#include "srcSTC12C5A.h" #include #include #include "srcDefine.h" ///////全局变量/////// uchar data Delaytime=9; //<=8效果最好; uchar data INTTime=0x40; //0x40; uchar data gain=6; uchar data Menu=2; uchar idata refreshflag[40]; uchar data LEDBuf[35]; //15列;从左到右;亮的位为真(1); uint32 data TouchKey=0; uchar data CBeep=0; ////////////////////// void Delays(uint t) { uint j; while(--t) for(j=0;j<5;j++); } void Delaysms(uint t) { uint j; while(--t) for(j=0;j<15;j++); } #include "srcADC.c" #include "srcFont.c" #include "srcfft.h" void PWM_init (void) //PWM初始化函数 //PWM模式,接P1.3接口(PWM0),强上拉. { CMOD=0x00; //设置PCA定时器 0x00~0x03; CL=0xEF; CH=0xEF; CCAPM0=0x42; //PWM0设置PCA工作方式为PWM方式(0100 0010) CCAP0L=0xEF; //设置PWM0初始值与CCAP0H相同 CCAP0H=0xFF; // PWM0初始时为0 CR=1; //启动PCA定时器 } void PWM0_set (uchar set) //PWM0占空比设置函数 (0x00~0xFF) { CCAP0L= set; //设置值写入CCAP0L CCAP0H= set; //设置值写入CCAP0H } void IOINIT(void) //I/O强上拉模式; { P4SW = 0xff; //启动I/O:P4; P4M1 = B(00000000); P4M0 = B(10000000);P47=0;//震动马达; P0M1 = 0x00; P0M0 = 0xff; P0=0; //点阵列(Y)(L:OFF; H,H+:ON,ON+;) P1M1 = B(01000011); P1M0 = B(00110100);P1=B(10110111); //(P17@(高阻,IN)&P16@(高阻,IN);TouchKey) ... P14@(传统IO,Beep,IN) P13@(强推,OUT)呼吸灯 ... P11@(高阻,IN)AD2;P10@(高阻,IN)AD1; P2M1 = B(00000000); P2M0 = B(11111111);P2=0; //点阵行(X0(Left))(L:OFF; H,H+:ON,ON+;) P3M1 = B(00000000); P3M0 = B(11111111);P3=0; //点阵行(X1(Right))(L:OFF; H,H+:ON,ON+;) P1ASF =B(00000011); //将P10,P11的IO设置为模拟输入功能; // Y(P0) // ↑ //H | // | // | //L | // ---------------------→ // [L:X0(P2):H][L:X1(P3):H] //TestCode: // P0=B(10000000); // P2=B(00000001); // P3=B(00010000); } void BufToLED_Refresh() //Refresh&Write Buf to LED ; { uchar data i; uchar data X=1; uchar data Y=1; for(X=1,i=2;X;X<<=1,i+=2) //for(X=1;X!=0;X<<=1) //8bit { P2=X; for(Y=1;Y!=0;Y<<=1) //Y=Y<<1; { P0=Y&LEDBuf; Delays(DelayTime); P0=0; } P2=0; }; for(X=1;X { P3=X; for(Y=1;Y!=0;Y<<=1) //Y=Y<<1; { P0=Y&LEDBuf; Delays(DelayTime); P0=0; } P3=0; }; } void LEDRefresh_INT() interrupt 3 //using 3 { static uint x=0; static uchar flag=1; TL1 = 0x00; TH1 = INTTime; //0x50~0x80 if(flag) { if(++x==0xFF) //MINOUTPUT { flag=0; } } else { if(--x==0xCF) //MAXOUTPUT { flag=1; } } PWM0_set(x); //设置PWM占空比 BufToLED_Refresh(); } void Timer_INT() { TMOD = 0x11; //高4位控制T/C1 EA = 1; //开总中断 TH1 = 0x00; //16位计数寄存器T1高8位 TL1 = 0x00; //16位计数寄存器T1低8位 ET1 = 1; //T/C1中断开 TR1 = 1; //T/C1启动 } void FullScan() { uchar data X=1; uchar data Y=1; for(Y=1;Y!=0;Y<<=1) //Y=Y<<1; { P0=Y; for(X=1;X;X<<=1) //8bit { P2=X; Delays(7); }; P2=0; for(X=1;X { P3=X; Delays(7); }; P3=0; P0=0; } } void Main() { uint data Count=700; uchar data i,Cgain,num=0; IOINIT(); InitADC(); while(--Count) FullScan(); for(i=0;i<40;i++) refreshflag=0x09; P14=0; //Beep Delays(4000); P14=1; PWM_init(); //PWM初始化 PWM0_set(0xFB); Timer_INT(); for(i=0;i<34;i++) LEDBuf=0x00; FontDisp(); while(520) { for(i=0;i<65;i++) { dd.real=(GetADCResult(0)+GetADCResult(1))< processfft();//傅立叶变化及处理 ///////////////////TouchKey////////////////////////// while(P16==1) //依据:脉冲 干扰持续时间短; { if(CBeep)P14=0; if(++TouchKey>0x0000FF00)break; } P14=1; if(P16==1) { if(++Menu==4)Menu=0; P14=0; P47=1; Delays(7000); P14=1; P47=0; } TouchKey=0; ////////////////////////////////////////////// if(P17==0)CBeep=!CBeep; if(dd[2].real<32) { if(++Count==300) //电平值过小,这降低gain,减少噪音的电平显示; { Count=0; //if(++Menu==4)Menu=0; //切换Menu,显示方式; gain=6; P14=0; //Beep Delays(1000); P14=1; } } else { Count=1; if(++num==0xAF) //播放时,Auto gain; { num=0; P14=0; //Beep Delays(700); P14=1; //自动增益;Automatic gain; Cgain=dd[2].real/32; if(7 gain=4; } else if(4 gain=5; } else if(2 gain=6; } else { gain=7; } } } } while(1); }
STM32F405驱动DS1302时钟模块,输出时间错乱该怎么排查?
2810 浏览 2 评论
stm32f405rgt6驱动DS1302ZN出现时间错乱问题
2420 浏览 1 评论
stm32用fsmc读取ad7606采集数据,数据不变,只有开发版复位才更新数据
2288 浏览 0 评论
2404 浏览 1 评论
1643 浏览 1 评论
/9
GMT+8, 2025-12-2 16:30 , Processed in 0.627552 second(s), Total 70, Slave 50 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
