> {quote:title = Dr.La'brat写道:} {quote}>我有一个SMT微带夹具,它使用来自洲际微波的TRL插件。
我有一个带有系数的3.5英寸磁盘,但无法弄清楚如何将校准常数上传到8753ES。尝试这个*打开电源,或者如果已经打开则按“预设”*插入软盘*按“保存/调用”键*按下软键
对于“选择磁盘”*按下软键“内置磁盘”此时,假设您的软盘驱动器仍然有效,您应该获得软盘上的文件列表。*按下软键“返回”*使用旋钮选择一个
文件*按下“Recall state”软键,然后将系数加载到USER套件中。>所以我参考TRL纠错手册,手动插入coeff。使用短反射,零距离和第1行,我输入了用户
定义参数。修改标准,分配标准类,标签类,标签套件,保存用户工具包.3x。我意识到我一定做错了。手动定义系数很容易出错。菜单结构很糟糕
我曾经看到过一条评论说这一点是由一个反叛者写的
ntled员工或实习生!
我的网站上有一些关于某些问题的说明。
就个人而言,如果我要修改一个TRL校准套件,那么我将从一个类似的开始。
我在8753ES固件(我的最新版本为7.74)中可以看到的最相似的套件是85052C 3.5 mm套件。
注意,作为3接收器VNA的8753不能做真正的TRL cal - 仅TRL *。
最好在每根电缆上贴上高质量的6-10 dB衰减器,这样就可以很好地匹配。
您应该能够在8753ES手册和/或某些安捷伦应用说明中找到有关该信息的信息。
>任何人都可以给我一些想法或告诉我如何从3.5#磁盘上传。
希望我有!
DaveEdited:drkirkby于2015年10月9日上午9:03
以上来自于谷歌翻译
以下为原文
> {quote:title=Dr.La'brat wrote:}{quote}
> I have an SMT microstrip fixture which uses TRL inserts from intercontinental microwave. I have a 3.5" disk with coefficients but cant figure out how to upload cal constants into 8753ES.
Try this
* Power on, or press "Preset" if already on
* Insert floppy
* Press the "Save/Recall" key
* Press the softkey for "Select disk"
* Press the softkey "Internal disk"
At this point, assuming your floppy drive still works, you should get a list of the files on the floppy.
* Press the softkey "Return"
* Use the knob to select a file
* Press the softkey "Recall state"
that will then load the coefficients into the USER kit.
> So I referred to manual on TRL error correction to manually insert coeff. Using short reflection, zero distance thru, and Line 1, I entered user defined parameters. Modify standards, assign standard class, label class, label kit, save user kit. 3x. I realize I must be doing something wrong.
It is very easy to go wrong with defining the coefficients manually. The menu structure is pretty poorly thought out. I once see a comment that bit was either written by a disgruntled employee or an intern! There are some
notes on my website about some of the issues.
Personally if I were going to modify a TRL cal kit, then I'd start with one that is similar. The most similar kit I can see in the 8753ES firmware (mine has the latest 7.74) is the 85052C 3.5 mm kit.
Note, that the 8753, being a 3-receiver VNA, can't do a true TRL cal - only TRL*. It is best to stick a high quality 6-10 dB attenuator at each cable, so there is a good match. You should be able to find information about that in the 8753ES manual and/or some Agilent application notes.
> Can anyone give me some ideas or tell me how to upload from 3.5# disk.
Hopefully I have!
Dave
Edited by: drkirkby on Oct 9, 2015 9:03 AM
ntled员工或实习生!
我的网站上有一些关于某些问题的说明。
希望我有!
以上来自于谷歌翻译
以下为原文
Try this
* Insert floppy
Hopefully I have!
Dave
举报
