扫一扫,分享给好友
各位大侠好 小弟今年刚毕业学习STM32 现在编程外部中断时无法进入中断函数 恳请大侠们帮小弟看看 小弟感激不尽!
PC6控制LED灯,高电平亮,低电平灭; PD13连接按键,外部中断,接有上拉,通过10K电阻接入3.3V, 程序无法进入中断,将PD13改为PD4,程序可以正常中断。 程序如下: 正常灯亮,按键后灯灭,但按键后灯还亮着 编程软件 MDK5.10 STM32F103VBT6 程序编译无错误 #include "stm32f10x_lib.h" EXti_InitTypeDef EXTI_InitStructure; ErrorStatus HSEStartUpStatus; void RCC_Configuration(void); void GPIO_Configuration(void); void NVIC_Configuration(void); void delay(u32 n); int main(void) { #ifdef DEBUG debug(); #endif RCC_Configuration(); NVIC_Configuration(); GPIO_Configuration(); GPIO_EXTILineConfig(GPIO_PortSourceGPIOD, GPIO_PinSource13); EXTI_InitStructure.EXTI_Line = EXTI_Line13; EXTI_InitStructure.EXTI_Mode = EXTI_Mode_Interrupt; EXTI_InitStructure.EXTI_Trigger = EXTI_Trigger_Falling; EXTI_InitStructure.EXTI_LineCmd = ENABLE; EXTI_Init(&EXTI_InitStructure); delay(0xffff); GPIO_SetBits(GPIOC, GPIO_Pin_6); delay(0xffff); EXTI_GenerateSWInterrupt(EXTI_Line13); while (1) { } } void RCC_Configuration(void) { RCC_DeInit(); RCC_HSEConfig(RCC_HSE_ON); HSEStartUpStatus = RCC_WaitForHSEStartUp(); if(HSEStartUpStatus == SUCCESS) { FLASH_PrefetchBufferCmd(FLASH_PrefetchBuffer_Enable); FLASH_SetLatency(FLASH_Latency_2); RCC_HCLKConfig(RCC_SYSCLK_Div1); RCC_PCLK2Config(RCC_HCLK_Div1); RCC_PCLK1Config(RCC_HCLK_Div2); RCC_PLLConfig(RCC_PLLSource_HSE_Div1, RCC_PLLMul_9); RCC_PLLCmd(ENABLE); while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET) { } RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK); while(RCC_GetSYSCLKSource() != 0x08) { } } RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD | RCC_APB2Periph_GPIOC | RCC_APB2Periph_AFIO, ENABLE); } void GPIO_Configuration(void) { GPIO_InitTypeDef GPIO_InitStructure; GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP; GPIO_Init(GPIOC, &GPIO_InitStructure); GPIO_InitStructure.GPIO_Pin = GPIO_Pin_13; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING; GPIO_Init(GPIOD, &GPIO_InitStructure); } void NVIC_Configuration(void) { NVIC_InitTypeDef NVIC_InitStructure; #ifdef VECT_TAB_RAM NVIC_SetVectorTable(NVIC_VectTab_RAM, 0x0); #else /* VECT_TAB_FLASH */ NVIC_SetVectorTable(NVIC_VectTab_FLASH, 0x0); #endif NVIC_PriorityGroupConfig(NVIC_PriorityGroup_1); NVIC_InitStructure.NVIC_IRQChannel = EXTI15_10_IRQChannel; NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0; NVIC_InitStructure.NVIC_IRQChannelSubPriority = 2; NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; NVIC_Init(&NVIC_InitStructure); } #ifdef DEBUG void assert_failed(u8* file, u32 line) { while (1) { } } #endif 中断程序 void EXTI15_10_IRQHandler(void) { delay(0xffff); if(EXTI_GetITStatus(EXTI_Line13) != RESET) { GPIO_ResetBits(GPIOC, GPIO_Pin_6); EXTI_ClearITPendingBit(EXTI_Line13); } } |
3个回答
各位大侠,问题已经解决,是固件库版本过低(V1.0)造成的,无法EXIT9_5中断,将固件库升级为V2.0后,EXIT9_5可以中断,谢谢大家关注!!
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
STM32F405驱动DS1302时钟模块,输出时间错乱该怎么排查?
2810 浏览 2 评论
stm32f405rgt6驱动DS1302ZN出现时间错乱问题
2420 浏览 1 评论
stm32用fsmc读取ad7606采集数据,数据不变,只有开发版复位才更新数据
2288 浏览 0 评论
2404 浏览 1 评论
1643 浏览 1 评论
/9
GMT+8, 2025-12-2 07:07 , Processed in 0.574011 second(s), Total 47, Slave 39 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
4971
