Cypress技术论坛
直播中
谷菁
8年用户 165经验值
私信 关注
[问答]
cy7c65642-28引脚12cSDA引脚
你好,
我用的是28引脚CY7C6562芯片。我使用PIN 26(PWR),使我的电荷泵的USB电源。但我的PIN 26没有激活,即使我所有的OVR管脚都是按要求的。
请让我知道PWR公司将在什么情况下运行。测试销(18针)的用途是什么?
当做,
南达
以上来自于百度翻译
     以下为原文
  Hi ,
   I am using 28 pin CY7C65642 chip. I am using pin 26 (PWR#) for enabling my charge pump for USB power supply. But my pin 26 is not getting activated even though all my OVR# pins are as required.
Kindly let me know under what conditions PWR# will be active.  What is the use of TEST pin(18 pin).
Regards,
Nanda
回帖(2)
王敏
2018-9-11 15:06:02
嗨,南达,
PWRα/i2CysDA可以用作PWRα或I2CsSDA,但不能用作28引脚QFN封装。如果EEPROM连接,那么PIN将充当I2CY-SDA,它将不会切换到PWRα模式(正如它在48引脚TQFP封装)。
如果EEPROM没有被使用,PWR是一个有源低引脚(低激活时),它需要一个外部上拉电阻。
测试引脚可用于测试模式,通过驱动高。对于正常运行,建议把这个引脚低。
问候,阿尼尔
以上来自于百度翻译
     以下为原文
  Hi Nanda,
PWR#/I2C_SDA can be used as either PWR# or I2C_SDA but not as both in 28-pin QFN Package. If EEPROM is connected then the pin will act as I2C_SDA, it will not switch to PWR# mode (as it does in 48-pin TQFP package).
If EEPROM is not being used, PWR# is an active LOW pin (LOW when activated), which needs an external pull-up resistor.
TEST pin can be used for Test Mode by driving it HIGH. For Normal operation it is recommended to drive this pin LOW.
Regards,
Anil
举报
刘辉
2018-9-11 15:17:24
另外,请确保PWR和VCCD/+5V与100KOHM电阻、OVRα连接到10kOHm的相同功率。由于PWR是开路漏输出,OVR是开放漏极输入。
有关测试引脚的更多细节,请参阅:
连接EZ-USB®HX2VL协议的测试/I2CYSCL引脚-KBA8488
以上来自于百度翻译
     以下为原文
  Also, make sure  to connect PWR# to VCCD/+5V with 100kohm resistors, OVR# to the same power with 10Kohm. Because PWR# is open drain output and OVR# is open drain input.
For more details on test pin, please refer:
Connecting the TEST/I2C_SCL Pin of EZ-USB® HX2VL™ - KBA85448
举报
更多回帖
