英伟达
直播中
何羽衣
8年用户 225经验值
私信 关注
[问答]
ESXi 6.0.0上的网格K2
我正在为VMware Horizo​​n View 6进行安装。硬件是带有Grid K2 GPU的IBM / Lenovo x3500 M4。
我按照说明在主机上安装了驱动程序并重新启动但显然没有加载。
当我运行vmkload-Mod -l |时
grep nvidia我一无所获。
当我运行nvidia-smi它说“NVIDIA-SMI失败了,因为它无法与NVIDIA驱动程序通信。请确保安装并运行最新的NVIDIA驱动程序。”
我已经搜索过,而且我空洞了。
任何帮助表示赞赏。
布赖恩
以上来自于谷歌翻译
以下为原文
I am working on an install for VMware Horizon View 6. The hardware is an IBM/Lenovo x3500 M4 with a Grid K2 GPU.
I have installed the driver on the host as per the instructions and rebooted but it is not loading apparently. When I run vmkload-Mod -l | grep nvidia I get nothing. When I run nvidia-smi It says "NVIDIA-SMI has failed because it couldn't communicate with the NVIDIA driver. Make sure that the latest NVIDIA driver is installed and running."
I have searched and I am coming up empty. Any help is appreciated.
Brian
回帖(2)
杨月粉
2018-9-5 10:36:56
我认为BM / Lenovo x3500 M4不是网格认证服务器。
它没有在http://www.nvidia.com/object/grid-certified-servers.html中显示
以上来自于谷歌翻译
以下为原文
I think BM/Lenovo x3500 M4 is not grid certified server.  It’s not shown in http://www.nvidia.com/object/grid-certified-servers.html
举报
俞舟群
2018-9-5 10:49:24
嗨布莱恩,
您尝试使用的服务器似乎仅针对K40进行了认证。
我建议联系IBM以确定他们的认证计划以及他们是否可以提供帮助。
您是否购买了已安装卡的服务器?
或者,您可以考虑在sandipt在上面链接中提供的认证列表中获取其中一个机箱。
以上来自于谷歌翻译
以下为原文
Hi Brian,
It appears that the server you're trying to use is only certified for the K40.  I would suggest contacting IBM to determine their plans to certify and whether they can assist. Did you purchase the server with the cards already fitted?
Alternatively you could consider acquiring one of the chassis on the certified list theat sandipt has provided in the link above.
举报
更多回帖
