LPS331AP和LPS25HB传感器具有类似的寄存器映射,但它们不相同。
我建议检查初始设置。您可以找到两个设备的数据表。
您是否在自定义电路板上焊接了设备?
如果设备报告的偏移值小于预期值,则可能需要单点校准以补偿焊后封装应力。
安东内拉
â€以下为原文
Hi,
the LPS331AP and LPS25HB sensors have a similar register map, but they are not same.
I suggest to check the initial setting. You can find attached the datasheet for both devices.
Do you have soldered the device on your customized board?
If the device is reporting a value with a small offset compared to the expected one, a single point calibration may be needed in order to compensate the post soldering package stress.Regards
Antonella
​Hi,
I working with Barometric Pressure sensor LPS331AP.Its working good. but as this chip absoluted,then we changed design to LPS25HB.But this chip is reading 6.4mBar error apart from the actual measured value .We are not added any offset value and not done any our factory calibration.Just I reading the 24-bit data and displaing converted pressure.I did 't change any code,just I replaced LPS331AP by LPS25HB chip.
Advice me is it nesassary to change any code ? or any calibration or offset vaules need to set?/
Please advice us...
李汉荣
2018-9-12 10:32:44
嗨〜
我遇到了完全相同的问题。我也看到6mbar偏移。
你找到了解决这个问题的方法吗?
提前致谢。
Yeonsik
以下为原文
Hi~
I am experiencing exactly same problem. I also see 6mbar offset.
Did you find any solution for this problem?
Thanks in advance.
Yeonsik
你找到了解决这个问题的方法吗?
提前致谢。
Yeonsik
以上来自于谷歌翻译
以下为原文
Hi~
Thanks in advance.
Yeonsik
举报
马祥
2018-9-12 10:40:13
请检查答案
https://community.st.com/0D50X00009XkYHDSA3
注意:原始帖子包含大量线程对话,只能迁移到第9级
以下为原文
Please check the answer on
Note: the original post contained a large number of threaded conversations and was only able to be migrated to the 9th level
以上来自于谷歌翻译
以下为原文
举报
