嗨,
你有哪个许可证?
Webpack或购买的许可证?
如果是webpack许可证,它只支持少数设备。
如果是购买许可证,请检查设备是否已锁定。
您可以打开许可证文件,并在文件中检查INCREMENT部分中的设备名称。
如果它是设备锁定许可证,则它只能用于该特定设备。
同时发布错误消息,以便更容易预测问题。
谢谢,
迪皮卡。
谢谢,迪皮卡.----------------------------------------------
---------------------------------------------- Google之前的问题
张贴。
如果某人的帖子回答了您的问题,请将帖子标记为“接受为解决方案”。
如果你看到一个特别好的和信息丰富的帖子,考虑给它Kudos(左边的明星)
以上来自于谷歌翻译
以下为原文
Hi,
Which license do you have? Webpack or purchased license?
If it is webpack license it has support for only few devices.
If it is purchased license, check if is device locked. You can open the license file and check for the device name in the INCREMENT part if the file. If it is device locked license then it can be used only with that particular device.
Also post the error message so that it can be easier to predict the issue.
Thanks,
Deepika.
Thanks,
Deepika.
Google your question before posting. If someone's post answers your question, mark the post as answer with "Accept as solution". If you see a particularly good and informative post, consider giving it Kudos (the star on the left)
嗨,
你有哪个许可证?
Webpack或购买的许可证?
同时发布错误消息,以便更容易预测问题。
谢谢,
迪皮卡。
张贴。
以上来自于谷歌翻译
以下为原文
Hi,
Thanks,
Deepika.
Thanks,
Deepika.
举报
