赛灵思
直播中
王瑞
8年用户 229经验值
私信 关注
[问答]
Chipscope许可证错误
你好,
我使用ISE 13.2,编译代码时出现许可错误。
你可以帮我吗。
谢谢
Xilinx.lic 2 KB
以上来自于谷歌翻译
以下为原文
Hello,
I use ISE 13.2 and I get licence errors when I compile my code.
Could you please help me.
Thank
            Xilinx.lic ‏2 KB
回帖(4)
王刚
2018-11-23 11:58:44
您似乎将“WebPACK”和“System_Edition”许可证合并在一起。
您可以尝试删除或注释掉许可证文件中的以下行吗?
INCREMENT Web_Package xilinxd 2012.10永久不计数 5DFD433AFC3D  VENDOR_STRING = doctordesign @ free.fr,Web_Package,软件,永久,_207563486_0_0_277  HOSTID = ANY ISSUER =“Xilinx Inc”START = 09-Oct-2011 TS_OK
包装Web_Package xilinxd 2012.10 CEF8961E58D9  COMPONENTS =“PlanAhead WebPACK”OPTIONS = SUITE
-----------------------不要忘记回答,kudo,并接受为解决方案.-------------
以上来自于谷歌翻译
以下为原文
It seems you combined "WebPACK" and "System_Edition" licenses.
Can you please try removing or commenting out the following lines in the license file?
INCREMENT Web_Package xilinxd 2012.10 permanent uncounted
5DFD433AFC3D
VENDOR_STRING=doctordesign@free.fr,Web_Package,software,permanent,_207563486_0_0_277
HOSTID=ANY ISSUER="Xilinx Inc" START=09-Oct-2011 TS_OK
PACKAGE Web_Package xilinxd 2012.10 CEF8961E58D9
COMPONENTS="PlanAhead WebPACK" OPTIONS=SUITE
Don't forget to reply, kudo, and accept as solution.
举报
王璐
2018-11-23 12:17:42
我已经尝试在许可证文件中注释掉行,我得到了同样的错误。
让我解释一下我的意思:
一开始我尝试使用WebPack解决方案并重新创建Chipscope不在此包中(我得到错误NgdBuild 1317)。
我从我的电脑上删除了所有软件并安装了新版本的Logic Edition。
管理许可证,但它仍然是相同的。
今天,我试图获得一个新的lisence文件,从管理许可证中删除WebPack,但它仍然是相同的。
我总是得到同样的错误。
帮帮我
Xilinx.lic 1 KB
以上来自于谷歌翻译
以下为原文
I have try commenting out lines in the license file, and I get the same error.
Let me explain what append to me :
At the beginning I have try using the WebPack solution and remarque that Chipscope was not in this pack (I get error NgdBuild 1317).
I have removed all software from my PC and install a new version, Logic Edition. Manage license but, it's still the same.
Today, I have try to get a new lisence file, removing WebPack from Manage Licenses but it's still the same. I get always the same error.
Help
            Xilinx.lic ‏1 KB
举报
王璐
2018-11-23 12:35:17
不要忘记我。
以上来自于谷歌翻译
以下为原文
Don't forget me.
举报
王刚
2018-11-23 12:54:35
您是否可以通过MAP进行简单设计而无需芯片内核?
如果没有,可能是因为您之前为此计算机生成了30天的评估许可证并且它已过期。
以上来自于谷歌翻译
以下为原文
Can you run through MAP for a simple design without chipscope cores? If not, probably because you generated 30-day evaluation license for this machine before and it's expired.
举报
更多回帖
