扫一扫,分享给好友
做的是心跳脉搏测量,用的是pulsesensor 脉搏 心率传感器
程序是都是一样的,是从Arduino改过来的51程序, 现在问题是,测不出数据来,显示屏算不出心率。。。 麻烦大神帮忙看看谢谢了。。 #include #include "stdio.h" #include #define false 0 #define true 1 #define FOSC 11059200L //系统时钟 #define BAUD 115200 //波特率 #define T0MS (65536-FOSC/12/500) //500HZ in 12T MODE #define ADC_POWER 0x80 #define ADC_FLAG 0x10 #define ADC_START 0x08; #define ADC_SPEEDLL 0x00 #define ADC_SPEEDL 0x20 #define ADC_SPEEDH 0x40 #define ADC_SPEEDHH 0x60 #define ADC_MASK 0x01 void UART_init(void); void ADC_init(unsigned char channel); void T0_init(void); void sendDataToProcessing(char symbol, int dat); void UART_send(char dat); unsigned char PulsePin = 0; //***it blinkPin = P1^7; //***it fadePin = P2^3; //***it led1 = P2^1; //***it led2 = P2^2; int fadeRate = 0; // these variables are volatile because they are used during the interrupt service routine! volatile unsigned int BPM; // used to hold the pulse rate volatile unsigned int Signal; // holds the incoming raw data volatile unsigned int IBI = 600; // holds the time between beats, must be seeded! volatile bit Pulse = false; // true when pulse wave is high, false when it's low volatile bit QS = false; // becomes true when Arduoino finds a beat. volatile int rate[10]; // array to hold last ten IBI values volatile unsigned long sampleCounter = 0; // used to determine pulse timing volatile unsigned long lastBeatTime = 0; // used to find IBI volatile int Peak =512; // used to find peak in pulse wave, seeded volatile int Trough = 512; // used to find trough in pulse wave, seeded volatile int thresh = 512; // used to find instant moment of heart beat, seeded volatile int amp = 100; // used to hold amplitude of pulse waveform, seeded volatile bit firstBeat = true; // used to seed rate array so we startup with reasonable BPM volatile bit secondBeat = false; // used to seed rate array so we startup with reasonable BPM static unsigned char order=0; unsigned char code ucForum0[]="Pulsesensor test"; unsigned char code ucForum1[]=" BPM: "; unsigned char DisBuff[4]={0}; void sys_init() { UART_init(); // we agree to talk fast! ADC_init(PulsePin); T0_init(); // sets up to read Pulse Sensor signal every 2mS LCD1602_Init(); //液晶初始化 } void main(void) { sys_init(); LCD1602_DisplayString(ucForum0); //显示的内容 LCD1602_MoveToPosition(1,0); //显示位置移动到指定位置 LCD1602_DisplayString(ucForum1); //显示的内容 while(1) { sendDataToProcessing('S', Signal); // send Processing the raw Pulse Sensor data if (QS == true){ // Quantified Self flag is true when arduino finds a heartbeat fadeRate = 255; // Set 'fadeRate' Variable to 255 to fade LED with pulse sendDataToProcessing('B',BPM); // send heart rate with a 'B' prefix sendDataToProcessing('Q',IBI); // send time between beats with a 'Q' prefix QS = false; // reset the Quantified Self flag for next time LCD1602_MoveToPosition(1,9); LCD1602_DisplayString(DisBuff); } //ledFadeToBeat(); delay(138); // take a break 19.6ms } } //void ledFadeToBeat(){ // fadeRate -= 15; // set LED fade value // fadeRate = constrain(fadeRate,0,255); // keep LED fade value from going into negative numbers! // analogWrite(fadePin,fadeRate); // fade LED // } void sendDataToProcessing(char symbol, int dat ){ putchar(symbol); // symbol prefix tells Processing what type of data is coming printf("%drn",dat); // the data to send culminating in a carriage return } void UART_init(void) { PCON &= 0x7f; //波特率不倍速 SCON = 0x50; //8位数据,可变波特率 BRT = 0xFD; //独立波特率产生器初值 AUXR |= 0x04; //时钟设置为1T模式 AUXR |= 0x01; //选择独立波特率产生器 AUXR |= 0x10; //启动波特率产生 } char putchar(unsigned char dat) { TI=0; SBUF=dat; while(!TI); TI=0; return SBUF; } void T0_init(void){ // Initializes Timer0 to throw an interrupt every 2mS. TMOD |= 0x01; //16bit TIMER TL0=T0MS; TH0=T0MS>>8; TR0=1; //start Timer 0 ET0=1; //enable Timer Interrupt EA=1; // MAKE SURE GLOBAL INTERRUPTS ARE ENABLED } void ADC_init(unsigned char channel) { P1ASF=ADC_MASK< ADC_RES=0; //clear