: ethernet_mac/trimac_fifo_block/trimac_sup_block/tri_mode_ethernet_mac_i/U0/tri_mode_ethernet_mac_core (tri_mode_ethernet_mac_tri_mode_ethernet_mac_v9_0_4)
Any ideas on what we are doing wrong?
            Doc1.docx ‏152 KB
回帖(7)
林立
2018-12-19 11:22:06
如果您使用eval许可证启动项目,然后迁移到购买的许可证,您可能会看到这样的错误。
就是这种情况,然后尝试重新生成IP,然后尝试创建一个比特流。
以上来自于谷歌翻译
以下为原文
If you started the project with an eval license then migrated to a purchased license you may see an error like this.  It that was the case then try regenerating the IP and then try creating a bit stream.
举报
李名扬
2018-12-19 11:27:23
即使我支付了TEMAC的PROJ版本,核心的IP STATUS也将其显示为设计链接许可证,我理解它仅用于模拟。
如何让它能够生成位文件?
以上来自于谷歌翻译
以下为原文
Even though I paid for a PROJ version of the TEMAC, the IP STATUS for the core shows it as a Design Linking License, which I understand it to be for simulation only.
How do I get it to be able to generate a bit file?
举报
林立
2018-12-19 11:32:27
您是否在许可页面上生成了新的许可证文件?
http://www.xilinx.com/ipcenter/ip_license/xilinx_license_key_types.htm
我已经有一段时间了,但我相信这是你必须要做的过程。
以上来自于谷歌翻译
以下为原文
Did you generate a new license file on the licensing page?
It's been a while since I've done this, but I believe that's the process that you have to do.
举报
赵雪培
2018-12-19 11:52:01
@ david.mcdaniel
从共享的VLM快照中,我看到该工具正在启动设计链接许可证,这将只允许您进行实施前和模拟后的实施。
但是,您无法使用此许可证生成比特流。
您能否分享通过电子邮件发送给您的已购买的TEMAC Core许可证文件(.lic)?
还要共享xinfo报告。要生成此报告,请在Vivado TCL控制台中运行以下命令并共享生成的xinfo.txt文件。
report_environment -file /xinfo.txt
--Syed
-------------------------------------------请注意 - 请标记答案
如果提供的信息有用,请“接受为解决方案”。给予您认为有用并回复导向的帖子。感谢Kudos .------------------------
以上来自于谷歌翻译
以下为原文
@david.mcdaniel
From the shared VLM snapshot, I see that the tool is picking up the design linking License which will only allow you perform both pre- and post-implementation simulation. However, you cannot generate bitstreams with this License.
Can you please share the bought TEMAC Core license file (.lic) which was emailed to you?
Also share the xinfo report. To generate this report,  run the below command in Vivado TCL console and share the generated xinfo.txt file.
--Syed
Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful.
Give Kudos to a post which you think is helpful and reply oriented.
举报
更多回帖
