电子发烧友论坛扫一扫,分享给好友
在通过参数转换函数得到CAN总线传输到的数值,想把不停刷新的数值显示在12864上,程序中有按键函数,实现12864两页的切换,这两页中都有数值接收显示,但是我每次主函数进入按键函数切换12864的界面时,数据就不能实时更新,因为显示函数在按键函数里。求大神解决方法。程序如下:
#include "userdefines.h" //#include "can.h" _FBS(BWRP_WRPROTECT_OFF & BSS_NO_FLASH & RBS_NO_RAM); //f80000 _FSS(SWRP_WRPROTECT_OFF & SSS_NO_FLASH & RSS_NO_RAM); //f80002 _FGS(GCP_OFF & GWRP_OFF & GSS_OFF); //f80004 _FOSCSEL(FNOSC_PRIPLL & IESO_ON); //f80006 _FOSC(POSCMD_XT& OSCIOFNC_OFF & IOL1WAY_OFF & FCKSM_CSECMD); //f80008 _FWDT(WDTPOST_PS32768 & WDTPRE_PR128 & WINDIS_OFF & FWDTEN_OFF); //f8000a _FPOR(FPWRT_PWR128 & ALti2C_OFF & LPOL_OFF & HPOL_OFF & PWMPIN_ON); //f8000c _FICD( ICS_PGD3 & JTAGEN_OFF); //f8000e #define E PORTBbits.RB13 #define RW PORTAbits.RA10 #define RS PORTAbits.RA7 #define RST PORTBbits.RB8 #define Key_enter PORTAbits.RA0 #define Key_mode PORTAbits.RA1 #define Key_down PORTBbits.RB0 #define Key_up PORTBbits.RB1 #define Key_blank PORTBbits.RB15 #define ON_OFF PORTBbits.RC0 #define Normal PORTBbits.RB3 #define Error PORTBbits.RB2 #define STB LATBbits.LATB4 #define uchar unsigned char #define uint unsigned int #define D0 PORTBbits.RB12 #define D1 PORTBbits.RB11 #define D2 PORTBbits.RB10 #define D3 PORTCbits.RC9 #define D4 PORTCbits.RC8 #define D5 PORTCbits.RC7 #define D6 PORTCbits.RC6 #define D7 PORTBbits.RB9 uchar kaiji1[]=("欢迎来到"); uchar kaiji2[]=("机电学院"); uchar canshu1[]=("设定转速0 0 0 0"); uchar canshu2[]=("当前转速: "); uchar canshu3[]=("设置功率0 0 . 0"); uchar canshu4[]=("母线电压: V"); uchar canshu5[]=("母线电流: A"); uchar canshu6[]=(" 相电流: A"); #define ATC_CAN_ID 0X34C #define ACP_CAN_ID 0X4A0 #define HCU_CAN_ID 0X4A2 #define BC1_CAN_ID 0X5B3 #define BC2_CAN_ID 0X533 #define ECAN_MSG_BUF_LENGTH 4 #define FCAN 40000000 // FCAN = Fcy = 40MHz #define BITRATE 500000 // Baude Rate = 500kHz #define NTQ 20 // 20 Time Quanta in a Bit Time #define CAN_BRP_VAL ((FCAN/(2*NTQ*BITRATE))-1) // 40MHz/(500kHz*2)]-1 = 39 BRP_VAL should be 0~63 void can_init(void); void ecanClkInit(void); void ecanWriteRxAcptFilter(int n, long identifier, unsigned int exide, unsigned int bufPnt,unsigned int maskSel); void ecanWriteRxAcptMask(int m, long identifier, unsigned int mide, unsigned int exide); void dma0init(void); void dma2init(void); void ecanWriteTxMsgBufId(unsigned int buf, long txIdentifier, unsigned int ide, unsigned int remoteTransmit); void ecanWriteTxMsgBufData(unsigned int buf, unsigned int dataLength, unsigned int data1, unsigned int data2, unsigned int data3, unsigned int data4); void ecanWriteMessage(unsigned int data1,unsigned int data2,unsigned int data3,unsigned int data4); void C1_P(void); unsigned int can_msgBuf[ECAN_MSG_BUF_LENGTH][8] __attribute__((space(dma),aligned(ECAN_MSG_BUF_LENGTH*16))); unsigned int can_msgBuf_r[ECAN_MSG_BUF_LENGTH][8] __attribute__((space(dma),aligned(ECAN_MSG_BUF_LENGTH*16))); unsigned int ACP_10=0; unsigned int ACP_11=0; unsigned int ACP_12=0; unsigned int ACP_13=0; unsigned int ACP_14=0; unsigned int ACP_15=0; unsigned int