扫一扫,分享给好友
代码 如下 在高电平计数到86ms以上时就会出现很大的误差 仿真也没问题 是什么原因呢?
module dutycycle( clk , rst_n , clk_400M , signal , en_d , flag_d , dout ); //输入信号定义 input clk ; input rst_n ; input clk_400M ; input signal ; input en_d ; //输出信号定义 output[31:0] dout ; output flag_d ; //输出信号reg定义 reg [31:0] dout ; reg flag_d ; reg [31:0] time_h ; reg [31:0] time_a ; //中间信号定义 reg signal_ff0; reg signal_ff1; reg signal_ff2; reg [31:0] time_h_buf; reg [31:0] time_a_buf; reg [2:0] state ; wire jump_p1 ; wire jump_p2 ; wire jump_n ; assign jump_p1 = signal_ff0 && ~signal_ff1; //第一个上升沿 assign jump_p2 = signal_ff1 && ~signal_ff2; //第二个上升沿 assign jump_n = ~signal_ff0 && signal_ff1; //第一个下降沿 always@(posedge clk_400M or negedge rst_n)begin if(rst_n==1'b0)begin signal_ff0 <= 0; signal_ff1 <= 0; signal_ff2 <= 0; end else begin signal_ff0 <= signal; signal_ff1 <= signal_ff0; signal_ff2 <= signal_ff1; end end //占空比测量 always @(posedge clk_400M or negedge rst_n)begin if(rst_n==1'b0)begin state <= 0; end else if(jump_p1&&state==0&&en_d)begin state <= 1; end else if(jump_n&&state==1)begin state <= 2; end else if(jump_p2&&state==2)begin state <= 3; end else if(state==3)begin state <= 4; end else if (state==4)begin state <= 0; end end always @(posedge clk_400M or negedge rst_n)begin if(rst_n==1'b0)begin dout <= 32'd0; flag_d <= 0; time_h <= 32'd0; time_a <= 32'd0; time_h_buf <= 32'd0; time_a_buf <= 32'd0; end else begin case(state) 3'd1:begin time_h_buf <= time_h_buf + 1'b1; time_a_buf <= time_a_buf + 1'b1; end 3'd2:begin time_h_buf <= time_h_buf; time_a_buf <= time_a_buf + 1'b1; end 3'd3:begin time_h <= time_h_buf; time_a <= time_a_buf; end 3'd4:begin dout <= 1+1000* time_h/time_a; flag_d <= 1'd1; end default:begin dout <= 32'd0; flag_d <= 0; //time_h <= 32'd0; //time_a <= 32'd0; time_h_buf <= 32'd0; time_a_buf <= 32'd0; end endcase end end endmodule |
6个回答
好像这里有问题,400M时钟在86mS里计数0x20ce700,乘1000之后=0x8 0266 5800,超过了32位吧?是不是溢出了? 另外,好像极限测量时间不是86mS,好像超过10.7mS乘法就溢出了,但是编译时可能结合了除法的优化,使得实际的测量乘法的上限到达了0x7 ffff ffff。请改一里再试验一下,祝好运!
最佳答案
先把乘1000改成乘100试验一下,如果上限变了,基本就确定是溢出了。
现在的问题是我把1000放在最后面乘的话数据是0 这该怎么改呢?
"1000放在最后面乘的话数据是0"是因为先算了除法,这个除法是整数除法,没小数部分,所以结果得0.
可能有两个办法可以解决: 1、因为乘1000改小一些可以提高上限,所以可以用分段的方法,对不同测量区间乘以不同的系数。 2、为了不损失精度,需要提高time_a 和time_h 的位数,不知您的编译器是否直接支持64位乘除?如果不支持,就得分解成为多次32位乘除法。会比较麻烦。 如果换成浮点运算,只是理论上可行,但是我没用逻辑做过。FPGA中用CPU软核来计算这个64位乘除法,或浮点乘除法是可行的。 |
jiaojiex 发表于 2016-5-20 23:42 谢谢你为我解决了这个问题 |
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
1307 浏览 1 评论
助力AIoT应用:在米尔FPGA开发板上实现Tiny YOLO V4
1038 浏览 0 评论
2382 浏览 1 评论
2087 浏览 0 评论
矩阵4x4个按键,如何把识别结果按编号01-16(十进制)显示在两个七段数码管上?
2349 浏览 0 评论
1864 浏览 49 评论
6006 浏览 113 评论
GMT+8, 2024-12-21 11:59 , Processed in 0.570041 second(s), Total 80, Slave 64 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
