我是一个单片机方面的的新人最近正在学习这方面的知识,不过认识浅薄实在看不懂,1563165260@qq.com这是我邮箱同志们加油哦!!!
#include #include #define LCD_DB P0 //并行数据端口 #define Keyboard P1 #define Coil_A1 {A1 = 1; B1 = 0; C1 = 0; D1 = 0;} #define Coil_B1 {A1 = 0; B1 = 1; C1 = 0; D1 = 0;} #define Coil_C1 {A1 = 0; B1 = 0; C1 = 1; D1 = 0;} #define Coil_D1 {A1 = 0; B1 = 0; C1 = 0; D1 = 1;} #define Coil_OFF {A1 = 0; B1 = 0; C1 = 0; D1 = 0;} ***it DQ = P2^0; //单总线端口定义 ***it BUZZER = P2^1; //蜂鸣器端口定义 ***it HUMIDIFIER = P2^2; //加湿器端口定义 ***it HEATER = P2^3; //加热器端口定义 ***it LCD_RS = P2^4; //数据/指令控制端口定义 ***it LCD_RW = P2^5; //读/写 控制端口定义 ***it LCD_E = P2^6; //使能控制端口定义 ***it BUZZER_LIGHtiNG = P2^7; //蜂鸣器数据输出端口定义 ***it A1 = P3^4; //步进电机端口定义 ***it B1 = P3^5; ***it C1 = P3^6; ***it D1 = P3^7; void initial(void); //初始化 void LCD_write_command(unsigned char com); //写指令 void LCD_display_char(unsigned char x, unsigned char y, unsigned char dat); //显示位置,x(0-16),y(1-2) void LCD_display_screen(unsigned char screenNumber); unsigned char keyScan(void); //键盘扫描 unsigned char KeyPro(void); void keyboardResponse(void); //获取输入或输出 unsigned char read_DHT11_char(void); void control_temperature_humidity(void); void delay_xms(unsigned int time_xms); void Delay_10us(void); void COM(void); void RH(void); void controlPeripheral(void); bit keyPressFlag = 0; unsigned char stop_system = 0; unsigned char screenNumber = 0; unsigned char keyNumber = 0; unsigned char code lineOne[] = "Grainbin T&H ACS"; unsigned char code lineTwo[] = " Loading... "; unsigned char code lineThree[] = "Temperature: C"; unsigned char code lineFour[] = " Region: - >"; unsigned char code lineFive[] = "Humidity: %RH"; unsigned char code lineSix[] = "< Region: - >"; unsigned char code lineSeven[] = " Humidifier: "; unsigned char code lineEight[] = "< Heater: >"; unsigned char code lineNine[] = "Window(0-90): 0 "; unsigned char code lineTen[] = "< "; unsigned char code lineEleven[] = "Shutting down..."; unsigned int T1_number; unsigned char temperature = 15, humidity = 50; unsigned char stepperNumber = 0; unsigned int motorNumber = 2525; //2525 * 5 ms步进电机转一周 unsigned char ceilingTemperature = 25, floorTemperature = 10, ceilingHumidity = 75, floorHumidity = 35; unsigned char windowState = 0, windowAngle = 0; unsigned char U8FLAG, U8comdata, U8temp; void initial(void) { DQ = 1; //闲置状态下,传感器数据线处于高电平状态 HEATER = 0; //关闭加热器 HUMIDIFIER = 0; //关闭加湿器 BUZZER = 0; //关闭报警器 BUZZER_LIGHTING = 1; TMOD = 0x11; //定时器0工作方式1,16位计数器;定时器1工作方式1,16位计数器 TH1 = 0xFC; //定时器1溢出周期1ms,延时 TH1 = 0x66; TH0 = 0xED; //定时器0中断周期5ms TL0 = 0xFF; EA = 1; //开启总中断 ET1 = 1; //开启定时/计数器1中断 ET0 = 1; //开启定时/计数器0中断 EX0 = 1; //开启外部中断0 IT0 = 1; //外部中断0下降沿触发 TR0 = 1; //开启定时计数器0 LCD_write_command(0x38); //设置8位格式,2行,5x7 LCD_write_command(0x0c); //设置整体显示,关闭光标,且不闪烁 LCD_write_command(0x06); //设置输入方式,增量不移位 LCD_display_screen(screenNumber); delay_xms(2000); LCD_display_screen(++screenNumber); } void