> {quote:title = jvall写道:} {quote}>我不确定更新的套件,但我的85053B在衰减器上有插槽连接器......它的日期代码为2815,所以它将它放在1988年左右......
。甚至包括一个磁带盒。
>>我会看看我是否可以在某处找到更新的套件谢谢。
我的85053A显然比较老,但至少你的衰减器是开槽的,这表明安捷伦会使用开槽连接器校准我的85053B。
由于85053B支持PNA,如果新型号的泡沫是USB棒或类似物的切口,我会感兴趣。
我很想从安捷伦那里购买泡沫,并且我也会用USB棒上的数据进行校准,以防我购买PNA。
它花了我569美元购买*两个*不完整的85053B 180美元和85053A缺少磁盘389美元。
这比eBay上的唯一85053B便宜了4222美元!
当然,在大量使用之前,我仍然需要向安捷伦支付校准费用。
DaveEdited:drkirkby于2013年11月27日下午6:41
以上来自于谷歌翻译
以下为原文
> {quote:title=jvall wrote:}{quote}
> I am not sure about newer kits, but my 85053B has slotted connectors on the attenuators...it has a date code of 2815 so that puts it around 1988....it even has a tape cartridge included.
> I will see if I can find a newer kit somewhere
Thank you. My 85053A is obviously older, but at least the fact your attenuators are slotted, it would indicate that Agilent would calibrate my 85053B with slotted connectors.
Since the 85053B supports the PNA, I'd be interested if the foam on a newer model a cutout for a USB stick or similar. I'd be tempted to buy the foam from Agilent and it calibrated with data on USB stick too, in case I buy a PNA.
It cost me $569 buying *both* the incomplete 85053B at $180 and the 85053A which is missing the disks at $389. That's quite a bit cheaper than the only 85053B on eBay now at $4222! Of course I still have to pay Agilent to calibrate it before it is much use.
Dave
Edited by: drkirkby on Nov 27, 2013 6:41 PM
。甚至包括一个磁带盒。
以上来自于谷歌翻译
以下为原文
Dave
举报