ACPSpdFeedback=0; unsigned int ACPDCCurrent=0; unsigned int ACPDCVoltage=0; unsigned char result1[4]={0,0,0,0}; unsigned char result2[2]={0,0}; uchar Key_num1; uchar Key_num; void System_Colck(void); void configio(void); void lcd_init(void); void chk_busy(); void write_cmd(unsigned char c); void write_data(unsigned char c); void get_canshu1(void); void get_canshu2(unsigned int ACPDC); void display(void); void display1(void); void display2(void); void yidong(void); void scan_key(); void main () { System_Colck(); configio(); can_init(); lcd_init(); delay_ms (100);//延迟8ms display(); delay_s(3000); write_cmd(0x01); delay_ms (100);//延迟8ms display1(); while(1) { //display1(); get_canshu1(); get_canshu2(ACPDCVoltage); get_canshu2(ACPDCCurrent); scan_key(); } } void LED_DAT (uchar d) { D0=d&0x01; D1=(d&0x02)>>1; D2=(d&0x04)>>2; D3=(d&0x08)>>3; D4=(d&0x10)>>4; D5=(d&0x20)>>5; D6=(d&0x40)>>6; D7=(d&0x80)>>7; } void System_Colck(void) { //Fosc = 80MHz 40MIPS CLKDIVbits.PLLPRE = 0;//N1 = 2 7.3728MHz/2= 3.6864MHz PLLFBDbits.PLLDIV = 38;//M = 40 3.6864*43 = 158.5152MHz CLKDIVbits.PLLPOST = 0;//N2 = 2 158.5152/2 = 79.2576MHz } /*------------------------------------------------ 缁崵绮洪柊宥囩枂閸戣姤鏆? ------------------------------------------------*/ void configio(void) { TRISA= 0x0003;//RA0,RA1娑撻缚绶崗銉礉閸忔湹缍戞稉楦跨翻閸? TRISB= 0x8003;//RB0,RB1,RB15娑撻缚绶崗銉礉閸忔湹缍戞稉楦跨翻閸? TRISC= 0x0003;//RC0娑撻缚绶崗銉礉閸忔湹缍戞稉楦跨翻閸? TRISBbits.TRISB8 = 0;//RB8 TRISBbits.TRISB9 = 0;//RB9 TRISBbits.TRISB10 = 0;//RB10 TRISBbits.TRISB11 = 0;//RB11 TRISBbits.TRISB12 = 0;//RB12 TRISBbits.TRISB13 = 0;//RA13 TRISCbits.TRISC6 = 0;//RC6 TRISCbits.TRISC7 = 0;//RC7 TRISCbits.TRISC8 = 0;//RC8 TRISCbits.TRISC9 = 0;//RC9 _TRISB4 = 0 ; AD1PCFGL=0x01ff; RPINR26bits.C1RXR = 17; // RP17 used for U1RX RPOR9bits.RP18R = 16; // RP18 used for U1TX _TRISC2 = 0 ; //C1TX _TRISC1 = 1 ; //C1RX STB=1; } void lcd_init(void) { RST=0; //复位 delay_ms(850); //延时70ms RST=1; //复位置高 delay_ms(120); //延时10ms write_cmd(0x34); //选择基本指令集 delay_us(2500); //延时166us write_cmd(0x34); delay_us(1000); //延时66us write_cmd(0x30); delay_us(1000); write_cmd(0x0c); //开显示,有游标,游标位置允许反白 delay_us(2500); write_cmd(0x01); //清除显示,并设定地址指针为00H delay_ms(250); //延迟20ms write_cmd(0x06); //指定在数据的读取与写入时,设定游标从右向左加1移动 delay_us(3000); //延时200us } /*------------------------------------------------ 测忙函数 ------------------------------------------------*/ void chk_busy() { TRISB = 0x9e03; //RB9,10,11,12设置为输入 TRISC = 0x3c03; //RC6,7,8设置为输入 E = 0; //使能无效 RS = 0; //指令方式 RW = 1; //读操作 delay_us(800); //延时50us while(D7) { delay_us(800); //延时50us E=1; delay_us(800); //延时50us E=0; } E=0; TRISB = 0x8003; //RB9,10,11,12还原为输出 TRISC = 0x0003; //RC6,7,8还原为输出 } /*------------------------------------------------ 写指令函数 ------------------------------------------------*/ void write_cmd(unsigned char c) { chk_busy(); RS=0; RW=0; delay_us(800);//延时50us E=1; delay_us(800);//延时50us LED_DAT (c); delay_us(8000);//延时500us E=0; delay_us(1500);//延时500us } /*------------------------------------------------ 写数据函数 ------------------------------------------------*/ void write_data(unsigned char c) { chk_busy(); RS=1; RW=0; delay_us(800);//延时50us E=1; delay_us(800);//延时50us LED_DAT (c); delay_us(8000);//延时500us E=0; delay_us(1500);//延时500us } /*------------------------------------------------ CAN总线输入数据转换函数 ------------------------------------------------*/ void get_canshu1(void) { result1[0]=((ACPSpdFeedback/2)/1000)+0x30; //整数千位 result1[1]=(((ACPSpdFeedback/2)%1000)/100)+0x30; //整数百位 result1[2]=(((ACPSpdFeedback/2)%100)/10)+0x30; //整数十位 result1[3]=((ACPSpdFeedback/2)%10)+0x30; //整数个位 } void get_canshu2(unsigned int ACPDC) { result2[0]=((ACPDC/2)/10)+0x30; //整数十位 result2[1]=((ACPDC/2)%10)+0x30; //整数个位 } /*------------------------------------------------ 显示函数 ------------------------------------------------*/ void display(void) { uchar i; write_cmd(0x81); for(i=0;i<14;i++) { write_data(kaiji1); delay_ms(100);//延时8ms }; write_cmd(0x8A); for(i=0;i<12;i++) { write_data(kaiji2); delay_ms(100);//延时8ms } } void display1(void) { uchar i; write_cmd(0x80); for(i=0;i<16;i++) { write_data(canshu1); delay_ms(100);//延时8ms }; write_cmd(0x90); for(i=0;i<16;i++) { write_data(canshu2); delay_ms(100); } write_cmd(0x95); for(i=0;i<4;i++) { write_data(result1); delay_ms(100);//延时8ms } write_cmd(0x88); for(i=0;i<15;i++) { write_data(canshu3); delay_ms(100);//延时8ms } write_cmd(0x98); for(i=0;i<14;i++) { write_data(canshu4); delay_ms(100);//延时8ms } write_cmd(0x9D); for(i=0;i<2;i++) { write_data(result2); delay_ms(100);//延时8ms } write_cmd(0x80+4 ); write_cmd(0x0D); } void display2(void) { uchar i; write_cmd(0x80); for(i=0;i<14;i++) { write_data(canshu5); delay_ms(100);//延时8ms } write_cmd(0x85); for(i=0;i<2;i++) { write_data(result2); delay_ms(100);//延时8ms } write_cmd(0x90); for(i=0;i<14;i++) { write_data(canshu6); delay_ms(100);//延时8ms } } /*------------------------------------------------ 按键功能函数 ------------------------------------------------*/ void scan_key() { if(Key_blank==0) //按键换页 { delay_ms(250); if(Key_blank==0) { while(!Key_blank); Key_num++; if(Key_num%2==0) { write_cmd(0x01); delay_us(800); display1(); delay_us(800); } if(Key_num%2==1) { write_cmd(0x01); delay_us(800); display2(); write_cmd(0x0C); delay_us(800); } } } if(Key_mode==0) //按键光标移动 { delay_ms(15); if(Key_mode==0) { while(!Key_mode); Key_num1++; switch(Key_num1) { case 0:write_cmd(0x84);break; case 1:write_cmd(0x85);break; case 2:write_cmd(0x86);break; case 3:write_cmd(0x8C);break; case 4:write_cmd(0x8D);break; case 5:write_cmd(0x8F);break; case 6:Key_num1=0;write_cmd(0x84);break; default:break; } } } if(Key_up==0) //按键加 { write_cmd(0x0c); delay_ms(15); if(Key_up==0) { while(!Key_up); //Key_num1++; switch(Key_num1) { case 0: canshu1[8]++; if(canshu1[8]==':') // canshu1[8]=='9'; canshu1[8]='0'; write_data(canshu1[8]); delay_us(800); write_cmd(0x84);break; case 1: canshu1[10]++; if(canshu1[10]==':') canshu1[10]='0'; write_data(canshu1[10]); delay_us(800); write_cmd(0x85);break; case 