看了很多ARM裸机硬件程序,感觉bootloader还没搞懂,根据2440的原文件精简了一下,不知道有没有错误?
GET option.inc GET memcfg.inc GET 2440addr.inc ENTRY b reset reset: ;close watchdog ldr r0,=WTCON mov r1,0x0 str r1,[r0] ;disable interrupt ;ldr r0,=INTMSK ;ldr r1,=0x7fff ;str r1,[r0] ;ldr r0,=INTSUBMSK ;ldr r1,=0x7fff ;str r1,[r0] mrs r0,cpsr orr r0,r0,0xc0 msr cpsr,r0 ;Adjust the LOCKTIME register ldr r0,=LOCKTIME ldr r1,=0xffffff str r1,[r0] ;configure clock divide ldr r0,=CLKDIVN mov r1,0x5 str r1,[r0] ;If HDIVN is not 0, the CPU bus mode has to be changed from the fast bus mode to the asynchronous bus ;mode using following instructions. mrc p15,0,r0,c1,c0,0 orr r0,r0,#0xc0000000 mcr p15,0,r0,c1,c0,0 ;Configure UPLL ldr r0,=UPLLCON ldr r1,=((56<<12)+(2<<4)+2) str r1,[r0] nop ; Caution: After UPLL setting, at least 7-clocks delay must be inserted for setting hardware be completed. nop nop nop nop nop nop ;Configure MPLL ldr r0,=MPLLCON ldr r1,=((127<<12)+(2<<4)+1) ;Fin=12MHz str r1,[r0] ;Set SDRAM control registers ;ldr r0,=SMRDATA adrl r0, SMRDATA ;be careful! ldr r1,=BWSCON ;BWSCON Address add r2, r0, #52 ;End address of SMRDATA 0 ldr r3, [r0], #4 str r3, [r1], #4 cmp r2, r0 bne %B0 ;set the stack for C program mov sp,#0x33000000 bl CopyProgramFromNand bl Main SMRDATA DATA ; Memory configuration should be optimized for best performance ; The following parameter is not optimized. ; Memory access cycle parameter strategy ; 1) The memory settings is safe parameters even at HCLK=75Mhz. ; 2) SDRAM refresh period is for HCLK<=75Mhz. DCD (0+(B1_BWSCON<<4)+(B2_BWSCON<<8)+(B3_BWSCON<<12)+(B4_BWSCON<<16)+(B5_BWSCON<<20)+(B6_BWSCON<<24)+(B7_BWSCON<<28)) DCD ((B0_Tacs<<13)+(B0_Tcos<<11)+(B0_Tacc<<8)+(B0_Tcoh<<6)+(B0_Tah<<4)+(B0_Tacp<<2)+(B0_PMC)) ;GCS0 DCD ((B1_Tacs<<13)+(B1_Tcos<<11)+(B1_Tacc<<8)+(B1_Tcoh<<6)+(B1_Tah<<4)+(B1_Tacp<<2)+(B1_PMC)) ;GCS1 DCD ((B2_Tacs<<13)+(B2_Tcos<<11)+(B2_Tacc<<8)+(B2_Tcoh<<6)+(B2_Tah<<4)+(B2_Tacp<<2)+(B2_PMC)) ;GCS2 DCD ((B3_Tacs<<13)+(B3_Tcos<<11)+(B3_Tacc<<8)+(B3_Tcoh<<6)+(B3_Tah<<4)+(B3_Tacp<<2)+(B3_PMC)) ;GCS3 DCD ((B4_Tacs<<13)+(B4_Tcos<<11)+(B4_Tacc<<8)+(B4_Tcoh<<6)+(B4_Tah<<4)+(B4_Tacp<<2)+(B4_PMC)) ;GCS4 DCD ((B5_Tacs<<13)+(B5_Tcos<<11)+(B5_Tacc<<8)+(B5_Tcoh<<6)+(B5_Tah<<4)+(B5_Tacp<<2)+(B5_PMC)) ;GCS5 DCD ((B6_MT<<15)+(B6_Trcd<<2)+(B6_SCAN)) ;GCS6 DCD ((B7_MT<<15)+(B7_Trcd<<2)+(B7_SCAN)) ;GCS7 DCD ((REFEN<<23)+(TREFMD<<22)+(Trp<<20)+(Trc<<18)+(Tchr<<16)+REFCNT) DCD 0x32 ;SCLK power saving mode, BANKSIZE 128M/128M DCD 0x30 ;MRSR6 CL=3clk DCD 0x30 ;MRSR7 CL=3clk ALIGN END |
1个回答
好好学习天天向上
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
762 浏览 0 评论
739 浏览 0 评论
飞凌嵌入式ElfBoard-文件I/O的了解探究之复制文件描述符
668 浏览 0 评论
飞凌嵌入式ElfBoard-文件I/O的了解探究之返回错误处理与相关函数
1448 浏览 0 评论
飞凌嵌入式ElfBoard-文件I/O的了解探究之文件描述符和FILE指针转换
1058 浏览 0 评论
/9
GMT+8, 2025-12-1 19:56 , Processed in 0.827103 second(s), Total 75, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2422
