嗨 - 有关将某人从vDGA转移到vGPU需要做些什么的想法?
我们是否删除了PCI HOLE条目? “2.调整pciHole.start。 注意:仅当虚拟机的配置内存超过2GB时才需要此选项。 对于配置内存超过2GB的虚拟机,请将以下参数添加到 虚拟机的.vmx文件(可以在文件末尾添加): pciHole.start =“2048” “ 感谢您的帮助。 以上来自于谷歌翻译 以下为原文 Hi - any thoughts on what we need to do to move someone from vDGA to vGPU ? Do we remove the PCI HOLE entry ? "2. Adjust pciHole.start. Note: This is required only if the virtual machine has more than 2GB of configured memory. For virtual machines that have more than 2GB of configured memory, add the following parameter to the .vmx file of the virtual machine (you can add this at the end of the file): pciHole.start = “2048” " thank you for the assistance. |
5个回答
这是关于VM中的vRAM,而不是GPU内存。
如果您的VM具有超过2GB的系统内存(vRAM),则您很可能仍需要此功能。 您不需要将GPU作为PCI-e设备通过THRU。 您需要在主机上安装vGPU VIB驱动程序,并在VM上安装相应的NVIDIA WDDM驱动程序。 详情如下: http://www.nvidia.com/object/grid-enterprise-resources.html#guides 单击适用于VMware Horizon 6.1的NVIDIA GRID™vGPU™部署指南链接。 以上来自于谷歌翻译 以下为原文 This is with regards to the vRAM in the VM, not GPU memory. If your VM has more than 2GB System Memory (vRAM) you most likely still need this. You will need to not PASS THRU the GPU as a PCI-e device. You will need to install a vGPU VIB driver on the Host and a corresponding NVIDIA WDDM driver on the VM. Details here: http://www.nvidia.com/object/grid-enterprise-resources.html#guides Click on the NVIDIA GRID™ vGPU™ Deployment Guide for VMware Horizon 6.1 link. |
好。
谢谢。 所以听起来像使用K2卡将pcihole.start添加到任何View桌面的每个VMX文件中..是的? 以上来自于谷歌翻译 以下为原文 ok. thank you. So it sounds like Add that pcihole.start to every VMX file of any View desktop using a K2 Card.. yes? |
如果您使用的是vSphere 6,则不再需要此功能。
以上来自于谷歌翻译 以下为原文 If you're on vSphere 6 you shouldn't need this any longer. |
嗨,
最新版本“在Horizon 6中使用View Virtual Desktops部署硬件加速图形”中仍然提到了pcihole条目 如果省略这个条目,该怎么做以及会出错? 以上来自于谷歌翻译 以下为原文 Hi, The pcihole entry is still mentioned in the latest version of "Deploying Hardware-Accelerated Graphics with View Virtual Desktops in Horizon 6" What does the entry do and what would go wrong if this was omitted? |
嗨,
这里的任何人都可以在vsphere 6中使用vDGA(每个vm的完整核心)启动vms吗? 我不是说vGPU! 我只能用vDGA核心启动一台机器。 第二个没有开始。 我正在使用GRID K1卡。 以上来自于谷歌翻译 以下为原文 Hi, anybody here can start vms with vDGA (full core per vm) in vsphere 6? I does not mean vGPU! I only can start one machine with vDGA core. The second one does not start. Im using GRID K1 cards. |
只有小组成员才能发言,加入小组>>
使用Vsphere 6.5在Compute模式下使用2个M60卡遇到VM问题
3095 浏览 5 评论
是否有可能获得XenServer 7.1的GRID K2驱动程序?
3511 浏览 4 评论
GMT+8, 2024-12-4 00:57 , Processed in 0.702513 second(s), Total 82, Slave 66 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