2: canshu1[12]++; if(canshu1[12]==':') canshu1[12]='0'; write_data(canshu1[12]); delay_us(800); write_cmd(0x86);break; case 3: canshu3[8]++; if(canshu3[8]==':') canshu3[8]='0'; write_data(canshu3[8]); delay_us(800); write_cmd(0x8C);break; case 4: canshu3[10]++; if(canshu1[10]==':') canshu1[10]='0'; write_data(canshu3[10]); delay_us(800); write_cmd(0x8D);break; case 5: canshu3[14]++; if(canshu3[14]==':') canshu3[14]='0'; write_data(canshu3[14]); delay_us(800); write_cmd(0x8F);break; case 6:Key_num1=0;write_cmd(0x84);break; default:break; } write_cmd(0x0d); } } if(Key_down==0) //按键减 { write_cmd(0x0c); delay_ms(15); if(Key_down==0) { while(!Key_down); //Key_num1++; switch(Key_num1) { case 0: canshu1[8]--; if(canshu1[8]=='/') canshu1[8]='9'; write_data(canshu1[8]); delay_us(800); write_cmd(0x84);break; case 1: canshu1[10]--; if(canshu1[10]=='/') canshu1[10]='9'; write_data(canshu1[10]); delay_us(800); write_cmd(0x85);break; case 2: canshu1[12]--; if(canshu1[12]=='/') canshu1[12]='9'; write_data(canshu1[12]); delay_us(800); write_cmd(0x86);break; case 3: canshu3[8]--; if(canshu3[8]=='/') canshu3[8]='9'; write_data(canshu3[8]); delay_us(800); write_cmd(0x8C);break; case 4: canshu3[10]--; if(canshu1[10]=='/') canshu1[10]='9'; write_data(canshu3[10]); delay_us(800); write_cmd(0x8D);break; case 5: canshu3[14]--; if(canshu3[14]=='/') canshu3[14]='9'; write_data(canshu3[14]); delay_us(800); write_cmd(0x8F);break; case 6:Key_num1=0;write_cmd(0x84);break; default:break; } write_cmd(0x0d); } } } /*------------------------------------------------ CAN功能 ------------------------------------------------*/ void can_init(void) { /* Request Configuration Mode */ C1CTRL1bits.REQOP=4; while(C1CTRL1bits.OPMODE!=4); ecanClkInit(); C1FCTRLbits.DMABS=0; /* 4 CAN Message Buffers in DMA RAM */ ecanWriteRxAcptFilter(0,ACP_CAN_ID,0,0,0); //Filter0,SID=34C ecanWriteRxAcptFilter(1,ACP_CAN_ID,0,1,0); //Filter1,SID= // ecanWriteRxAcptFilter(2,HCU2_CAN_ID,0,2,0); //Filter0,SID= // ecanWriteRxAcptFilter(3,HCU3_CAN_ID,0,3,0); //Filter1,SID= ecanWriteRxAcptMask(1,0x0,1,0);// Mask1,SID = 203 /* Enter Normal Mode */ C1CTRL1bits.REQOP=0; // 0---Normal Mode,2---Loopback Mode while(C1CTRL1bits.OPMODE!=0); /* ECAN transmit/receive message control */ C1RXFUL1=C1RXFUL2=C1RXOVF1=C1RXOVF2=0x0000; C1TR01CONbits.TXEN0=1; /* ECAN1, Buffer 0 is a Transmit Buffer */ C1TR01CONbits.TXEN1=0; /* ECAN1, Buffer 1 is a Receive Buffer */ C1TR01CONbits.TX0PRI=0b11; /* Message Buffer 0 Priority Level */ C1TR01CONbits.TX1PRI=0b11; /* Message Buffer 1 Priority Level */ dma0init(); dma2init(); IPC8bits.C1IP=2; IEC2bits.C1IE = 1; C1INTEbits.TBIE = 1; C1INTEbits.RBIE = 1; } void ecanClkInit(void) { C1CTRL1bits.CANCKS = 0x1; //FCAN is selected to be FCY = 40MHz C1CFG1bits.SJW = 0x3; //Synchronization Jump Width set to 4 TQ C1CFG2bits.SEG1PH=0x7; //Phase Segment 1 time is 8 TQ C1CFG2bits.SEG2PHTS = 0x1; //Phase Segment 2 time is set to be