转dsp系列教程
本期教程主要讲解矩阵运算中的初始化,加法,逆矩阵和减法。 19.1 矩阵初始化 Matinit 19.2 矩阵加法 MatAdd 19.3 逆矩阵 MatInverse 19.4 矩阵减法 MatSub 19.5 总结 19.1 矩阵初始化 MatInit 19.1.1 arm_mat_init_f32 函数定义如下: void arm_mat_init_f32( arm_matrix_instance_f32 * S, uint16_t nRows, uint16_t nColumns, float32_t * pData) 参数定义: [in,out] *S points to an instance of the floating-point matrix structure. [in] nRows number of rows in the matrix. [in] nColumns number of columns in the matrix. [in] *pData points to the matrix data array. 注意事项: 1. arm_matrix_instance_f32的结构体定义如下(在文件arm_math.h文件里面): typedef struct { uint16_t numRows; // number of rows of the matrix. uint16_t numCols; // number of columns of the matrix. float32_t *pData; // points to the data of the matrix. } arm_matrix_instance_f32; |
19.1.2 arm_mat_init_q31
函数定义如下: void arm_mat_init_q31( arm_matrix_instance_q31 * S, uint16_t nRows, uint16_t nColumns, q31_t * pData) 参数定义: [in,out] *S points to an instance of the floating-point matrix structure. [in] nRows number of rows in the matrix. [in] nColumns number of columns in the matrix. [in] *pData points to the matrix data array. 注意事项: 1. arm_matrix_instance_q31的结构体定义如下(在文件arm_math.h文件里面): typedef struct { uint16_t numRows; // number of rows of the matrix. uint16_t numCols; // number of columns of the matrix. q31_t *pData; // points to the data of the matrix. } arm_matrix_instance_q31; |
19.1.3 arm_mat_init_q15
函数定义如下: void arm_mat_init_q15( arm_matrix_instance_q15 * S, uint16_t nRows, uint16_t nColumns, q15_t * pData) 参数定义: [in,out] *S points to an instance of the floating-point matrix structure. [in] nRows number of rows in the matrix. [in] nColumns number of columns in the matrix. [in] *pData points to the matrix data array. 注意事项: 1. arm_matrix_instance_q15的结构体定义如下(在文件arm_math.h文件里面): typedef struct { uint16_t numRows; // number of rows of the matrix. uint16_t numCols; // number of columns of the matrix. q15_t *pData; // points to the data of the matrix. } arm_matrix_instance_q15; |
19.1.4 实例讲解
实验目的: 1. 学习MatrixFunctions中矩阵的初始化 实验内容: 1. 按下按键K1, 串口打印函数DSP_MatInit的输出结果 实验现象: 通过窗口上位机软件SecureCRT(V5光盘里面有此软件)查看打印信息现象如下: |
程序设计:
复制代码 /* ********************************************************************************************************* * 函 数 名: DSP_MatInit * 功能说明: 矩阵数据初始化 * 形 参:无 * 返 回 值: 无 ********************************************************************************************************* */ static void DSP_MatInit(void) { uint8_t i; /****浮点数数组******************************************************************/ float32_t pDataA[9] = {1.1f, 1.1f, 2.1f, 2.1f, 3.1f, 3.1f, 4.1f, 4.1f, 5.1f}; arm_matrix_instance_f32 pSrcA; //3行3列数据 arm_matrix_instance_f32 pDst; /****定点数Q31数组******************************************************************/ q31_t pDataA1[9] = {1, 1, 2, 2, 3, 3, 4, 4, 5}; arm_matrix_instance_q31 pSrcA1; //3行3列数据 arm_matrix_instance_q31 pDst1; /****定点数Q15数组******************************************************************/ q15_t pDataA2[9] = {1, 1, 2, 2, 3, 3, 4, 4, 5}; arm_matrix_instance_q15 pSrcA2; //3行3列数据 arm_matrix_instance_q15 pDst2; /****浮点数***********************************************************************/ printf("****浮点数******************************************rn"); arm_mat_init_f32(&pSrcA, 3,3, pDataA); for(i = 0; i < 9; i++) { printf("pDataA[%d] = %frn", i, pDataA[i]); } /****定点数Q31***********************************************************************/ printf("****浮点数******************************************rn"); arm_mat_init_q31(&pSrcA1, 3,3, pDataA1); for(i = 0; i < 9; i++) { printf("pDataA1[%d] = %drn", i, pDataA1[i]); } /****定点数Q15***********************************************************************/ printf("****浮点数******************************************rn"); arm_mat_init_q15(&pSrcA2, 3,3, pDataA2); for(i = 0; i < 9; i++) { printf("pDataA2[%d] = %drn", i, pDataA2[i]); } } |
