英伟达
直播中
潘晓明
7年用户 197经验值
私信 关注
[问答]
通过vDGA在XenDesktop中***lverlight
使用vSphere vDGA和K2的XenDesktop 7.1。
根据评论者指南进行设置。
我可以通过HDX MOnitor显示HDX3D Pro以及1080p youtube等确认一般图形加速。但是,我无法获得编译的Silverlight应用程序来加速。
在不起眼的物理PC上的性能得到了很大改善。
Silverlight配置实用程序未显示选中使用硬件加速的选项。
几次尝试检查盒子不成功。
直接编辑注册表允许框保持检查但行为没有区别。
该应用程序是一个编译(和闭源)silverlight应用程序,一个.xap,在浏览器外部运行,并直接使用slauncher.exe调用。
任何关于正确加速Silverlight应用程序的反馈都将受到赞赏。
以上来自于谷歌翻译
以下为原文
XenDesktop 7.1 using vSphere vDGA and a K2.  Setup per the reviewer's guide.  I can confirm general graphics acceleration via HDX MOnitor showing HDX3D Pro as well as 1080p youtube, etc.  However, I cannot get a compiled Silverlight application to accelerate.  Performance on an unremarkable yet physical PC is much improved.  The Silverlight configuration utility did not show the option to use hardware acceleration as checked.  Several attempts to check the box unsucessful.  Directly editing the registry allowed the box to remain checked but made no difference in behavior.  The application is a compiled (and closed-source) silverlight application, an .xap, running outside of the browser and called directly with slauncher.exe.  Any feedback on proper acceleration of a Silverlight application would be appreciated.
回帖(1)
张秀荣
2018-9-5 09:50:02
你使用的是哪种浏览器?
仅供参考 -  Internet Explorer将在虚拟环境中运行时禁用所有硬件加速,因此您可能需要尝试其他浏览器,因为我相信Silverlight将从浏览器继承此设置。
以上来自于谷歌翻译
以下为原文
Which browser are you using?
FYI - Internet Explorer will disable all HW acceleration when running in a virtual environment and so you would probably need to try another browser as I believe Silverlight will inherit this setting from the browser.
举报
更多回帖
