扫一扫,分享给好友
#include ***it P2_2=P2^2; ***it signalBit=P2^1; //发送信号标志位 ***it LED=P3^7; //使能信号位,将E位定义为P2.2引脚 unsigned char irData[]={0x14,0xeb,0xf0,0x0f}; //存放所有的控制码 unsigned char mazhi[]={0x33,0x22,0xeb,0x14}; unsigned char key,send_flag=0; void SendIRdata(unsigned char irdata[4]); //红外发射函数 void anjian_send(unsigned char flag); void delay(unsigned int tt) //延时函数 { while(--tt); } void main(void) { signalBit=0; P2_2= 0; TMOD=0x12;//设定定时器1和0工作方式为1和2 EX1=1; IT1=1; ET0 =1; //定时器0中断允许 ET1 =1; TH0= 0xf4; TL0= 0xf4; //设定时值0为38K 也就是每隔13us中断一次 周期为26us TR0= 0;//先关闭定时器 0 TR1= 0; IP=0X01; EA=1; //允许CPU中断 LED=0; while(1) { P1=0XF0; if(send_flag==1) { anjian_send(key); send_flag=0; } } } void anjian_send(unsigned char flag) { unsigned char zhi=flag; switch(zhi) { case 0xee: SendIRdata(irData); break; case 0xbe: SendIRdata(irData); break; case 0xde: SendIRdata(irData); break; case 0x7e: SendIRdata(irData); break; case 0xed: SendIRdata(irData); break; case 0xdd: SendIRdata(irData); break; case 0xbd: SendIRdata(irData); break; case 0x7d: SendIRdata(irData); break; case 0xeb: SendIRdata(irData); break; case 0xdb: SendIRdata(irData); break; case 0xbb: SendIRdata(mazhi); break; case 0x7b: SendIRdata(mazhi); break; case 0xe7: SendIRdata(mazhi); break; case 0xd7: SendIRdata(mazhi); break; case 0xb7: SendIRdata(mazhi); break; case 0x77: SendIRdata(mazhi); break; } } /******* 定时器1中断处理 ***********/ void isr_T1(void) interrupt 3 { } /******* 定时器0中断处理 38K载波发生器***********/ void timeint(void) interrupt 1 { P2_2=~P2_2; //产生38k的载波信号 } /**************** 中断1 键盘的扫描 ********************/ void Int1(void) interrupt 2 { unsigned char l,h; P1=0XF0; l=P1; l=l&0xf0; if(l!=0xf0) { delay(10); if(l!=0xf0) { l=P1&0xf0; l=l|0x0f; P1=l; h=P1; h=h&0x0f; l=l&0xf0; key=h+l; send_flag=1; LED=~LED; } } } /********* 红外发射函数 ************/ void SendIRdata(unsigned char *mData) { unsigned char i,j; unsigned char test[4]; for(i=0;i<4;i++) test=mData; TR0=1; //开定时器T0 输出38K载波 /********* 发送9ms的高电平 ************/ TH1=0XDF; //装入初值设置波延时为9ms TL1=0XE3; TR1=1; //启动T1工作 定时所需时间 signalBit=1; //发送信号 while(!TF1); TF1=0; /********* 发送4.5ms的低电平 *************/ TH1=0xef; TL1=0xf0; signalBit=0; while(!TF1); TF1=0; /********* 发送 用户码 控制码 控制反码 ***********/ for(j=0;j<4;j++) //发送十六位地址的前八位 { for(i=0;i<8;i++) { //先发送0.565ms的38KHZ红外波(即编码中0.565ms的高电平) TH1=0XFE; TL1=0X70; signalBit=1; while(!TF1); TF1=0; //停止发送红外信号(即编码中的高电平) if(test[j]&0x01) //判断二进制数个位为1还是0 { TH1=0XFA; // //1为宽的低电平,持续时间1.685ms TL1=0X30; } else { TH1=0XFE; //0为窄的低电平,持续时间 0.56ms TL1=0x50; } signalBit=0; while(!TF1); TF1=0; test[j]=test[j]>>1; } } TR1=0; //发送停止位 关闭定时器T0 signalBit=1; delay(100); signalBit=0; TR0=0; //关闭定时器T1 }
1个回答
你这个暗亮实现不了,led的电路没搭建呢。我知道实物电路可以,但是仿真要求比较严格。
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
4878 浏览 0 评论
6008 浏览 0 评论
PROTUES仿真no model specified for adc0809,谁有ADC0809的model?
18244 浏览 1 评论
单片机应用技术的ISIS professional电路设置仿真老是报错怎么办
18469 浏览 0 评论
21842 浏览 3 评论
/9
GMT+8, 2025-12-13 22:08 , Processed in 0.436268 second(s), Total 40, Slave 32 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
4644
