你好
我们正在为使用Autocad 2015的客户运行一系列POC。
POC硬件是具有2 K2的超微服务器。
我们已经应用了Jason(thx btw)共享的策略,所有Nvidia演示都通过HDX 3D pro完美运行。
VDI计算机正在运行Windows 7 64位,最新的VDA修补程序。
我们的问题和showstopper是Autocad。
我们遇到的是鼠标滞后和游标问题。
有时Windows光标位于acad光标的顶部。
有时光标变为随机Windows光标,通过将指针移出绘图区域然后返回来解决问题。
Autocad在首次启动时会发出有关硬件加速的警告,但会看到grafx卡并显示使用DirectX 11。
我们知道GRID不在Acad 2015硬件兼容性列表中。
我们一直在尝试使用Acad 2016来查看问题是否已解决。
但它完全一样。
GRID也不在这里的hw兼容性列表中。
如果有人知道如何解决这个问题,或者知道有人这样做,请告诉我!
以上来自于谷歌翻译
以下为原文
Hi
We are running a series of POC's for customers who use Autocad 2015.
The POC hardware is a supermicro server with 2 K2's.
We have applied the policies shared by Jason (thx btw), and all Nvidia demos are working perfectly through HDX 3D pro.
The VDI machines are running Windows 7 64 Bit, latest VDA hotfixes.
Our issue, and showstopper, is with Autocad. What we experience is mouse lag and cursor problems. Some
times the Windows cursor sits ontop of the acad cursor. Sometimes the cursor changes to a random Windows cursor, the problem is "solved" by moving the pointer out of the drawing area and then back.
Autocad gives a warning at first startup regarding the hardware acceleration but sees the grafx Card and shows DirectX 11 is used.
We are aware that GRID is not on the Acad 2015 hardware compatibility list.
We have been experimenting with Acad 2016 to see if the problem is solved. But it is exactly the same. GRID not on the hw compatibility list here as well.
If anyone has an idea to how this problem can be fixed or know someone who does, tell me! :)