LCD_display_screen(unsigned char screenNumber) { unsigned char i, j; if (screenNumber == 0) { LCD_write_command(0x01); //清屏 for (i = 0; i < 16; i++) { LCD_display_char(i, 1, lineOne); } for (j = 0; j < 16; j++) { LCD_display_char(j, 2, lineTwo[j]); } } else if (screenNumber == 1) { LCD_write_command(0x01); //清屏 for (i = 0; i < 16; i++) { LCD_display_char(i, 1, lineThree); } for (j = 0; j < 16; j++) { LCD_display_char(j, 2, lineFour[j]); } LCD_display_char(14,1,0xDF); //显示特殊符号 LCD_display_char(12, 1, temperature / 10 + 0x30); LCD_display_char(13, 1, temperature % 10 + 0x30); LCD_display_char(9, 2, floorTemperature / 10 + 0x30); LCD_display_char(10, 2, floorTemperature % 10 + 0x30); LCD_display_char(12, 2, ceilingTemperature / 10 + 0x30); LCD_display_char(13, 2, ceilingTemperature % 10 + 0x30); } else if (screenNumber == 2) { LCD_write_command(0x01); //清屏 for (i = 0; i < 16; i++) { LCD_display_char(i, 1, lineFive); } for (j = 0; j < 16; j++) { LCD_display_char(j, 2, lineSix[j]); } LCD_display_char(11, 1, humidity / 10 + 0x30); LCD_display_char(12, 1, humidity % 10 + 0x30); LCD_display_char(9, 2, floorHumidity / 10 + 0x30); LCD_display_char(10, 2, floorHumidity % 10 + 0x30); LCD_display_char(12, 2, ceilingHumidity / 10 + 0x30); LCD_display_char(13, 2, ceilingHumidity % 10 + 0x30); } else if (screenNumber == 3) { LCD_write_command(0x01); //清屏 for (i = 0; i < 16; i++) { LCD_display_char(i, 1, lineSeven); } for (j = 0; j < 16; j++) { LCD_display_char(j, 2, lineEight[j]); } if (HUMIDIFIER == 0) { LCD_display_char(15, 1, 'F'); LCD_display_char(14, 1, 'F'); LCD_display_char(13, 1, 'O'); } else { LCD_display_char(15, 1, 'N'); LCD_display_char(14, 1, 'O'); } if (HEATER == 0) { LCD_display_char(13, 2, 'F'); LCD_display_char(12, 2, 'F'); LCD_display_char(11, 2, 'O'); } else { LCD_display_char(13, 2, 'N'); LCD_display_char(12, 2, 'O'); } } else if (screenNumber == 4) { LCD_write_command(0x01); //清屏 for (i = 0; i < 16; i++) { LCD_display_char(i, 1, lineNine); } for (j = 0; j < 16; j++) { LCD_display_char(j, 2, lineTen[j]); } LCD_display_char(15,1,0xDF); //显示特殊符号 LCD_display_char(13, 1, windowAngle + 0x30); } else if (screenNumber == 5) { LCD_write_command(0x01); //清屏 for (i = 0; i < 16; i++) { LCD_display_char(i, 1, lineEleven); } } } void LCD_write_command(unsigned char com) { LCD_DB = com; LCD_RS = 0; LCD_RW = 0; LCD_E = 1; delay_xms(1); LCD_E = 0; delay_xms(5); } void LCD_display_char(unsigned char x, unsigned char y, unsigned char dat) { if (y == 1) { LCD_write_command(0x80 + x); } else { LCD_write_command(0xc0 + x); } LCD_DB = dat; LCD_RS = 1; LCD_RW = 0; LCD_E = 1; delay_xms(1); LCD_E = 0; delay_xms(5); } void delay_xms(unsigned int time_xms) { T1_number = 0; TR1 = 1; while (1) { if (time_xms == T1_number) { break; } } TR1 = 0; } void Delay_10us(void) { unsigned char i; i--; i--; i--; i--; i--; i--; } void COM(void) //DHT11传输总线 { unsigned char i = 0; for(i=0;i<8;i++) { U8FLAG=2; _nop_(); _nop_(); while((!DQ) && U8FLAG++); Delay_10us(); Delay_10us(); U8temp=0; if(DQ) U8temp=1; U8FLAG=2; while((DQ) && U8FLAG++); _nop_(); _nop_(); if(U8FLAG==1)break; //如果超时,退出循环 U8comdata<<=1; //判断数据位0或1 U8comdata|=U8temp; } } void RH(void) { unsigned char humidity_H, humidity_L, temperature_H, temperature_L, checkData; DQ = 0; //主机拉低18ms delay_xms(200); DQ = 1; //总线由上拉电阻拉高 主机延时20us Delay_10us(); Delay_10us(); Delay_10us(); Delay_10us(); DQ = 1; //主机设为输入 判断从机响应信号 //判断从机是否有低电平响应信号 如不响应则跳出,响应则向下运 行 if(!DQ) { U8FLAG=2; while((!DQ)&&U8FLAG++); //判断从机是否发出 80us 的低电平响应信号是否结 束 U8FLAG=2; while((DQ)&&U8FLAG++); //判断从机是否发出 80us 的高电平,如发出则进入数据接收状态 COM(); humidity_H = U8comdata; //数据接收状态 COM(); humidity_L = U8comdata; COM(); temperature_H = U8comdata; COM(); temperature_L = U8comdata; COM(); checkData = U8comdata; DQ = 1; } if ((unsigned char)(humidity_H + humidity_L + temperature_H + temperature_L)== checkData) { humidity = humidity_H; temperature = temperature_H; } } void controlPeripheral() { if (temperature < floorTemperature) { windowState = 0; } else if (temperature > ceilingTemperature) { windowState = 9; } else { windowState = (unsigned char)(10 * (temperature - floorTemperature) /(ceilingTemperature - floorTemperature)); } if (temperature > ceilingTemperature | temperature < floorTemperature) //蜂鸣器调控 { BUZZER = 1; BUZZER_LIGHTING = 0; } else if (humidity > ceilingHumidity | humidity < floorHumidity) { BUZZER = 1; BUZZER_LIGHTING = 0; } else { BUZZER = 0; BUZZER_LIGHTING = 1; } if (temperature <= floorTemperature) //加热器调控 { HEATER = 1; } else if (temperature >= (ceilingTemperature - 3)) { HEATER = 0; } if (humidity <= floorHumidity) //加湿器调控 { HUMIDIFIER = 1; } else if (humidity >= ceilingHumidity) { HUMIDIFIER = 0; } } void main(void) { unsigned int DHT11Timer = 200; initial(); while(!stop_system) { keyboardResponse(); if (DHT11Timer-- == 0) { DHT11Timer = 200; RH(); if (screenNumber == 1) { LCD_display_char(12, 1, temperature / 10 + 0x30); LCD_display_char(13, 1, temperature % 10 + 0x30); } else if (screenNumber == 2) { LCD_display_char(11, 1, humidity / 10 + 0x30); LCD_display_char(12, 1, humidity % 10 + 0x30); } } else { delay_xms(10); } if (screenNumber == 4) { LCD_display_char(13, 1, windowAngle + 0x30); } controlPeripheral(); } LCD_display_screen(5); //关闭系统 windowState = 0; delay_xms(3000); LCD_write_command(0x01); delay_xms(60000); } void keyboardResponse() { Keyboard = 0xf0; // 赋值用于中断检测 if(keyPressFlag == 1) { keyPressFlag = 0; //按键标志清零,以便下次检测 keyNumber = KeyPro(); if(keyNumber != 0xff) { if (screenNumber != 1 & keyNumber == 0) { LCD_display_screen(--screenNumber); } else if (screenNumber != 4 & keyNumber == 4) { LCD_display_screen(++screenNumber); } else if (keyNumber == 1) { floorTemperature--; LCD_display_screen(screenNumber); } else if (keyNumber == 