programmable C1CFG2bits.SEG2PH = 0x5; //Phase Segment 2 time is 6 TQ C1CFG2bits.PRSEG = 0x4; //Propagation Segment time is 5 TQ C1CFG2bits.SAM = 0x1; //Bus line is sampled three times at the sample point C1CFG1bits.BRP = CAN_BRP_VAL; //Baud Rate Prescaler } void ecanWriteRxAcptFilter(int n, long identifier, unsigned int exide, unsigned int bufPnt,unsigned int maskSel) { unsigned long sid10_0=0, eid15_0=0, eid17_16=0; unsigned int *sidRegAddr,*bufPntRegAddr,*maskSelRegAddr, *fltEnRegAddr; C1CTRL1bits.WIN=1; // Obtain the Address of CiRXFnSID, CiBUFPNTn, CiFMSKSELn and CiFEN register for a given filter number "n" sidRegAddr = (unsigned int *)(&C1RXF0SID + (n << 1)); bufPntRegAddr = (unsigned int *)(&C1BUFPNT1 + (n >> 2)); maskSelRegAddr = (unsigned int *)(&C1FMSKSEL1 + (n >> 3)); fltEnRegAddr = (unsigned int *)(&C1FEN1); if(exide==1) { // Filter Extended Identifier eid15_0 = (identifier & 0xFFFF); eid17_16= (identifier>>16) & 0x3; sid10_0 = (identifier>>18) & 0x7FF; *sidRegAddr=(((sid10_0)<<5) + 0x8) + eid17_16; // Write to CiRXFnSID Register *(sidRegAddr+1)= eid15_0; // Write to CiRXFnEID Register } else { // Filter Standard Identifier sid10_0 = (identifier & 0x7FF); *sidRegAddr=(sid10_0)<<5; // Write to CiRXFnSID Register *(sidRegAddr+1)=0; // Write to CiRXFnEID Register } *bufPntRegAddr = (*bufPntRegAddr) & (0xFFFF - (0xF << (4 *(n & 3)))); // clear nibble *bufPntRegAddr = ((bufPnt << (4 *(n & 3))) | (*bufPntRegAddr)); // Write to C1BUFPNTn Register *maskSelRegAddr = (*maskSelRegAddr) & (0xFFFF - (0x3 << ((n & 7) * 2))); // clear 2 bits *maskSelRegAddr = ((maskSel << (2 * (n & 7))) | (*maskSelRegAddr)); // Write to C1FMSKSELn Register *fltEnRegAddr = ((0x1 << n) | (*fltEnRegAddr)); // Write to C1FEN1 Register C1CTRL1bits.WIN=0; } void ecanWriteRxAcptMask(int m, long identifier, unsigned int mide, unsigned int exide) { unsigned long sid10_0=0, eid15_0=0, eid17_16=0; unsigned int *maskRegAddr; C1CTRL1bits.WIN=1; maskRegAddr = (unsigned int *)(&C1RXM0SID + (m << 1)); // Bit-filed manupulation to write to Filter Mask register if(exide==1) { // Filter Extended Identifier eid15_0 = (identifier & 0xFFFF); eid17_16= (identifier>>16) & 0x3; sid10_0 = (identifier>>18) & 0x7FF; if(mide==1) *maskRegAddr=((sid10_0)<<5) + 0x0008 + eid17_16;// Write to CiRXMnSID Register else *maskRegAddr=((sid10_0)<<5) + eid17_16; // Write to CiRXMnSID Register *(maskRegAddr+1)= eid15_0; // Write to CiRXMnEID Register } else { // Filter Standard Identifier sid10_0 = (identifier & 0x7FF); if(mide==1) *maskRegAddr=((sid10_0)<<5) + 0x0008; // Write to CiRXMnSID Register else *maskRegAddr=(sid10_0)<<5; // Write to CiRXMnSID Register *(maskRegAddr+1)=0; // Write to CiRXMnEID Register } C1CTRL1bits.WIN=0; } void dma0init(void) { DMACS0=0; DMA0CON=0x2020; DMA0PAD=0x0442; /* ECAN 1 (C1TXD) */ DMA0CNT=0x0007; DMA0REQ=0x0046; /* ECAN 1 Transmit */ DMA0STA= __builtin_dmaoffset(can_msgBuf); DMA0CONbits.CHEN=1; } /* Dma Initialization for ECAN1 Reception */ void dma2init(void) { DMACS0=0; DMA2CON=0x0020; DMA2PAD=0x0440; /* ECAN 1 (C1RXD) */ DMA2CNT=0x0007; DMA2REQ=0x0022; /* ECAN 1 Receive */ DMA2STA= __builtin_dmaoffset(can_msgBuf_r); DMA2CONbits.CHEN=1; } void ecanWriteTxMsgBufId(unsigned int buf, long txIdentifier, unsigned int ide, unsigned int remoteTransmit) { unsigned long word0=0, word1=0, word2=0; unsigned long sid10_0=0, eid5_0=0, eid17_6=0; eid5_0 = (txIdentifier & 0x3F); eid17_6 = (txIdentifier>>6) & 0xFFF; sid10_0 = (txIdentifier>>18) & 0x7FF; word1 = eid17_6; if(remoteTransmit==1) { // Transmit Remote Frame word0 = ((sid10_0 << 2) | ide | 0x2); word2 = ((eid5_0 << 10)| 0x0200); } else { word0 = ((sid10_0 << 2) | ide); word2 = (eid5_0 << 10); } can_msgBuf[0][0] = word0; can_msgBuf[0][1] = word1; can_msgBuf[0][2] = word2; } void ecanWriteTxMsgBufData(unsigned int buf, unsigned int dataLength, unsigned int data1, unsigned int data2, unsigned int data3, unsigned int data4) { can_msgBuf[0][2] = ((can_msgBuf[0][2] & 0xFFF0) + dataLength) ; can_msgBuf[0][3] = data1; can_msgBuf[0][4] = data2; can_msgBuf[0][5] = data3; can_msgBuf[0][6] = data4; } void ecanWriteMessage(unsigned int data1,unsigned int data2,unsigned int data3,unsigned int data4) { unsigned long txIdentifier; unsigned int Data1; unsigned int Data2; unsigned int Data3; unsigned int Data4; txIdentifier = ACP_CAN_ID; Data1 = data1; Data2 = data2; Data3 = data3; Data4 = data4; ecanWriteTxMsgBufId(0,txIdentifier<<18,0,0); ecanWriteTxMsgBufData(0,8,Data1,Data2,Data3,Data4); C1TR01CONbits.TXREQ0=1; } void C1_P(void) { IFS2bits.C1IF = 0; // clear interrupt flag if(C1INTFbits.TBIF) { C1INTFbits.TBIF = 0; } if(C1INTFbits.RBIF) { C1INTFbits.RBIF = 0; // read the message if(C1RXFUL1bits.RXFUL1==1) { C1RXFUL1bits.RXFUL1=0; } if(((can_msgBuf_r[1][0] & 0x1FFC) >> 2) == ACP_CAN_ID) { ACP_10= can_msgBuf_r[1][5]; ACP_11 = ((ACP_10 & 0x00FF)<<8); ACP_11 += ((ACP_10 & 0xFF00)>>8); ACPDCCurrent=ACP_11; ACP_12= can_msgBuf_r[1][3]; ACP_13 = ((ACP_12 & 0x00FF)<<8); ACP_13 += ((ACP_12 & 0xFF00)>>8); ACPDCVoltage=ACP_13; ACP_14= can_msgBuf_r[1][4]; ACP_15 = ((ACP_14 & 0x00FF)<<8); ACP_15 += ((ACP_14 & 0xFF00)>>8); ACPSpdFeedback=ACP_15; } } } void __attribute__((interrupt, no_auto_psv)) _C1Interrupt(void) { IFS2bits.C1IF = 0; // clear interrupt flag C1_P(); return; } void __attribute__((interrupt, no_auto_psv)) _DMA0Interrupt(void) { IFS0bits.DMA0IF = 0; return; } void __attribute__((interrupt, no_auto_psv)) _DMA2Interrupt(void) { IFS1bits.DMA2IF = 0; return; } |
2个回答
谢谢楼主愿意把这些东西和大家分享,相信会对很多人产生好的影响
只有小组成员才能发言,加入小组>>
求解外围电路实现的是4脚给持续低电平复位并正常工作,高电平不工作的原因
2382 浏览 1 评论
4242 浏览 3 评论
PIC1946程序有一个变量在运行过程中恢复初始值其他变量保持不变
2619 浏览 2 评论
3118 浏览 0 评论
PIC16F1825的RC5引脚,在主程序中操作无效,在中断中可以改变是为什么?
4577 浏览 5 评论
有套STM32与西门子200程序需要代写,有兴趣的工程师与有联系!
2491浏览 1评论
用XC8编译PIC18F25K80时提示下面Error,求怎么解决这个问题
6801浏览 0评论
/9
GMT+8, 2025-12-17 20:50 , Processed in 0.720812 second(s), Total 77, Slave 60 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
10331
