#include
***it IR=P3^2;
***it RS=P2^1;
***it RW=P1^5;
***it E=P1^6;
#define DataPort P0 //定义数据端口 程序中遇到DataPort 则用P0 替换
#define Imax 14000 //此处为晶振为11.0592时的取值, #define Imin 8000 //如用其它频率的晶振时, #define Inum1 1450 //要改变相应的取值。 #define Inum2 700 #define Inum3 3000 ***it wela=P2^7;
char code Tab[16]="0123456789ABCDEF";
unsigned char f=0;
unsigned char Im[4]={0x00,0x00,0x00,0x00};
unsigned char show[2]={0,0};
unsigned long m,Tc;
unsigned char IrOK;
void delay(unsigned char x)
unsigned char a,b;
for(a=x;a>0;a--)
for(b=110;b>0;b--);
void time0() interrupt 1
TH0=0;
TL0=0;
void intersvr1(void) interrupt 0 using 1
Tc=TH0*256+TL0; //提取中断时间间隔时长
TH0=0;
TL0=0; //定时中断重新置零
if((Tc>Imin)&&(Tc
m=0;
f=1;
return;
} //找到启始码
if(f==1)
if(Tc>Inum1&&Tc
Im[m/8]=Im[m/8]>>1|0x80; m++;
if(Tc>Inum2&&Tc
Im[m/8]=Im[m/8]>>1; m++; //取码
if(m==32)
m=0;
f=0;
if(Im[2]==~Im[3])
IrOK=1;
else IrOK=0; //取码完成后判断读码是否正确
//准备读下一码
void Time0_ini()
TMOD=0x01;
TH0=0;
TL0=0;
ET0=1;
TR0=1;
void EX0_ini()
IT0=1;
EX0=1;
EA=1;
void write_com(unsigned char com)
RS=0;
delay(1);
E=1;
P0=com;
E=0;
void write_dat(unsigned char dat)
RS=1;
delay(1);
E=1;
P0=dat;
E=0;
void ini()
E=0;
RW=0;
write_com(0x38);
write_com(0x0c);//设置光标
write_com(0x06);
write_com(0x01);//清屏
write_com(0x80);
wela=1;
P0=0xff;
wela=0;
void Ir_work(void)//红外键值散转程序
write_com(0x80);
write_dat(Tab[Im[2]/16]);
write_dat(Tab[Im[2]%16]);
IrOK=0;
void main()
Time0_ini();
EX0_ini();
ini();
while(1)
if(IrOK)
Ir_work();
