瑞秋,
感谢您在内部以及VMware进行检查。
不必重新启动听起来很棒,希望我能做到这一点。
我在更新时更新了支持GRID的服务器。
两者都是测试,所以我可以回过头来重做其中一个,但是在我有时间做之前还有一两天。
我当时的经验是,在升级振动之后我可以打开VM,直到我重新启动。
一旦我再次尝试此操作,我将收到确切的错误消息,以便在此处发布并联系VMware支持。
在NVIDIA文档中,在VMware GRID软件下载附带的用户指南中,367.43-369.17-nvidia-grid-vgpu-user-guide.pdf,在2.2.4.1(安装)和2.2.4.2(更新)部分中
列出的最后一步是重启主机。
杰里米
以上来自于谷歌翻译
以下为原文
Rachel,
Thanks for checking internally as well as with VMware. Not having to reboot sounds great, hopefully I get that working.
I updated both our GRID enabled servers when I did my updates. Both are test, so I can go back and redo this on one of those, but will be another day or two before I have time to do that. My experience at the time was that I could power on the VM after the upgrading the vib, until I restarted. Once I try this again, I'll get the exact error message to post here and reach out to VMware support.
On the NVIDIA documentation, in the user-guide included with the VMware GRID software download, 367.43-369.17-nvidia-grid-vgpu-user-guide.pdf, in both sections 2.2.4.1 (installing) and 2.2.4.2 (updating) the final step listed is to reboot the host.
Jeremy
瑞秋,
感谢您在内部以及VMware进行检查。
我在更新时更新了支持GRID的服务器。
列出的最后一步是重启主机。
杰里米
以上来自于谷歌翻译
以下为原文
Rachel,
Jeremy
举报
