地图经常崩溃:
#map -o p25_map.ncd -w -pr b -ol high -global_opt speed -logic_opt on -xe n -mt on -
timing -detail p25.ngd p25.pcf#------------
----------------------------------#Release 13.1 - Map O.40d(nt64)Copyright(c)1995
-2011 Xilinx,Inc。保留所有权利.PMSPEC - 使用本地文件覆盖Xilinx文件使用目标部件“6vlx130tff1156-3”.INFO:映射:284 - 正在运行多线程选项的映射。
Map目前支持使用最多2个处理器。
根据用户选项和机器负载,Map将在此运行期间使用2个处理器。运行全局优化... EXCEPTION:ConstraintSystem:Cs_ResSpec_TypeName.c:143:1.28 - ''不是'EXPANDED的有效设计对象类型
'view.FATAL_ERROR:Map:Portability / export / Port_Main.h:159:1.28 - 此应用程序发现了一个无法恢复的异常情况。
流程将终止。
有关此问题的技术支持,请打开一个WebCase,该项目附在
http://www.xilinx.com/support.ERROR:Xflow-程序映射返回错误代码2.中止流程执行... make:***
[__xps / p25_routed]错误1完成!
已安装2011年4月更新。
任何帮助赞赏。
谢谢,
斯泰西
以上来自于谷歌翻译
以下为原文
Map routinely crashes with:
# map -o p25_map.ncd -w -pr b -ol high -global_opt speed -logic_opt on -xe n -mt on -timing -detail p25.ngd p25.pcf
Release 13.1 - Map O.40d (nt64)
Copyright (c) 1995-2011 Xilinx, Inc. All rights reserved.
PMSPEC -- Overriding Xilinx file
with local file
Using target part "6vlx130tff1156-3".
INFO:Map:284 - Map is running with the multi-threading option on. Map currently
supports the use of up to 2 processors. Based on the the user options and
machine load, Map will use 2 processors during this run.
Running global optimization...
EXCEPTION:ConstraintSystem:Cs_ResSpec_TypeName.c:143:1.28 - '' is not a valid
design object type for the 'EXPANDED' view.
FATAL_ERROR:Map:Portability/export/Port_Main.h:159:1.28 - This application has
discovered an exceptional condition from which it cannot recover. Process
will terminate. For technical support on this issue, please open a WebCase
with this project attached at http://www.xilinx.com/support.
ERROR:Xflow - Program map returned error code 2. Aborting flow execution...
make: *** [__xps/p25_routed] Error 1
Done!
The April 2011 update is installed. Any help appreciated.
Thanks,
Stacey
