你好,
我正在尝试在XC6VLX240T中将IOBUFBS与双向IODELAYE1和IDDR以及ODDR一起用于特殊的DDR3应用程序。
当我按照Virtex-6选择IO用户指南中所述连接四个基元时,我从map(ISE12.2)中收到错误:
错误:打包:2531 - 双数据速率寄存器“ddr3_controller_inst / G_lane [0] .ODDR_dqs_t”无法根据需要加入“OLOGICE1”组件。
寄存器符号ddr3_controller_inst / G_lane [0] .ODDR_dqs_t的输出信号需要一般路由到结构,但寄存器只能路由到ILOGIC,IODELAY和IOB。
如果我使用(单端)IOBUF而不是IOBUFDS一切正常。
我还尝试了生成相同连接的Select IO Generator,因此map生成了相同的错误。
这是我的代码:
ODDR_dqs_o:ODDR通用映射(DDR_CLK_EDGE =>“SAME_EDGE”,INIT =>'0',SRTYPE =>“SYNC”)端口映射(Q => dqs_o,C => clk_400,CE =>'1',D1 =>
dqs_o_a,D2 => dqs_o_b,R =>'0',S =>'0');
------------------------------- ODDR_dqs_t:ODDR通用地图(DDR_CLK_EDGE =>“SAME_EDGE”,INIT =>'0'
,SRTYPE =>“SYNC”)端口映射(Q => dqs_t,C => clk_400,CE =>'1',D1 => dqs_t_a,D2 => dqs_t_b,R =>'0',S =>'0
------------------------------- IODELAYE1_dqs:IODELAYE1通用地图(CINVCTRL_SEL => FALSE,DELAY_src =>“IO”,HIGH_PERFORMANCE_MODE
=> TRUE,IDELAY_TYPE =>“VAR_LOADABLE”,IDELAY_VALUE => 0,ODELAY_TYPE =>“VAR_LOADABLE”,ODELAY_VALUE => 0,REFCLK_FREQUENCY => 200.0,SIGNAL_PATTERN =>“DATA”)端口映射(CNTVALUEOUT =>打开,DATAOUT =
> dqs_i,C => clk_400,CE =>'0',CINVCTRL =>'0',CLKIN =>'Z',CNTVALUEIN => dqs_lane,DATAIN =>'Z',IDATAIN => dqs_x,INC =>'
0',ODATAIN => dqs_o,RST => dqs_lane_wr,T => dqs_t(l));
------------------------------- IOBUFDS_dqs:IOBUFDS端口映射(O => dqs_x,IO => ddr_dqsp,IOB =>
ddr_dqsn,I => dqs_i,T => dqs_t);
有谁知道如何让事情发挥作用?
问候,
迈克尔
以上来自于谷歌翻译
以下为原文
Hello,
I'm trying to use an IOBUFBS together with bidirec
tional IODELAYE1 and IDDR und ODDR in a XC6VLX240T for a special DDR3 application.
When I connected the four primitives as described in the Virtex-6 Select IO User Guide I get an error from map (ISE12.2):
ERROR:Pack:2531 - The dual data rate register
"ddr3_controller_inst/G_lane[0].ODDR_dqs_t" failed to join the "OLOGICE1"
component as required. The output signal for register symbol
ddr3_controller_inst/G_lane[0].ODDR_dqs_t requires general routing to fabric,
but the register can only be routed to ILOGIC, IODELAY, and IOB.
If I use a (single ended) IOBUF instead of the IOBUFDS everything works fine. I also tried the Select IO Generator which produced the same connections and thus the same error is produces by map. Here my code:
ODDR_dqs_o: ODDR
generic map(
DDR_CLK_EDGE => "SAME_EDGE",
INIT => '0',
SRTYPE => "SYNC"
port map (
Q => dqs_o,
C => clk_400,
CE => '1',
D1 => dqs_o_a,
D2 => dqs_o_b,
R => '0',
S => '0'
ODDR_dqs_t: ODDR
generic map(
INIT => '0',
SRTYPE => "SYNC"
port map (
Q => dqs_t,
C => clk_400,
CE => '1',
D1 => dqs_t_a,
D2 => dqs_t_b,
R => '0',
S => '0'
IODELAYE1_dqs: IODELAYE1
generic map (
DELAY_src=> "IO",
HIGH_PERFORMANCE_MODE => TRUE,
IDELAY_TYPE => "VAR_LOADABLE",
IDELAY_VALUE => 0,
ODELAY_TYPE => "VAR_LOADABLE",
ODELAY_VALUE => 0,
SIGNAL_PATTERN => "DATA"
port map (
CNTVALUEOUT => open,
DATAOUT => dqs_i,
C => clk_400,
CE => '0',
CINVCTRL => '0',
CLKIN => 'Z',
DATAIN => 'Z',
IDATAIN => dqs_x,
INC => '0',
ODATAIN => dqs_o,
RST => dqs_lane_wr,
T => dqs_t(l)
IOBUFDS_dqs: IOBUFDS
port map (
O => dqs_x,
IO => ddr_dqsp,
IOB => ddr_dqsn,
I => dqs_i,
T => dqs_t
Has anyone an idea how I get things to work?
Regards,
Michael
