您好Karthus-Tian,感谢您联系英特尔®技术支持。据我们了解,您需要有关英特尔®Optane™内存系列的帮助如果我们正确推断,开始诊断和随后的故障排除可能需要我们解决问题,我们
如果您能,请回复此帖,并提供以下重要的基本信息:
SSU登录.1-转到https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility?v=t下载软件.2-下载完成后,打开它.3-
标记“Everything”框,然后单击“Scan.4-完成扫描后,单击”下一步。“5-单击”保存“.6-将文件附加到您的回复。窗口”磁盘管理“的屏幕截图
显示所有硬盘和分区。我们期待您的回复。最好的问候,JoshB.Intel®客户支持技术人员与英特尔公司的合同
以上来自于谷歌翻译
以下为原文
Hello Karthus-Tian,
Thank you for contacting Intel® Technical Support.
As we understand, you need assistance with your Intel® Optane™ Memory Series If we infer correctly, to begin diagnosis and consequent troubleshooting that could take us to a resolution, and we would appreciate if you could, please, reply to this post with the following, important, basic information:
1- Go to
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility?v=t and download the software.
2- When finished downloading it, open it.
3- Mark the box "Everything" and then click "Scan.
4- When finish scanning, click "Next."
5- Click on "Save."
6- Attach the file to your reply.
- A screenshot of the “Disk Management” of windows showing all your HDDs and partitions.
We will be looking forward to your reply.
Best regards,
Josh B.
Intel® Customer Support Technician
Under Contract to Intel Corporation
以上来自于谷歌翻译
以下为原文
Hello Karthus-Tian,
1- Go to
5- Click on "Save."
Best regards,
Josh B.
举报