former ADC result ADC_RESL=0; //clear former ADC result AUXR1 |= 0x04; //adjust the format of ADC result ADC_CONTR=channel|ADC_POWER|ADC_SPEEDLL|ADC_START; //power on ADC and start conversion } unsigned int analogRead(unsigned char channel) { unsigned int result; ADC_CONTR &=!ADC_FLAG; //clear ADC FLAG result=ADC_RES; result=result<<8; result+=ADC_RESL; ADC_CONTR|=channel|ADC_POWER|ADC_SPEEDLL|ADC_START; return result; } // Timer 0中断子程序,每2MS中断一次,读取AD值,计算心率值 void Timer0_rountine(void) interrupt 1 { int N; unsigned char i; // keep a running total of the last 10 IBI values unsigned int runningTotal = 0; // clear the runningTotal variable EA=0; // disable interrupts while we do this TL0=T0MS; TH0=T0MS>>8; //reload 16 bit TIMER0 Signal = analogRead(PulsePin); // read the Pulse Sensor sampleCounter += 2; // keep track of the time in mS with this variable N = sampleCounter - lastBeatTime; // monitor the time since the last beat to avoid noise // find the peak and trough of the pulse wave if(Signal < thresh && N > (IBI/5)*3){ // avoid dichrotic noise by waiting 3/5 of last IBI if (Signal < Trough){ // T is the trough Trough = Signal; // keep track of lowest point in pulse wave } } if(Signal > thresh && Signal > Peak){ // thresh condition helps avoid noise Peak = Signal; // P is the peak } // keep track of highest point in pulse wave // NOW IT'S TIME TO LOOK FOR THE HEART BEAT // signal surges up in value every time there is a pulse if (N > 250){ // avoid high frequency noise if ( (Signal > thresh) && (Pulse == false) && (N > (IBI/5)*3) ){ Pulse = true; // set the Pulse flag when we think there is a pulse // blinkPin=0; // turn on pin 13 LED IBI = sampleCounter - lastBeatTime; // measure time between beats in mS lastBeatTime = sampleCounter; // keep track of time for next pulse if(secondBeat){ // if this is the second beat, if secondBeat == TRUE secondBeat = false; // clear secondBeat flag for(i=0; i<=9; i++){ // seed the running total to get a realisitic BPM at startup rate = IBI; } } if(firstBeat){ // if it's the first time we found a beat, if firstBeat == TRUE firstBeat = false; // clear firstBeat flag secondBeat = true; // set the second beat flag EA=1; // enable interrupts again return; // IBI value is unreliable so discard it } for(i=0; i<=8; i++){ // shift data in the rate array rate = rate[i+1]; // and drop the oldest IBI value runningTotal += rate; // add up the 9 oldest IBI values } rate[9] = IBI; // add the latest IBI to the rate array runningTotal += rate[9]; // add the latest IBI to runningTotal runningTotal /= 10; // average the last 10 IBI values BPM = 60000/runningTotal; // how many beats can fit into a minute? that's BPM! if(BPM>200)BPM=200; //限制BPM最高显示值 if(BPM<30)BPM=30; //限制BPM最低显示值 DisBuff[2] = BPM%10+48;//取个位数 DisBuff[1] = BPM%100/10+48; //取十位数 DisBuff[0] = BPM/100+48; //百位数 if(DisBuff[0]==48) DisBuff[0]=32; QS = true; // set Quantified Self flag // QS FLAG IS NOT CLEARED INSIDE THIS ISR } } if (Signal < thresh && Pulse == true){ // when the values are going down, the beat is over // blinkPin=1; // turn off pin 13 LED Pulse = false; // reset the Pulse flag so we can do it again amp = Peak - Trough; // get amplitude of the pulse wave thresh = amp/2 + Trough; // set thresh at 50% of the amplitude Peak = thresh; // reset these for next time Trough = thresh; } if (N > 2500){ thresh = 512; Peak = 512; Trough = 512; lastBeatTime = sampleCounter; firstBeat = true; secondBeat = false; } EA=1; }// end isr |
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
【瑞萨RA6E2】瑞萨E2S软件安装过程,等待过程玩下97_e2 studio_ZGZZ
234 浏览 0 评论
514 浏览 0 评论
【原创】【RA4M2-SENSOR开发板评测】低功耗+USB综合测试
826 浏览 0 评论
1366 浏览 2 评论
814 浏览 0 评论
【youyeetoo X1 windows 开发板体验】少儿AI智能STEAM积木平台
16911 浏览 31 评论
/9
GMT+8, 2025-12-3 00:57 , Processed in 0.594835 second(s), Total 71, Slave 53 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
4507
