赛灵思
直播中
王东
8年用户 228经验值
私信 关注
[问答]
WebPACK到版本升级问题
我在Windows 7上安装了ISE WebPACK并且工作正常,但是我的目标设备不受此版本的支持,所以我决定升级到标准版。
为此,我重新生成一个新的许可证文件,并通过许可证管理器成功导入。
问题是我仍然只能定位WebPACK设备而不是整个系列。
知道如何在不重新安装ISE的情况下解决这个问题吗?
谢谢
以上来自于谷歌翻译
以下为原文
I have installed ISE WebPACK on Windows 7 and it worked fine, but a device I was targetting was not supported by this edition so I decided to upgrade to the standard Edition. For this I re-generate a new license file and import it through the license mananger successfully.
The problem is that I can only still target the WebPACK devices and not the entire family. Any idea how to solve this problem without having to re-install ISE?
Thx
回帖(9)
姚庭芳
2018-12-3 16:10:10
嗨,
在文本编辑器中打开许可证文件。
如果在组件列表中找到“WebPACK”功能。
您需要购买许可证。
谢谢。
------------------------------------------您是否尝试在Google中输入问题?
如果没有,你应该在发布之前。
此外,MARK这是一个答案,以防它有助于解决您的查询/问题。给予帮助您找到解决方案的帖子。
以上来自于谷歌翻译
以下为原文
Hi,
Open your license file in a text editor. If you find the feature "WebPACK" in the components list.
You need to purchase a license.
Thanks.
Have you tried typing your question in Google? If not you should before posting. Also, MARK this is as an answer in case it helped resolve your query/issue.Give kudos to the post that helped you to find the solution.
举报
陈芳
2018-12-3 16:22:05
许可证文件根本不引用WebPACK:
#这是在2月20日星期三09:57:20 GMT + 00:00生成的永久许可证2013INCREMENT System_Edition xilinxd 2014.01永久不计数 322D8D1B79D8  VENDOR_STRING = my_email @ .... com,System_Edition,软件,永久,_210690853_1777488263_210553860_048  HOSTID =
4437e6b3d6cd ISSUER =“Xilinx Inc”START = 2013年2月20日 TS_OK ### -------------------------------
---------------------------------------#以下PACKAGE定义是此要求的一部分
许可证:#PACKAGE System_Edition xilinxd 2014.01 9A3893740635  COMPONENTS =“合成ChipScopePro_SIOTK分析仪ISE 仿真HLS PlanAhead SysGen SDK ChipscopePro 实施ISIM XPS”OPTIONS = SUITE#
以上来自于谷歌翻译
以下为原文
The license file does not reference WebPACK at all:
# This is a permanent license generated on Wed Feb 20 09:57:20 GMT+00:00 2013
INCREMENT System_Edition xilinxd 2014.01 permanent uncounted
322D8D1B79D8
VENDOR_STRING=my_email@....com,System_Edition,software,permanent,_210690853_1777488263_210553860_048
HOSTID=4437e6b3d6cd ISSUER="Xilinx Inc" START=20-Feb-2013
TS_OK
#  The following PACKAGE definition is a REQUIRED part of this license:
COMPONENTS="Synthesis ChipScopePro_SIOTK Analyzer ISE
Simulation HLS PlanAhead SysGen SDK ChipscopePro
Implementation ISIM XPS" OPTIONS=SUITE
举报
石俊梅
2018-12-3 16:37:12
嗨,
请访问http://www.xilinx.com/support/answers/34746.htm
这解释了如何在webpack许可证之前强制该工具使用系统版许可证。
谢谢,
迪皮卡。
谢谢,迪皮卡.----------------------------------------------
---------------------------------------------- Google之前的问题
张贴。
如果某人的帖子回答了您的问题,请将帖子标记为“接受为解决方案”。
如果你看到一个特别好的和信息丰富的帖子,考虑给它Kudos(左边的明星)
以上来自于谷歌翻译
以下为原文
Hi,
Refer to http://www.xilinx.com/support/answers/34746.htm
This gives explanation on how to force the tool to use the sytem edition license before webpack license.
Thanks,
Deepika.
Thanks,
Deepika.
Google your question before posting. If someone's post answers your question, mark the post as answer with "Accept as solution". If you see a particularly good and informative post, consider giving it Kudos (the star on the left)
举报
陈芳
2018-12-3 16:52:46
我刚读过这篇文章,但我的系统没有webpack.lic。
当我下载ISE时,我通过在线许可证管理员创建了一个webPack许可证并选择了WebPack。
xilinx通过电子邮件向我发送了以下Xilinx.lic文件,该文件包含Web_PACKAGE信息。
当我重新生成一个新文件(以前的显示和导入一个使用它检测到的许可证,并说,ISE版本是系统版本的许可证mananger,但FPGA器件中的其余项目窗口不显示,
虽然我可以在D: Xilinx  14.2  ISE_DS  ISE中看到我想要定位的设备在那里
#-----在此处移除线路-------------------------- ##此许可证有效期自2007年2月7日星期四09:54:
30 GMT + 00:00 2013 ##这是许可节点锁定到HOSTID = ANY;#没有必要为这个许可证来运行lmgrd ###这是上周四年2月7 9时54分三十零秒GMT产生永久许可证。
+00:00 2013INCREMENT Web_Package xilinxd 2014.02永久无数 2FB7629CA0E8  VENDOR_STRING = my_emila @,Web_Package,软件,永久,_210690853_1777488263_0_519  HOSTID =任何发行商= “赛灵思公司” START = 07  -  2月 -  2013 TS_OK ### ----
----------------#下面PACKAGE定义是这样的许可证的一个必要组成部分:#PACKAGE Web_Package xilinxd 2014.02 228C24D696E0  COMPONENTS = “的PlanAhead xps_tdp V_WebPACK XC7Z030 XC7Z010  XC7Z020的WebPack” OPTIONS =
SUITE ## -----------------------------------------------
------------------------------- ## -----在这下面删除线路--------
以上来自于谷歌翻译
以下为原文
I have just read the article, but my system does not have a webpack.lic. when I downloaded ISE I created a webPack license through the online license mananger and choose WebPack. xilinx emailed me the following Xilinx.lic file which is the one that contains Web_PACKAGE information. When I re-generate a new file (the previous shown and import that one using the license mananger it detects the license and says that the ISE edition is the system edition, but the rest of the FPGA devices are not shown in the project window , although I can see in the D:Xilinx14.2ISE_DSISE that the device that I want to target is there
# ----- REMOVE LINES ABOVE HERE --------------------------
# This license is valid from Thu Feb 07 09:54:30 GMT+00:00 2013.
# This is license NODELOCKED to HOSTID=ANY;
# there is no need to run lmgrd for this license.
# This is a permanent license generated on Thu Feb 07 09:54:30 GMT+00:00 2013
INCREMENT Web_Package xilinxd 2014.02 permanent uncounted
2FB7629CA0E8
VENDOR_STRING=my_emila@,Web_Package,software,permanent,_210690853_1777488263_0_519
HOSTID=ANY ISSUER="Xilinx Inc" START=07-Feb-2013 TS_OK
COMPONENTS="PlanAhead xps_tdp V_WebPACK XC7Z030 XC7Z010
XC7Z020 WebPACK" OPTIONS=SUITE
# ----- REMOVE LINES BELOW HERE --------------------------
举报
更多回帖
