STM32/STM8技术论坛
直播中
Mr_RMS
8年用户 327经验值
擅长:可编程逻辑 嵌入式技术 处理器/DSP 接口/总线/驱动 控制/MCU
私信 关注
[问答]
STM32F107VC 能够Jlink仿真吗?
应该是可以的吧,但是我配置好之后,程序编译没问题,点击debug后,Peripheral里却没有外设选项,这是因为什么呢?下图是我的Option配置,以及调试出现问题的界面
程序:
#include "STM32f10x.h"
#include
void RCC_Configuration(void);
void GPIO_Configuration(void);
USART_InitTypeDef USART_InitStructure;
int main(void)
  u16 F;
        u8  data='A';
        RCC_Configuration();
        GPIO_Configuration();
        USART_InitStructure.USART_BaudRate = 9600;
  USART_InitStructure.USART_WordLength = USART_WordLength_8b;
  USART_InitStructure.USART_StopBits = USART_StopBits_1;
  USART_InitStructure.USART_Parity = USART_Parity_No;
  USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;
  USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;
  USART_Init(USART1, &USART_InitStructure);
        USART_Cmd(USART1,ENABLE);
        for(F=0;F<20;F++)
                USART1->DR = data;
                data++;
                while((USART1->SR & (1<<6))==0) ;
        RCC_DeInit();
        RCC_HSEConfig(RCC_HSE_ON);
        while(RCC_GetFlagStatus(RCC_FLAG_HSERDY) == RESET);
        RCC_HCLKConfig(RCC_SYSCLK_Div1);                //HCLK = SYSCLK
        RCC_PCLK2Config(RCC_HCLK_Div1);                        //PCLK2 =  HCLK
        RCC_PCLK1Config(RCC_HCLK_Div2);                        //PCLK1 = HCLK/2
        RCC_PLLConfig(RCC_PLLSource_HSE_Div1,RCC_PLLMul_9);        //PLLCLK = 8MHZ * 9 =72MHZ
        RCC_PLLCmd(ENABLE);                        //Enable PLLCLK
        while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET);        //Wait till PLLCLK is ready
    RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);        //Select PLL as system clock
        while(RCC_GetSYSCLKSource()!=0x08);                //Wait till PLL is used as system clock source
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA,ENABLE);
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC,ENABLE);
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO,ENABLE);
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1,ENABLE);
  GPIO_InitTypeDef GPIO_InitStructure;
  /* Configure USARTx_Tx as alternate function push-pull */
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;
  GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
  GPIO_Init(GPIOA, &GPIO_InitStructure);
  /* Configure USARTx_Rx as input floating */
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
已退回10积分
回帖(21)
猎国倾城
2017-4-7 18:01:15
完全支持Jlink
举报
汪晨阳
2017-4-7 19:52:31
应该是支持的
举报
失火的天堂1234
2017-4-7 21:14:45
支持的,可以用
举报
Mr_RMS
2017-4-8 09:05:01
引用: 猎国倾城 发表于 2017-4-7 18:01
完全支持Jlink
那为什么会出现上面的结果呢?
举报
Mr_RMS
2017-4-8 09:05:33
引用: hbwldz 发表于 2017-4-7 19:52
应该是支持的
那为什么会出现这样的情况啊?
举报
Mr_RMS
2017-4-8 09:05:50
引用: 失火的天堂1234 发表于 2017-4-7 21:14
支持的,可以用
那为什么会出现这样的情况啊?
举报
大头老王
2017-4-8 10:20:06
可以吧
举报
大头老王
2017-4-8 10:20:11
可以吧
举报
Mr_RMS
2017-4-8 11:09:29
那为什么会出现我这种情况呀?
举报
猎国倾城
2017-4-8 12:07:44
引用: Mr_RMS 发表于 2017-4-8 09:05
那为什么会出现上面的结果呢?
你用的是那个串口
举报
Mr_RMS
2017-4-8 12:28:03
引用: 猎国倾城 发表于 2017-4-8 12:07
你用的是那个串口
通用同步异步收发器 USART1
举报
猎国倾城
2017-4-8 12:35:31
引用: Mr_RMS 发表于 2017-4-8 12:28
通用同步异步收发器 USART1
你可以看一下这个blog.csdn.net/lestrade_/article/details/54784112
举报
一眼万年Mike
2017-4-9 15:04:27
好像是驱动没有安装正确吧
举报
Mr_RMS
2017-4-9 16:58:43
引用: 一眼万年Mike 发表于 2017-4-9 15:04
好像是驱动没有安装正确吧
程序可以用Jlink正常下载到开发板上,也能正常运行
举报
h1654155945.7192
2017-4-9 22:05:22
受到警告
提示: 作者被禁止或删除 内容自动屏蔽
举报
h1654155945.7192
2017-4-9 22:05:41
受到警告
提示: 作者被禁止或删除 内容自动屏蔽
举报
Mr_RMS
2017-4-10 15:09:20
受到警告
提示: 作者被禁止或删除 内容自动屏蔽
举报
jinyi7016
2017-4-11 17:06:58
没有结果,你的程序配置是不是正确
举报
Mr_RMS
2017-4-11 17:19:18
引用: jinyi7016 发表于 2017-4-11 17:06
没有结果,你的程序配置是不是正确
配置应该没错的
举报
更多回帖