19.2 矩阵加法 MatAdd
19.2.1 arm_mat_add_f32 公式描述(以3*3矩阵为例进行说明): 函数定义如下: arm_status arm_mat_add_f32( const arm_matrix_instance_f32 * pSrcA, const arm_matrix_instance_f32 * pSrcB, arm_matrix_instance_f32 * pDst) 参数定义: [in] *pSrcA points to the first input matrix structure [in] *pSrcB points to the second input matrix structure [out] *pDst points to output matrix structure return The function returns either 注意事项: 1. pSrcA,pSrcB,pDst的行数和列数必须是相同的,要不没有办法使用加法运行。 2. 矩阵在数组中的存储是从左到右,再从上到下。 |
19.2.2 arm_mat_add_q31
函数定义如下: arm_status arm_mat_add_q31( const arm_matrix_instance_q31 * pSrcA, const arm_matrix_instance_q31 * pSrcB, arm_matrix_instance_q31 * pDst) 参数定义: [in] *pSrcA points to the first input matrix structure [in] *pSrcB points to the second input matrix structure [out] *pDst points to output matrix structure return The function returns either 注意事项: 1. pSrcA,pSrcB,pDst的行数和列数必须是相同的,要不没有办法使用加法运行。 2. 矩阵在数组中的存储是从左到右,再从上到下。 19.2.3 arm_mat_add_q15 函数定义如下: arm_status arm_mat_add_q15( const arm_matrix_instance_q15 * pSrcA, const arm_matrix_instance_q15 * pSrcB, arm_matrix_instance_q15 * pDst) 参数定义: [in] *pSrcA points to the first input matrix structure [in] *pSrcB points to the second input matrix structure [out] *pDst points to output matrix structure return The function returns either 注意事项: 1. pSrcA,pSrcB,pDst的行数和列数必须是相同的,要不没有办法使用加法运行。 2. 矩阵在数组中的存储是从左到右,再从上到下。 |
19.2.4 实例讲解
实验目的: 1. 学习MatrixFunctions中矩阵的加法 实验内容: 1. 按下按键K2, 串口打印函数DSP_MatAdd的输出结果 实验现象: 通过窗口上位机软件SecureCRT(V5光盘里面有此软件)查看打印信息现象如下: |
程序设计:
复制代码 /* ********************************************************************************************************* * 函 数 名: DSP_MatAdd * 功能说明: 矩阵求和 * 形 参:无 * 返 回 值: 无 ********************************************************************************************************* */ static void DSP_MatAdd(void) { uint8_t i; /****浮点数数组******************************************************************/ float32_t pDataA[9] = {1.1f, 1.1f, 2.1f, 2.1f, 3.1f, 3.1f, 4.1f, 4.1f, 5.1f}; float32_t pDataB[9] = {1.1f, 1.1f, 2.1f, 2.1f, 3.1f, 3.1f, 4.1f, 4.1f, 5.1f}; float32_t pDataDst[9]; arm_matrix_instance_f32 pSrcA; //3行3列数据 arm_matrix_instance_f32 pSrcB; //3行3列数据 arm_matrix_instance_f32 pDst; /****定点数Q31数组******************************************************************/ q31_t pDataA1[9] = {1, 1, 2, 2, 3, 3, 4, 4, 5}; q31_t pDataB1[9] = {1, 1, 2, 2, 3, 3, 4, 4, 5}; q31_t pDataDst1[9]; arm_matrix_instance_q31 pSrcA1; //3行3列数据 arm_matrix_instance_q31 pSrcB1; //3行3列数据 arm_matrix_instance_q31 pDst1; /****定点数Q15数组******************************************************************/ q15_t pDataA2[9] = {1, 1, 2, 2, 3, 3, 4, 4, 5}; q15_t pDataB2[9] = {1, 1, 2, 2, 3, 3, 4, 4, 5}; q15_t pDataDst2[9]; arm_matrix_instance_q15 pSrcA2; //3行3列数据 arm_matrix_instance_q15 pSrcB2; //3行3列数据 arm_matrix_instance_q15 pDst2; /****浮点数***********************************************************************/ pSrcA.numCols = 