| #include "esp_common.h" #include "freertos/FreeRTOS.h" #include "freertos/task.h" #include "freertos/queue.h" #include "driver/uart.h" enum { UART_EVENT_RX_CHAR, UART_EVENT_MAX }; typedef struct _os_event_ { uint32 event; uint32 param; } os_event_t; xTaskHandle xUartTaskHandle; xQueueHandle xQueueUart; LOCAL STATUS uart_tx_one_char(uint8 uart, uint8 TxChar) { while (true) { uint32 fifo_cnt = READ_PERI_REG(UART_STATUS(uart)) & (UART_TXFIFO_CNT << UART_TXFIFO_CNT_S); if ((fifo_cnt >> UART_TXFIFO_CNT_S & UART_TXFIFO_CNT) < 126) { break; } } WRITE_PERI_REG(UART_FIFO(uart) , TxChar); return OK; } LOCAL void uart1_write_char(char c) { if (c == 'n') { uart_tx_one_char(UART1, 'r'); uart_tx_one_char(UART1, 'n'); } else if (c == 'r') { } else { uart_tx_one_char(UART1, c); } } LOCAL void uart0_write_char(char c) { if (c == 'n') { uart_tx_one_char(UART0, 'r'); uart_tx_one_char(UART0, 'n'); } else if (c == 'r') { } else { uart_tx_one_char(UART0, c); } } LOCAL void uart_rx_intr_handler_ssc(void) { /* uart0 and uart1 intr combine togther, when interrupt occur, see reg 0x3ff20020, bit2, bit0 represents * uart1 and uart0 respectively */ os_event_t e; portBASE_TYPE xHigherPriorityTaskWoken; uint8 RcvChar; uint8 uart_no = 0; if (UART_RXFIFO_FULL_INT_ST != (READ_PERI_REG(UART_INT_ST(uart_no)) & UART_RXFIFO_FULL_INT_ST)) { return; } RcvChar = READ_PERI_REG(UART_FIFO(uart_no)) & 0xFF; WRITE_PERI_REG(UART_INT_CLR(uart_no), UART_RXFIFO_FULL_INT_CLR); e.event = UART_EVENT_RX_CHAR; e.param = RcvChar; xQueueSendFromISR(xQueueUart, (void *)&e, &xHigherPriorityTaskWoken); portEND_SWITCHING_ISR(xHigherPriorityTaskWoken); } LOCAL void uart_task(void *pvParameters) { os_event_t e; for (;;) { if (xQueueReceive(xQueueUart, (void *)&e, (portTickType)portMAX_DELAY)) { switch (e.event) { case UART_EVENT_RX_CHAR: printf("%c", e.param); break; default: break; } } } vTaskDelete(NULL); } //================================================================= void UART_SetWordLength(UART_Port uart_no, UART_WordLength len) { SET_PERI_REG_BITS(UART_CONF0(uart_no), UART_BIT_NUM, len, UART_BIT_NUM_S); } void UART_SetStopBits(UART_Port uart_no, UART_StopBits bit_num) { SET_PERI_REG_BITS(UART_CONF0(uart_no), UART_STOP_BIT_NUM, bit_num, UART_STOP_BIT_NUM_S); } void UART_SetLineInverse(UART_Port uart_no, UART_LineLevelInverse inverse_mask) { CLEAR_PERI_REG_MASK(UART_CONF0(uart_no), UART_LINE_INV_MASK); SET_PERI_REG_MASK(UART_CONF0(uart_no), inverse_mask); } void UART_SetParity(UART_Port uart_no, UART_ParityMode Parity_mode) { CLEAR_PERI_REG_MASK(UART_CONF0(uart_no), UART_PARITY | UART_PARITY_EN); if (Parity_mode == USART_Parity_None) { } else { SET_PERI_REG_MASK(UART_CONF0(uart_no), Parity_mode | UART_PARITY_EN); } } void UART_SetBaudrate(UART_Port uart_no, uint32 baud_rate) { uart_div_modify(uart_no, UART_CLK_FREQ / baud_rate); } //only when USART_HardwareFlowControl_RTS is set , will the rx_thresh value be set. void UART_SetFlowCtrl(UART_Port uart_no, UART_HwFlowCtrl flow_ctrl, uint8 rx_thresh) { if (flow_ctrl & USART_HardwareFlowControl_RTS) { PIN_FUNC_SELECT(PERIPHS_IO_MUX_MTDO_U, FUNC_U0RTS); SET_PERI_REG_BITS(UART_CONF1(uart_no), UART_RX_FLOW_THRHD, rx_thresh, UART_RX_FLOW_THRHD_S); SET_PERI_REG_MASK(UART_CONF1(uart_no), UART_RX_FLOW_EN); } else { CLEAR_PERI_REG_MASK(UART_CONF1(uart_no), UART_RX_FLOW_EN); } if (flow_ctrl & USART_HardwareFlowControl_CTS) { PIN_FUNC_SELECT(PERIPHS_IO_MUX_MTCK_U, FUNC_UART0_CTS); SET_PERI_REG_MASK(UART_CONF0(uart_no), UART_TX_FLOW_EN); } else { CLEAR_PERI_REG_MASK(UART_CONF0(uart_no), UART_TX_FLOW_EN); } } void UART_WaitTxFifoEmpty(UART_Port uart_no) //do not use if tx flow control enabled { while (READ_PERI_REG(UART_STATUS(uart_no)) & (UART_TXFIFO_CNT << UART_TXFIFO_CNT_S)); } void UART_ResetFifo(UART_Port uart_no) { SET_PERI_REG_MASK(UART_CONF0(uart_no), UART_RXFIFO_RST | UART_TXFIFO_RST); CLEAR_PERI_REG_MASK(UART_CONF0(uart_no), UART_RXFIFO_RST | UART_TXFIFO_RST); } void UART_ClearIntrStatus(UART_Port uart_no, uint32 clr_mask) { WRITE_PERI_REG(UART_INT_CLR(uart_no), clr_mask); } void UART_SetIntrEna(UART_Port uart_no, uint32 ena_mask) { SET_PERI_REG_MASK(UART_INT_ENA(uart_no), ena_mask); } void UART_intr_handler_register(void *fn, void *arg) { _xt_isr_attach(ETS_UART_INUM, fn, arg); } void UART_SetPrintPort(UART_Port uart_no) { if (uart_no == 1) { os_install_putc1(uart1_write_char); } else { os_install_putc1(uart0_write_char); } } void UART_ParamConfig(UART_Port uart_no, UART_ConfigTypeDef *pUARTConfig) { if (uart_no == UART1) { PIN_FUNC_SELECT(PERIPHS_IO_MUX_GPIO2_U, FUNC_U1TXD_BK); } else { PIN_PULLUP_DIS(PERIPHS_IO_MUX_U0TXD_U); PIN_FUNC_SELECT(PERIPHS_IO_MUX_U0RXD_U, FUNC_U0RXD); PIN_FUNC_SELECT(PERIPHS_IO_MUX_U0TXD_U, FUNC_U0TXD); } UART_SetFlowCtrl(uart_no, pUARTConfig->flow_ctrl, pUARTConfig->UART_RxFlowThresh); UART_SetBaudrate(uart_no, pUARTConfig->baud_rate); WRITE_PERI_REG(UART_CONF0(uart_no), ((pUARTConfig->parity == USART_Parity_None) ? 0x0 : (UART_PARITY_EN | pUARTConfig->parity)) | (pUARTConfig->stop_bits << UART_STOP_BIT_NUM_S) | (pUARTConfig->data_bits << UART_BIT_NUM_S) | ((pUARTConfig->flow_ctrl & USART_HardwareFlowControl_CTS) ? UART_TX_FLOW_EN : 0x0) | pUARTConfig->UART_InverseMask); UART_ResetFifo(uart_no); } void UART_IntrConfig(UART_Port uart_no, UART_IntrConfTypeDef *pUARTIntrConf) { ...... } LOCAL void uart0_rx_intr_handler(void *para) { /* uart0 and uart1 intr