赛灵思
直播中
杜美娜
8年用户 179经验值
私信 关注
[问答]
Chipscope许可证收到错误
嗨,
我有spartan 3a评估套件,我试图将Chipscope ILA添加到我的设计中但是我在实现的设计部分中收到了错误。
错误:NgdBuild:1317  - 使用核心芯片eye_ila_v1需要ChipScopePro许可证。
以下块是核心芯片的实例.cope_ila_v1:错误:安全性:14  - 没有可用于'ChipScopePro'的功能.ERROR:NgdBuild:1316  - 试图获得ChipScopePro许可证时遇到问题。
以上来自于谷歌翻译
以下为原文
HI ,
I have spartan 3a eval kit and I tried to add Chipscope ILA to my design but I received error in implemented design part.
ERROR:NgdBuild:1317 - Using core chipscope_ila_v1 requires a ChipScopePro
license. The following blocks are instances of core chipscope_ila_v1:
ERROR:Security:14 - No feature was available for 'ChipScopePro'.
ERROR:NgdBuild:1316 - A problem was encountered attempting to get the
ChipScopePro license.
回帖(7)
张晶晶
2018-12-12 11:00:26
嗨,由于3个许可证中只有第1个许可证对ISE和webpack许可证有用。
ISE具有ILA / chipscope的功能,但您需要单独的许可才能使用此功能。您可以联系Xilinx销售/ Xilinx分销商进行销售相关查询。谢谢,Yash
在原帖中查看解决方案
以上来自于谷歌翻译
以下为原文
Hi,
As out of 3 license only 1st license is useful for ISE and i.e. webpack license. ISE has feature of ILA/chipscope but you need separate license to use this feature.
You can contact Xilinx sales/Xilinx distributor for sales related query.
Thanks,
YashView solution in original post
举报
陈衡毅
2018-12-12 11:10:19
嗨,请在此处附上您的许可文件。
谢谢,维杰-----------------------------------------------
---------------------------------------------请将帖子标记为
一个答案“接受为解决方案”,以防它有助于解决您的查询。如果一个帖子引导到解决方案,请给予赞誉。
以上来自于谷歌翻译
以下为原文
Hi,
Please attach your license file here.
Thanks,Vijay
Please mark the post as an answer "Accept as solution" in case it helped resolve your query.
Give kudos in case a post in case it guided to the solution.
举报
蒲泛粟
2018-12-12 11:21:49
我的电子邮件中有这三个文件。
Xilinx.lic 1 KB
Xilinx(1).lic 2 KB
Xilinx(2).lic 2 KB
以上来自于谷歌翻译
以下为原文
I have these three files in my email.
            Xilinx.lic ‏1 KB                Xilinx (1).lic ‏2 KB                Xilinx (2).lic ‏2 KB
举报
陈衡毅
2018-12-12 11:40:40
嗨,这些许可证文件都没有支持chipcope功能。
以上来自于谷歌翻译
以下为原文
Hi,
None of these license files has chipscope feature support.Thanks,Vijay
举报
更多回帖