3; pSrcA.numRows = 3; pSrcA.pData = pDataA; pSrcB.numCols = 3; pSrcB.numRows = 3; pSrcB.pData = pDataB; pDst.numCols = 3; pDst.numRows = 3; pDst.pData = pDataDst; printf("****浮点数******************************************rn"); arm_mat_add_f32(&pSrcA, &pSrcB, &pDst); for(i = 0; i < 9; i++) { printf("pDataDst[%d] = %frn", i, pDataDst[i]); } /****定点数Q31***********************************************************************/ pSrcA1.numCols = 3; pSrcA1.numRows = 3; pSrcA1.pData = pDataA1; pSrcB1.numCols = 3; pSrcB1.numRows = 3; pSrcB1.pData = pDataB1; pDst1.numCols = 3; pDst1.numRows = 3; pDst1.pData = pDataDst1; printf("****定点数Q31******************************************rn"); arm_mat_add_q31(&pSrcA1, &pSrcB1, &pDst1); for(i = 0; i < 9; i++) { printf("pDataDst1[%d] = %drn", i, pDataDst1[i]); } /****定点数Q15***********************************************************************/ pSrcA2.numCols = 3; pSrcA2.numRows = 3; pSrcA2.pData = pDataA2; pSrcB2.numCols = 3; pSrcB2.numRows = 3; pSrcB2.pData = pDataB2; pDst2.numCols = 3; pDst2.numRows = 3; pDst2.pData = pDataDst2; printf("****定点数Q15******************************************rn"); arm_mat_add_q15(&pSrcA2, &pSrcB2, &pDst2); for(i = 0; i < 9; i++) { printf("pDataDst2[%d] = %drn", i, pDataDst2[i]); } } |
19.3 逆矩阵 MatInverse
19.3.1 arm_mat_inverse_f32 公式描述(Gauss-Jordan法求逆矩阵): 函数定义如下: arm_status arm_mat_inverse_f32( const arm_matrix_instance_f32 * pSrc, arm_matrix_instance_f32 * pDst) 参数定义: [in] *pSrc points to input matrix structure [out] *pDst points to output matrix structure 注意事项: 1. pSrc必须得是方阵(行数和列数相同)。 2. pSrc和pDst必须是相同的方阵。 3. 输入的矩阵可逆,函数会返回ARM_MATH_SUCCESS,如果不可逆,返回ARM_MATH_SINGULAR。 4. ARM官方库只提供了浮点数矩阵求逆矩阵。 |
19.3.2 实例讲解
实验目的: 1. 学习MatrixFunctions中逆矩阵的求解 实验内容: 1. 按下按键K3, 串口打印函DSP_MatInverse的输出结果 实验现象: 通过窗口上位机软件SecureCRT(V5光盘里面有此软件)查看打印信息现象如下: |
程序设计:
复制代码 /* ********************************************************************************************************* * 函 数 名: DSP_MatInverse * 功能说明: 求逆矩阵 * 形 参:无 * 返 回 值: 无 ********************************************************************************************************* */ static void DSP_MatInverse(void) { uint8_t i; /****浮点数数组******************************************************************/ float32_t pDataA[9] = {1.1f, 1.1f, 2.1f, 2.1f, 3.1f, 3.1f, 4.1f, 4.1f, 5.1f}; float32_t pDataB[9]; arm_matrix_instance_f32 pSrcA; //3行3列数据 arm_matrix_instance_f32 pSrcB; //3行3列数据; /****浮点数***********************************************************************/ pSrcA.numCols = 3; pSrcA.numRows = 3; pSrcA.pData = pDataA; pSrcB.numCols = 3; pSrcB.numRows = 3; pSrcB.pData = pDataB; arm_mat_inverse_f32(&pSrcA, &pSrcB); for(i = 0; i < 9; i++) { printf("pDataB[%d] = %frn", i, pDataB[i]); } } |
1. 用C语言实现逆矩阵要稍麻烦些,下面我们通过Matlab来实现求逆矩阵(数据和上面代码中的程序一样)
可以看出求得结果跟上面的C函数求得结果基本一致。 |
19.4 矩阵减法 MatSub
19.4.1 arm_mat_sub_f32 公式描述(以3*3矩阵为例进行说明): 函数定义如下: arm_status arm_mat_sub_f32( const arm_matrix_instance_f32 * pSrcA, const arm_matrix_instance_f32 * pSrcB, arm_matrix_instance_f32 * pDst) 参数定义: [in] *pSrcA points to the first input matrix structure [in] *pSrcB points to the second input matrix structure [out] *pDst points to output matrix structure return The function returns either 注意事项: 1. pSrcA,pSrcB,pDst的行数和列数必须是相同的,要不没有办法使用加法运行。 2. 矩阵在数组中的存储是从左到右,再从上到下。 |
19.4.2 arm_mat_add_q31
