我不会假装知道你的'Rho'和你的'compl vectordisplays',但命令:trace:data?
trace1然后读取一个REAL ARRAY:401返回(401个数据点)它对我有用!!我发现这是一个令人烦恼的安捷伦允许你设置E系列上的点数 - 但不是在L系列上
- grrrr !! Alex。(Raytheon Systems)英国“Daly,Denis”致:VRF主题:[vrf] E4406 VSA I / Q测量compl矢量跟踪下载?
21/01/04 14:47请回复“Daly,Denis”文具名称:-Untitled-您好我使用Vee 6.2和windows 2k。当使用e4406 VSA测量cdma IS95时。当Rho显示器显示时
I / Q测量Compl矢量显示。我找不到下载跟踪数据的命令(即使在阅读程序员手册之后!)你们中的任何人都找到了正确的命令来做这个吗?任何帮助都会很棒谢谢Denis ---
您目前订阅到VRF为:Alex.Barrett@raytheon.co.ukTo订阅发送空白邮件到“join-vrf@it.lists.it.agilent.com”。要退订发送一个空白邮件“离开-VRF
@ it.lists.it.agilent.com“。要发送邮件到这个邮件列表,请发送电子邮件至”vrf@agilent.com“。如果您需要有关邮件列表的帮助,请发送邮件至”owner-vrf@it.lists。
it.agilent.com“。将您最喜欢的VEE示例发送到”VRF-EXAMPLES@agilent.com“,以便在VEE 7.0中包含可能的内容!---您目前订阅的是vrf:r***@soco.agilent.com要订阅发送空白
发送电子邮件至“join-vrf @ it。
lists.it.agilent.com“。要取消订阅,请发送空白电子邮件至”leave-vrf@it.lists.it.agilent.com“。要向此邮件列表发送邮件,请发送电子邮件至”vrf@agilent.com“。
如果您需要有关邮件列表的帮助,请发送邮件至“owner-vrf@it.lists.it.agilent.com”。将您最喜欢的VEE示例发送到“VRF-EXAMPLES@agilent.com”,以便可能包含在VEE 7.0中!
以上来自于谷歌翻译
以下为原文
I won't pretend to know anything about your 'Rho's' and your 'compl vector
displays' but the command:
trace:data? trace1
and then read a REAL ARRAY:401 back
(for 401 data points)
it works for me!!
an annoyonce I found with this though is that Agilent allowed you to set
the number of points on the E series - but not on the L- Series - grrrr!!
Alex.
(Raytheon Systems)
UK
"Daly, Denis" To: VRF
Subject: [vrf] E4406 VSA I/Q measured compl vector trace download?
21/01/04
14:47
Please respond to "Daly, Denis"
Stationery name:-Untitled-
Hi I am using Vee 6.2 and windows 2k.
When using the e4406 VSA for measuring cdma IS95.
When the Rho display is up showing the I/Q Measured Compl vector display.
I cannot find a command to download the trace data (even after reading the
programmers manual!)
Have any of you folks found the right set of commands to do this?
Any help would be great
Thanks Denis
You are currently subscribed to vrf as:
To subscribe send a blank email to "join-vrf@it.lists.it.agilent.com".
To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com".
To send messages to this mailing list, email "vrf@agilent.com".
If you need help with the mailing list send a message to
"owner-vrf@it.lists.it.agilent.com".
Send your favorite VEE example to "VRF-EXAMPLES@agilent.com" for possible
inclusion in VEE 7.0!
You are currently subscribed to vrf as: [email=r***@soco.agilent.com]r***@soco.agilent.com[/email]
If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com".
Send your favorite VEE example to "VRF-EXAMPLES@agilent.com" for possible inclusion in VEE 7.0!
以上来自于谷歌翻译
以下为原文
trace:data? trace1
it works for me!!
Alex.
(Raytheon Systems)
UK
21/01/04
14:47
Thanks Denis
举报
