嗨,我最近在Digikey(768-1032-ND)和Connection Expert(安捷伦的IO Librairies 17.0)上买了一个USB转rs-232转换器,很容易测试与34970A的通信。
使用零调制解调器电缆将u***-rs232转换器连接到34970A,并使用“shift”“interface”键配置设置rs-232。
打开Connection Expert,使用手动配置并在asrl上添加“serial instrument?”。
选择正确的COM端口并使用与34970A相同的参数对其进行配置。
使用“仪器”选项卡,点击asrl?
您刚刚配置的连接,在右侧,单击“向此仪器发送命令”。
点击“发送和读取”按钮,通常,您将收到34970A连接的答案。
默认命令是“* IDN?”。编辑:Tardz于2015年1月24日下午4:42
以上来自于谷歌翻译
以下为原文
Hi
I bought recently an USB to rs-232 converter on Digikey (768-1032-ND) and with Connection Expert (IO librairies 17.0 from Agilent), it's easy to test communication with a 34970A.
Connect u***-rs232 converter to your 34970A with null modem cable, and configure setup rs-232 with keys "shift" "interface". Open Connection Expert, use manual configuration and add "serial instrument on asrl?". Choice the right com port and configure it with same parameters that your 34970A.
Use tab "Instruments", click on the asrl? connection that you just configure, on right, click on "Send commands to this instrument". Click on "Send and Read" button, normally, you will receive an answer of you 34970A connected. Default command is "*IDN?".
Edited by: Tardz on Jan 24, 2015 4:42 PM
使用“仪器”选项卡,点击asrl?
以上来自于谷歌翻译
以下为原文
Hi
举报