函数定义如下: arm_status arm_mat_add_q31( const arm_matrix_instance_q31 * pSrcA, const arm_matrix_instance_q31 * pSrcB, arm_matrix_instance_q31 * pDst) 参数定义: [in] *pSrcA points to the first input matrix structure [in] *pSrcB points to the second input matrix structure [out] *pDst points to output matrix structure return The function returns either 注意事项: 1. pSrcA,pSrcB,pDst的行数和列数必须是相同的,要不没有办法使用加法运行。 2. 矩阵在数组中的存储是从左到右,再从上到下。 |
19.4.3 arm_mat_add_q15
19.4.4 实例讲解
程序设计:
复制代码 /* ********************************************************************************************************* * 函 数 名: DSP_MatSub * 功能说明: 矩阵减法 * 形 参:无 * 返 回 值: 无 ********************************************************************************************************* */ static void DSP_MatSub(void) { uint8_t i; /****浮点数数组******************************************************************/ float32_t pDataA[9] = {1.1f, 1.1f, 2.1f, 2.1f, 3.1f, 3.1f, 4.1f, 4.1f, 5.1f}; float32_t pDataB[9] = {1.1f, 1.1f, 2.1f, 2.1f, 3.1f, 3.1f, 4.1f, 4.1f, 5.1f}; float32_t pDataDst[9]; arm_matrix_instance_f32 pSrcA; //3行3列数据 arm_matrix_instance_f32 pSrcB; //3行3列数据 arm_matrix_instance_f32 pDst; /****定点数Q31数组******************************************************************/ q31_t pDataA1[9] = {1, 1, 2, 2, 3, 3, 4, 4, 5}; q31_t pDataB1[9] = {2, 2, 2, 2, 2, 2, 2, 2, 2}; q31_t pDataDst1[9]; arm_matrix_instance_q31 pSrcA1; //3行3列数据 arm_matrix_instance_q31 pSrcB1; //3行3列数据 arm_matrix_instance_q31 pDst1; /****定点数Q15数组******************************************************************/ q15_t pDataA2[9] = {1, 1, 2, 2, 3, 3, 4, 4, 5}; q15_t pDataB2[9] = {2, 2, 2, 2, 23, 2, 2, 2, 2}; q15_t pDataDst2[9]; arm_matrix_instance_q15 pSrcA2; //3行3列数据 arm_matrix_instance_q15 pSrcB2; //3行3列数据 arm_matrix_instance_q15 pDst2; /****浮点数***********************************************************************/ pSrcA.numCols = 3; pSrcA.numRows = 3; pSrcA.pData = pDataA; pSrcB.numCols = 3; pSrcB.numRows = 3; pSrcB.pData = pDataB; pDst.numCols = 3; pDst.numRows = 3; pDst.pData = pDataDst; printf("****浮点数******************************************rn"); arm_mat_sub_f32(&pSrcA, &pSrcB, &pDst); for(i = 0; i < 9; i++) { printf("pDataDst[%d] = %frn", i, pDataDst[i]); } /****定点数Q31***********************************************************************/ pSrcA1.numCols = 3; pSrcA1.numRows = 3; pSrcA1.pData = pDataA1; pSrcB1.numCols = 3; pSrcB1.numRows = 3; pSrcB1.pData = pDataB1; pDst1.numCols = 3; pDst1.numRows = 3; pDst1.pData = pDataDst1; printf("****定点数Q31******************************************rn"); arm_mat_sub_q31(&pSrcA1, &pSrcB1, &pDst1); for(i = 0; i < 9; i++) { printf("pDataDst1[%d] = %drn", i, pDataDst1[i]); } /****定点数Q15***********************************************************************/ pSrcA2.numCols = 3; pSrcA2.numRows = 3; pSrcA2.pData = pDataA2; pSrcB2.numCols = 3; pSrcB2.numRows = 3; pSrcB2.pData = pDataB2; pDst2.numCols = 3; pDst2.numRows = 3; pDst2.pData = pDataDst2; printf("****定点数Q15******************************************rn"); arm_mat_sub_q15(&pSrcA2, &pSrcB2, &pDst2); for(i = 0; i < 9; i++) { printf("pDataDst2[%d] = %drn", i, pDataDst2[i]); } } |
265 浏览 0 评论
【原创】【RA4M2-SENSOR开发板评测】低功耗+USB综合测试
789 浏览 0 评论
1306 浏览 2 评论
787 浏览 0 评论
【RA4M2-SENSOR开发板评测】Analogue+Timers综合测试
1587 浏览 0 评论
【youyeetoo X1 windows 开发板体验】少儿AI智能STEAM积木平台
16899 浏览 31 评论
/9
GMT+8, 2025-12-1 23:00 , Processed in 2.012039 second(s), Total 101, Slave 83 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
