嗨 - 这是我们当前的版本:
Esxi vGPU经理= 346.58 赢7 = 348.27 我们正在尝试升级到当前版本: Esxi - 352.70 赢7/8 - 354.56 遇到问题。 我将Esxi方面升级到352.70 Esxi主机升级的2台机器拒绝启动。 我删除了K2卡,并通过网络视图将其读入一个。 没有帮助。 我将当前更新应用于我们的Esxi主机,这似乎有所帮助(我们现在是Esxi 6.0.0 3380124) 现在机器启动但根本看不到K2卡。 我们仍然在操作系统上运行旧驱动程序(即348.27)。 我正在尝试更新它,就像我更新了其他驱动程序,我得到的只是一个黑屏。 我输入密码,然后进入蓝屏(不是bsod)。 它从未登录过。 我们正在使用Unidesk,我们为我们的软件创建图层。 它现在已经好了好一年。 我即将尝试创建一个带有k2卡的快速机器并打开当前驱动程序(而不是“升级”它),看看是否有效。 这些新驱动程序有什么问题吗? 我们升级的主要原因只是为了获得Win 10支持。 谢谢, 以上来自于谷歌翻译 以下为原文 Hi- here are our current versions : Esxi vGPU manager = 346.58 Win 7 = 348.27 We are trying to upgrade to the current version of : Esxi - 352.70 Win 7 / 8 - 354.56 Running into problems. I upgraded the Esxi side 1st to 352.70 The 2 machines that were on the upgrade Esxi host refused to power on. I removed the K2 card and readded it to one via the web vcenter. Didn't help. I applied current updates to our Esxi host and that appeared to help ( we are now Esxi 6.0.0 3380124 ) Right now the machines power up but do not see the K2 card at all. We are still running the old driver on the OS ( ie 348.27 ). I'm trying to update it like i updated the other drivers and all i get is a black screen. I type the password and it goes to a blue screen ( not a bsod ). It never logs in. We are using Unidesk and we create layers for our software. It has worked fine for a good year now. I am about to try and just create a quick machine with a k2 card and slap on the current driver ( and not 'upgrade' it ) and see if that works. Any problems with these new drivers ? The main reason we are upgrading is just to get the Win 10 support. thanks, |
3个回答
嗨鲍勃,
如果有任何已知问题,我正在与团队核实。 最好的祝愿, 雷切尔 以上来自于谷歌翻译 以下为原文 Hi Bob, I'm checking with the team if any known issues. Best wishes, Rachel |
如果你使用的是vGPU或pass-thru(vDGA),你有点不清楚吗?
你说机器启动但看不到K2卡。 但是,如果您现在尝试安装较新的显示驱动程序354.56,则驱动程序安装程序会看到连接了GPU并安装正常。 在整个堆栈工作之前,您需要将ESXi 352.70与显示驱动程序354.56配对(至少这是vGPU)。 以上来自于谷歌翻译 以下为原文 Its a bit unclear if you are using vGPU or pass-thru (vDGA) could you elaborate on that ?. You say that the machines boot up but can't see the K2 card. But if you now try to install the newer display driver 354.56 does the driver installer see that there is a GPU attached and install OK. You need to pair the ESXi 352.70 with the display driver 354.56 before the whole stack will work (at least you do if this is vGPU). |
感谢大家。
我认为我们将Esxi主机升级到352.70& 桌面(赢7)到354.56。 在Mix的某个地方,我们似乎还需要升级我们的ESXI主机和更新管理器。 我们去了Esxi 6.0.0 rev 3380124(我们并不落后 - 我认为我们只应用了8个更新)。 虽然不是100%的esxi更新。 更新后我确实可以打开机器。 我们正在使用vGPU。 我升级了一个只有两个K2用户的Esxi主机,并且进展顺利。 我今天和明天正在休息 - 所以希望一切顺利。 谢谢你的帮助! 以上来自于谷歌翻译 以下为原文 Thanks Everyone. I think we have it working when both upgrading the Esxi host to 352.70 & the Desktop ( win 7 ) to 354.56. Somewhere in the Mix we also seemed to need to upgrade our ESXI hosts w/ update manager. We went to Esxi 6.0.0 rev 3380124 ( we were not far behind - I think there were only 8 updates we applied ). Not 100% the esxi updates were required though. It did appear after the update that I could turn the machines on. We are using vGPU. I upgraded an Esxi hosts that only had two K2 users on and that went well. I am doing the rest today and tomorrow - thus hopefully all goes well. thanks for the assistance !. |
只有小组成员才能发言,加入小组>>
使用Vsphere 6.5在Compute模式下使用2个M60卡遇到VM问题
3069 浏览 5 评论
是否有可能获得XenServer 7.1的GRID K2驱动程序?
3485 浏览 4 评论
GMT+8, 2024-11-22 04:50 , Processed in 0.687137 second(s), Total 101, Slave 84 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
