/*CAN总线实验 采用回环测试
开发板通过CAN总线发送0xAB,0xCD,自己发送自己接收 CAN 所需GPIO不使用重映射 回环测试无需外接导线 适用一块开发板测试 */ #include"STM32f10x.h" #include CanTxMsg TxMessage; //CAN发送缓冲区 CanRxMsg RxMessage; //CAN接收缓冲区 int flag=0xff; //判断接收标志 /*GPIO设置 */ GPIO_Configuration() //GPIO的设置 CAN发送接收引脚设置 { GPIO_InitTypeDef GPIO_InitStructure; //定义结构体 RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE); GPIO_InitStructure.GPIO_Pin = GPIO_Pin_12; //选中第12引脚 GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; //设置输出速率为50MHz GPIO_InitStructure.GPIO_Mode =GPIO_Mode_IPU; //设置输出方式为上拉输入 GPIO_Init(GPIOA, &GPIO_InitStructure); //取GPIO为GPIOA GPIO_InitStructure.GPIO_Pin = GPIO_Pin_11; //选中第11引脚 GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; //设置输出速率为50MHz GPIO_InitStructure.GPIO_Mode =GPIO_Mode_Out_PP; //设置输出方式为推挽输出 GPIO_Init(GPIOA, &GPIO_InitStructure); //取GPIO为GPIOA } void Dealy_Ms(u16 x) //延时 {int i,j; for(i=0;i<1000;i++) for(j=0;j int fputc(int ch,FILE *f) //将printf函数指向USART1 发送数据时便可直接调用printf { USART1->SR; USART_SendData(USART1, ch); //ch送给USART1 while(USART_GetFlagStatus(USART1, USART_FLAG_TC)==RESET); //等待发送完毕 return ch; //返回ch } /*UART1发送函数 */ USART1_Configuration() //usart1串口设置 { USART_InitTypeDef USART_InitStructure; GPIO_InitTypeDef GPIO_InitStructure; RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1|RCC_APB2Periph_GPIOA,ENABLE); //usart1串口时钟使能 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9; //选中第9引脚 GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; //设置输出速率为50MHz GPIO_InitStructure.GPIO_Mode =GPIO_Mode_AF_PP; //设置输出方式为复用输出 GPIO_Init(GPIOA, &GPIO_InitStructure); GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10; //选中第10引脚 GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; //设置输出速率为50MHz GPIO_InitStructure.GPIO_Mode =GPIO_Mode_IN_FLOATING; //设置输出方式为模拟输入 GPIO_Init(GPIOA, &GPIO_InitStructure); USART_DeInit(USART1); //初始化 USART_InitStructure.USART_BaudRate = 9600; //9600波特率 USART_InitStructure.USART_WordLength = USART_WordLength_8b; //八个字节 USART_InitStructure.USART_StopBits = USART_StopBits_1; //停止位为1位 USART_InitStructure.USART_Parity = USART_Parity_No; //无校验 USART_InitStructure.USART_HardwareFlowControl =USART_HardwareFlowControl_None; //无硬件流 USART_InitStructure.USART_Mode = USART_Mode_Tx | USART_Mode_Rx; //接收和发送功能使能 USART_Init(USART1, &USART_InitStructure); USART_Cmd(USART1, ENABLE); //串口使能 } /* CAN总线的模式初始化 */ void CAN_Mode_Configriation(void) { CAN_InitTypeDef CAN_InitStructure; CAN_DeInit(CAN1); //CAN总线寄存器初始化 CAN_StructInit(&CAN_InitStructure); //CAN单元初始化 RCC_APB1PeriphClockCmd(RCC_APB1Periph_CAN1,ENABLE); //开启CAN总线时钟 CAN_InitStructure.CAN_TTCM = DISABLE; //关闭时间时间触发通信 CAN_InitStructure.CAN_ABOM = ENABLE; //开启自动离线管理 CAN_InitStructure.CAN_AWUM = ENABLE; //开启自动唤醒模式 CAN_InitStructure.CAN_NART = DISABLE; //开启禁止报文自动重传 CAN_InitStructure.CAN_RFLM = DISABLE; //开启接收FIFO锁定模式 DISABLE设置为溢出时新报文覆盖原有报文 CAN_InitStructure.CAN_TXFP = DISABLE; //发送FIFO优先级 DISABLE设置为优先级取决于报文标识符 ENABLE设置为顺序优先级 CAN_InitStructure.CAN_Mode = CAN_Mode_LoopBack; // 设置工作模式为回环测试 一块开发板无需接任何线 CAN_InitStructure.CAN_SJW = CAN_BS1_2tq; //重新同步跳跃宽度为2个时间单元 CAN_InitStructure.CAN_BS1 = CAN_BS1_6tq; //BTR-TS1时间段1占用6个时间单元 CAN_InitStructure.CAN_BS2 = CAN_BS2_3tq; //BTR-TS1时间段2占用3个时间单元 CAN_InitStructure.CAN_Prescaler =4; //BTR-BRP波特率分频器 定义时间单元的时间大小 //APB1的时钟频率为36M 则传输速率为36/(1+3+6)/4=0.8Mbps CAN_Init(CAN1,&CAN_InitStructure); } /* CAN的过滤器设置 */ void CAN_Filter_Configriation(void) { CAN_FilterInitTypeDef CAN_FilterInitStructure; CAN_FilterInitStructure.CAN_FilterNumber = 2; //设置过滤器组2 CAN_FilterInitStructure.CAN_FilterMode = CAN_FilterMode_IdMask; //工作在标识位屏蔽模式 //让报文标识符过滤器按照报文的内容进行对比过滤 拓展ID不符合就抛弃 //符合就存入FIFO0 CAN_FilterInitStructure.CAN_FilterScale = CAN_FilterScale_32bit; //过滤器位宽为单位32个 CAN_FilterInitStructure.CAN_FilterIdHigh = (((u32)0x1225<<3)&0xffff0000)>>16; //过滤的拓展ID的高16位 CAN_FilterInitStructure.CAN_FilterIdLow = ((u32)0x1225<<3)|CAN_ID_EXT|CAN_RTR_DATA&0XFFFF; //过滤的ID低16位 CAN_FilterInitStructure.CAN_FilterMaskIdHigh = 0xFFFF; //高16位每位进行匹配 CAN_FilterInitStructure.CAN_FilterMaskIdLow = 0xFFFF; //低16位每位进行匹配 CAN_FilterInitStructure.CAN_FilterFIFOAssignment = CAN_Filter_FIFO0; //过滤器关联到FIFO0 CAN_FilterInitStructure.CAN_FilterActivation = ENABLE; //过滤器使能 CAN_FilterInit(&CAN_FilterInitStructure); CAN_ITConfig(CAN1,CAN_IT_FMP0,ENABLE); //CAN通信中断使能 } /* 主机的通信报文设置 */ void CAN_SETMsg(void) { TxMessage.ExtId=0x1225; //报文的拓展ID设置 TxMessage.IDE = CAN_ID_EXT; //拓展模式 TxMessage.RTR = CAN_RTR_DATA; //发送的是数据 TxMessage.DLC = 2; //报文数据长度 TxMessage.Data[0] = 0xAB; //报文数据内容 TxMessage.Data[1] = 0xCD; } /* CAN的中断设置 */ void CAN_NVIC_Configriation(void) { NVIC_InitTypeDef NVIC_InitStructure; NVIC_PriorityGroupConfig(NVIC_PriorityGroup_1); //选择抢占优先级和响应优先级 NVIC_InitStructure.NVIC_IRQChannel = USB_LP_CAN1_RX0_IRQn; //CAN接收中断 NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0; //主优先级设置 NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0; //从优先级设置 NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; // 通道使能 NVIC_Init(&NVIC_InitStructure); } int main(void) { USART1_Configuration() ; //串口设置 GPIO_Configuration(); //CAN所需GPIO设置 CAN_Mode_Configriation(); //CAN模式参数设置 CAN_NVIC_Configriation(); //CAN中断设置 CAN_Filter_Configriation(); //CAN过滤器设置 printf("rn这是一个CAN通讯实验 采用回环测试rn") ; CAN_SETMsg(); //通信所需发送的报文设置 printf("rn发送的内容:rn") ; printf("rnID号ExtId:0x%x",TxMessage.ExtId) ; printf("rn数据段的内容:DATA[0]=0X%x,DATA[1]=0X%xrn",TxMessage.Data[0],TxMessage.Data[1]) ; CAN_Transmit(CAN1,&TxMessage); while(flag==0xff); //判断是否发送成功 printf("rn成功接受到数据!rn") ; printf("rn接受到的内容:rn") ; printf("rnID号ExtId:0x%x",RxMessage.ExtId) ; printf("rn数据段的内容:DATA[0]=0X%x,DATA[1]=0X%xrn",RxMessage.Data[0],RxMessage.Data[1]) ; while(1); } /* CAN接收中断函数 */ void USB_LP_CAN1_RX0_IRQHandler(void) { CAN_Receive(CAN1,CAN_FIFO0,&RxMessage); //将接收到的ID、数据等移入到RxMessage结构体中 if((RxMessage.ExtId==0x1225)&&(RxMessage.IDE==CAN_ID_EXT)&&(RxMessage.DLC==2)&&((RxMessage.Data[1]|RxMessage.Data[0]<<8)==0xABCD)) {flag=0; //判断是否接收到发送的数据信息 } else flag=0xff; } |
请问ad9910芯片的ram模式在接收数据时为什么会出现一段方波?
1822 浏览 1 评论
767 浏览 0 评论
不懂真得问!FREERTOS在中断里面,可以调用有任务级临界段代码的函数吗?
1763 浏览 1 评论
2000 浏览 1 评论
2174 浏览 1 评论
GMT+8, 2024-6-26 19:50 , Processed in 0.594025 second(s), Total 36, Slave 29 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
