不幸的是,据我所知,Ubuntu没有得到Xilinx的支持。
我在vmware下使用了Centos 6。
它源自RHEL 6,而XELX支持RHEL 6。
可能支持也可能不支持Centos。
如果你知道Vivado的安装位置,你可以为Vivado创建一个启动器。
以下网页介绍了如何为gnome桌面创建启动器:
http://xmodulo.com/2013/11/create-desktop-shortcut-launcher-linux.html
在我的情况下,创建后,启动器图标显示在其中一个菜单的菜单栏中。
然后我右键单击图标并选择菜单项以将启动器放在我的桌面上。
在我的情况下,我有以下shell脚本,名为“startVivado.sh”这是它的内容:
#!/ bin / bashcd~ / vivadoFiles / opt / Xilinx / Vivado / 2014.1 / settings32.sh / opt / Xilinx / Vivado / 2014.1 / bin / vivado
我的主目录中有一个名为“vivadoFiles”的目录,因为Vivado在当前目录中创建了多个工作文件,所以我更喜欢它们,而不是在我的桌面上。
启动器运行应用程序,vivado似乎工作。
以上来自于谷歌翻译
以下为原文
unfortunately, as far as I know, Ubuntu is unsupported by Xilinx. I used Centos 6 under vmware. it is derived from RHEL 6, and RHEL 6 is supported by Xilinx. Centos may or may not be supported.
If you know where Vivado was installed, you can create a launcher for Vivado.
The following web page shows you how to create a launcher for the gnome desktop:
In my case, after creation, the launcher icon showed up in the menu bar in one of the menus. I then right clicked on the icon and selected the menu item to put the launcher on my desktop.
in my case, I have the following shell script, called "startVivado.sh"
Here is its contents:
#!/bin/bash
cd ~/vivadoFiles
/opt/Xilinx/Vivado/2014.1/settings32.sh
/opt/Xilinx/Vivado/2014.1/bin/vivado
I have a directory in my home directory called "vivadoFiles" This directory is needed because Vivado creates several work files in the current directory, and I prefer them there rather than on my desktop.
The launcher runs the app and vivado appears to work.
可能支持也可能不支持Centos。
以上来自于谷歌翻译
以下为原文
#!/bin/bash
cd ~/vivadoFiles
举报