combine togther, when interrupt occur, see reg 0x3ff20020, bit2, bit0 represents * uart1 and uart0 respectively */ uint8 RcvChar; uint8 uart_no = UART0;//UartDev.buff_uart_no; uint8 fifo_len = 0; uint8 buf_idx = 0; uint8 fifo_tmp[128] = {0}; uint32 uart_intr_status = READ_PERI_REG(UART_INT_ST(uart_no)) ; while (uart_intr_status != 0x0) { if (UART_FRM_ERR_INT_ST == (uart_intr_status & UART_FRM_ERR_INT_ST)) { //printf("FRM_ERRrn"); WRITE_PERI_REG(UART_INT_CLR(uart_no), UART_FRM_ERR_INT_CLR); } else if (UART_RXFIFO_FULL_INT_ST == (uart_intr_status & UART_RXFIFO_FULL_INT_ST)) { printf("fullrn"); fifo_len = (READ_PERI_REG(UART_STATUS(UART0)) >> UART_RXFIFO_CNT_S)&UART_RXFIFO_CNT; buf_idx = 0; while (buf_idx < fifo_len) { uart_tx_one_char(UART0, READ_PERI_REG(UART_FIFO(UART0)) & 0xFF); buf_idx++; } WRITE_PERI_REG(UART_INT_CLR(UART0), UART_RXFIFO_FULL_INT_CLR); } else if (UART_RXFIFO_TOUT_INT_ST == (uart_intr_status & UART_RXFIFO_TOUT_INT_ST)) { printf("toutrn"); fifo_len = (READ_PERI_REG(UART_STATUS(UART0)) >> UART_RXFIFO_CNT_S)&UART_RXFIFO_CNT; buf_idx = 0; while (buf_idx < fifo_len) { uart_tx_one_char(UART0, READ_PERI_REG(UART_FIFO(UART0)) & 0xFF); buf_idx++; } WRITE_PERI_REG(UART_INT_CLR(UART0), UART_RXFIFO_TOUT_INT_CLR); } else if (UART_TXFIFO_EMPTY_INT_ST == (uart_intr_status & UART_TXFIFO_EMPTY_INT_ST)) { printf("emptynr"); WRITE_PERI_REG(UART_INT_CLR(uart_no), UART_TXFIFO_EMPTY_INT_CLR); CLEAR_PERI_REG_MASK(UART_INT_ENA(UART0), UART_TXFIFO_EMPTY_INT_ENA); } else { //skip } uart_intr_status = READ_PERI_REG(UART_INT_ST(uart_no)) ; } } void uart_init_new(void) { UART_WaitTxFifoEmpty(UART0); UART_WaitTxFifoEmpty(UART1); UART_ConfigTypeDef uart_config; uart_config.baud_rate = BIT_RATE_74880; uart_config.data_bits = UART_WordLength_8b; uart_config.parity = USART_Parity_None; uart_config.stop_bits = USART_StopBits_1; uart_config.flow_ctrl = USART_HardwareFlowControl_None; uart_config.UART_RxFlowThresh = 120; uart_config.UART_InverseMask = UART_None_Inverse; UART_ParamConfig(UART0, &uart_config); UART_IntrConfTypeDef uart_intr; uart_intr.UART_IntrEnMask = UART_RXFIFO_TOUT_INT_ENA | UART_FRM_ERR_INT_ENA | UART_RXFIFO_FULL_INT_ENA | UART_TXFIFO_EMPTY_INT_ENA; uart_intr.UART_RX_FifoFullIntrThresh = 10; uart_intr.UART_RX_TimeOutIntrThresh = 2; uart_intr.UART_TX_FifoEmptyIntrThresh = 20; UART_IntrConfig(UART0, &uart_intr); UART_SetPrintPort(UART0); UART_intr_handler_register(uart0_rx_intr_handler,NULL); ETS_UART_INTR_ENABLE(); /* UART_SetWordLength(UART0,UART_WordLength_8b); UART_SetStopBits(UART0,USART_StopBits_1); UART_SetParity(UART0,USART_Parity_None); UART_SetBaudrate(UART0,74880); UART_SetFlowCtrl(UART0,USART_HardwareFlowControl_None,0); */ } |
