问题是利用串口通信输送0到9的数字显示在普中的点阵上(16*16)的,这过程我不知道代码哪里错了,在单片机总是仿真不出来,求大虾们帮帮忙谢谢!!!!
#include #include #define uchar unsigned char #define uint unsigned int unsigned char a,flag; ***it SCK=P3^6; ***it LCK=P3^5; ***it SDI=P3^4; void HC595_Send(uchar dat1,uchar dat0,uchar dat3,uchar dat2); //void delay(uchar z); uchar code NUM_HANG[]={0x80,0x00,0x40,0x00,0x20,0x00,0x10,0x00,0x08,0x00,0x04,0x00,0x02,0x00,0x01,0x00, 0x00,0x80,0x00,0x40,0x00,0x20,0x00,0x10,0x00,0x08,0x00,0x04,0x00,0x02,0x00,0x01,}; uchar code NUM[]={0x1F,0xFE,0x1F,0xFE,0x18,0x06,0x18,0x06,0x18,0x06,0x18,0x06,0x18,0x06,0x18,0x06, 0x18,0x06,0x18,0x06,0x18,0x06,0x18,0x06,0x1F,0xFE,0x1F,0xFE,0x00,0x00,0x00,0x00, 0x00,0x80,0x00,0x80,0x00,0x80,0x00,0x80,0x00,0x80,0x00,0x80,0x00,0x80,0x00,0x80, 0x00,0x80,0x00,0x80,0x00,0x80,0x00,0x80,0x00,0x80,0x00,0x80,0x00,0x80,0x00,0x80, 0x3F,0xFC,0x3F,0xFC,0x00,0x0C,0x00,0x0C,0x00,0x0C,0x00,0x0C,0x1F,0xFC,0x1F,0xFC, 0x18,0x00,0x18,0x00,0x18,0x00,0x18,0x00,0x18,0x00,0x1F,0xFC,0x1F,0xFC,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x3F,0x80,0x7B,0xC0,0x79,0xC0,0x79,0xC0,0x03,0xC0, 0x1F,0x00,0x03,0xC0,0x01,0xE0,0x01,0xE0,0x79,0xE0,0x79,0xE0,0x7B,0xC0,0x3F,0x80, 0x00,0x00,0x00,0x00,0x00,0x00,0x07,0x80,0x0F,0x80,0x0F,0x80,0x1F,0x80,0x3F,0x80, 0x3F,0x80,0x77,0x80,0x67,0x80,0xFF,0xE0,0x07,0x80,0x07,0x80,0x07,0x80,0x1F,0xC0, 0x00,0x00,0x00,0x00,0x00,0x00,0x7F,0xE0,0x70,0x00,0x70,0x00,0x70,0x00,0x70,0x00, 0x7F,0x80,0x7B,0xC0,0x01,0xE0,0x01,0xE0,0x79,0xE0,0x79,0xE0,0x7B,0xC0,0x3F,0x80, 0x00,0x00,0x00,0x00,0x00,0x00,0x1F,0xC0,0x3F,0xC0,0x7B,0xC0,0x70,0x00,0x70,0x00, 0xFF,0xC0,0xFD,0xE0,0xF9,0xE0,0xF0,0xE0,0x71,0xE0,0x79,0xE0,0x7D,0xC0,0x1F,0x80, 0x00,0x00,0x00,0x00,0x00,0x00,0x7F,0xC0,0x73,0xC0,0x73,0x80,0x07,0x80,0x07,0x00, 0x0F,0x00,0x0E,0x00,0x0E,0x00,0x1E,0x00,0x1E,0x00,0x1E,0x00,0x1E,0x00,0x1E,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x3F,0x80,0x7B,0xC0,0x71,0xE0,0x71,0xE0,0x79,0xC0, 0x3F,0xC0,0x3F,0x80,0x7B,0xC0,0xF1,0xE0,0xF1,0xE0,0xF1,0xE0,0x7B,0xC0,0x3F,0x80, 0x00,0x00,0x00,0x00,0x00,0x00,0x3F,0x80,0x7B,0xC0,0xF1,0xE0,0xF1,0xE0,0xF1,0xE0, 0xF1,0xE0,0x7B,0xE0,0x3F,0xE0,0x01,0xE0,0x01,0xC0,0x7B,0xC0,0x7F,0x80,0x3F,0x00, }; void mian() { int i,j; SCON=0x40; TMOD=0X20; PCON=0; TH1=0XE6; TL1=0XE6; TR1=1; REN=1; EA=1; ES=1; while(1) { if(flag==1) {flag=0;} if(a==0x48) { HC595_Send(0xff,0xff,0x00,0x00); for(j=255;j>0;j--) //一个字显示的次数,刷256次然后刷第二个字。 { for(i=0;i<32;i=i+2) //一共有16行,所以刷16次 { HC595_Send(~NUM[i],~NUM[i+1],NUM_HANG[i],NUM_HANG[i+1]); } } } if(a==0x49) { HC595_Send(0xff,0xff,0x00,0x00); for(j=255;j>0;j--) //一个字显示的次数,刷256次然后刷第二个字。 { for(i=0;i<32;i=i+2) //一共有16行,所以刷16次 { HC595_Send(~NUM[32+i],~NUM[32+i+1],NUM_HANG[i],NUM_HANG[i+1]); } } } if(a==0x50) { HC595_Send(0xff,0xff,0x00,0x00); for(j=255;j>0;j--) //一个字显示的次数,刷256次然后刷第二个字。 { for(i=0;i<32;i=i+2) //一共有16行,所以刷16次 { HC595_Send(~NUM[32+i],~NUM[32+i+1],NUM_HANG[i],NUM_HANG[i+1]); } } } if(a==0x51) { HC595_Send(0xff,0xff,0x00,0x00); for(j=255;j>0;j--) //一个字显示的次数,刷256次然后刷第二个字。 { for(i=0;i<32;i=i+2) //一共有16行,所以刷16次 { HC595_Send(~NUM[i],~NUM[i+1],NUM_HANG[i],NUM_HANG[i+1]); } } } if(a==0x52) { HC595_Send(0xff,0xff,0x00,0x00); for(j=255;j>0;j--) //一个字显示的次数,刷256次然后刷第二个字。 { for(i=0;i<32;i=i+2) //一共有16行,所以刷16次 { HC595_Send(~NUM[32+i],~NUM[32+i+1],NUM_HANG[i],NUM_HANG[i+1]); } } } if(a==0x53) { HC595_Send(0xff,0xff,0x00,0x00); for(j=255;j>0;j--) //一个字显示的次数,刷256次然后刷第二个字。 { for(i=0;i<32;i=i+2) //一共有16行,所以刷16次 { HC595_Send(~NUM[32+i],~NUM[32+i+1],NUM_HANG[i],NUM_HANG[i+1]); } } } if(a==0x54) { HC595_Send(0xff,0xff,0x00,0x00); for(j=255;j>0;j--) //一个字显示的次数,刷256次然后刷第二个字。 { for(i=0;i<32;i=i+2) //一共有16行,所以刷16次 { HC595_Send(~NUM[32+i],~NUM[32+i+1],NUM_HANG[i],NUM_HANG[i+1]); } } } if(a==0x55) { HC595_Send(0xff,0xff,0x00,0x00); for(j=255;j>0;j--) //一个字显示的次数,刷256次然后刷第二个字。 { for(i=0;i<32;i=i+2) //一共有16行,所以刷16次 { HC595_Send(~NUM[32+i],~NUM[32+i+1],NUM_HANG[i],NUM_HANG[i+1]); } } } if(a==0x56) { HC595_Send(0xff,0xff,0x00,0x00); for(j=255;j>0;j--) //一个字显示的次数,刷256次然后刷第二个字。 { for(i=0;i<32;i=i+2) //一共有16行,所以刷16次 { HC595_Send(~NUM[32+i],~NUM[32+i+1],NUM_HANG[i],NUM_HANG[i+1]); } } } if(a==0x57) { HC595_Send(0xff,0xff,0x00,0x00); for(j=255;j>0;j--) //一个字显示的次数,刷256次然后刷第二个字。 { for(i=0;i<32;i=i+2) //一共有16行,所以刷16次 { HC595_Send(~NUM[32+i],~NUM[32+i+1],NUM_HANG[i],NUM_HANG[i+1]); } } } } } /* void delay(uchar z) { uchar x,y; for(x=z;x>0;x--) for(y=110;y>0;y--); } */ void ser()interrupt 4 { while(!RI) RI=0; a=SBUF; flag=1; } void HC595_Send(uchar dat1,uchar dat0,uchar dat3,uchar dat2) { uchar i; SCK=1; LCK=1; for(i=0;i<8;i++) { SDI=dat0&0x01; //从高位到低位 dat0>>=1; SCK=0; _nop_(); _nop_(); SCK=1; _nop_(); _nop_(); } for(i=0;i<8;i++) { SDI=dat1&0x01; //从高位到低位 dat1>>=1; SCK=0; _nop_(); _nop_(); SCK=1; _nop_(); _nop_(); } for(i=0;i<8;i++) { SDI=dat2&0x01; //从高位到低位 dat2>>=1; SCK=0; _nop_(); _nop_(); SCK=1; _nop_(); _nop_(); } for(i=0;i<8;i++) { SDI=dat3&0x01; //从高位到低位 dat3>>=1; SCK=0; _nop_(); _nop_(); SCK=1; _nop_(); _nop_(); } LCK=0; //下面是输出时钟 _nop_(); _nop_(); LCK=1; _nop_(); _nop_(); } |
2个回答
好复杂.............。。。。。。。。。
已解决
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
LDO线性稳压器产生了模拟电源与数字电源,模拟电源去给运放供电,他们的地是不是同一个地?
1442 浏览 2 评论
1317 浏览 1 评论
1036 浏览 0 评论
2413 浏览 1 评论
ad把一个15mm*1.5mm的灯放到直径15mm的圆形pcb板上,可以实现吗
2173 浏览 1 评论
GMT+8, 2024-12-23 20:39 , Processed in 0.598438 second(s), Total 77, Slave 59 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