5) { floorTemperature++; LCD_display_screen(screenNumber); } else if (keyNumber == 9) { ceilingTemperature--; LCD_display_screen(screenNumber); } else if (keyNumber == 13) { ceilingTemperature++; LCD_display_screen(screenNumber); } else if (keyNumber == 3) //加热器开关 { if (HEATER == 0) { HEATER = 1; } else { HEATER = 0; } if (screenNumber == 3) { LCD_display_screen(screenNumber); } } else if (keyNumber == 2) { floorHumidity--; LCD_display_screen(screenNumber); } else if (keyNumber == 6) { floorHumidity++; LCD_display_screen(screenNumber); } else if (keyNumber == 10) { ceilingHumidity--; LCD_display_screen(screenNumber); } else if (keyNumber == 14) { ceilingHumidity++; LCD_display_screen(screenNumber); } else if (keyNumber == 7) //加湿器开关 { if (HUMIDIFIER == 0) { HUMIDIFIER = 1; } else { HUMIDIFIER = 0; } if (screenNumber == 3) { LCD_display_screen(screenNumber); } } else if (keyNumber == 11) { stop_system = 1; } } } } void INT_0(void) interrupt 0 { keyPressFlag = 1; } unsigned char keyScan() { unsigned char Val; Keyboard=0xf0; //高四位置高,低四位拉低 if(Keyboard != 0xf0) //表示有按键按下 { delay_xms(10); //去抖 if(Keyboard != 0xf0) { //表示有按键按下 Keyboard = 0xfe; //检测第一行 if(Keyboard != 0xfe) { Val=Keyboard & 0xf0; Val += 0x0e; while(Keyboard != 0xfe); delay_xms(10); //去抖 while(Keyboard != 0xfe); return Val; } Keyboard = 0xfd; //检测第二行 if(Keyboard != 0xfd) { Val=Keyboard & 0xf0; Val += 0x0d; while(Keyboard != 0xfd); delay_xms(10); //去抖 while(Keyboard != 0xfd); return Val; } Keyboard = 0xfb; //检测第三行 if(Keyboard != 0xfb) { Val=Keyboard & 0xf0; Val += 0x0b; while(Keyboard != 0xfb); delay_xms(10); //去抖 while(Keyboard != 0xfb); return Val; } Keyboard = 0xf7; //检测第四行 if(Keyboard != 0xf7) { Val=Keyboard & 0xf0; Val += 0x07; while(Keyboard != 0xf7); delay_xms(10); //去抖 while(Keyboard != 0xf7); return Val; } } } return 0xff; } unsigned char KeyPro() { switch(keyScan() { case 0x7e:return 0;break; //0 按键返回响应值 case 0x7d:return 1;break; //1 case 0x7b:return 2;break; //2 case 0x77:return 3;break; //3 case 0xbe:return 4;break; //4 case 0xbd:return 5;break; //5 case 0xbb:return 6;break; //6 case 0xb7:return 7;break; //7 case 0xde:return 8;break; //8 case 0xdd:return 9;break; //9 case 0xdb:return 10;break; //a case 0xd7:return 11;break; //b case 0xee:return 12;break; //c case 0xed:return 13;break; //d case 0xeb:return 14;break; //e case 0xe7:return 15;break; //f default:return 0xff;break; } } void Timer_0(void) interrupt 1 { TR0 = 0; TH0 = 0xED; //定时器0中断周期5ms TL0 = 0xFF; if (windowState < windowAngle) { if (motorNumber >= 1) { motorNumber--; switch (stepperNumber) { case 0: Coil_A1; stepperNumber++; break; case 1: Coil_B1; stepperNumber++; break; case 2: Coil_C1; stepperNumber++; break; case 3: Coil_D1; stepperNumber++; break; default: stepperNumber = 0; break; } } else { motorNumber = 2525; windowAngle--; } } else if (windowState > windowAngle) { if (motorNumber >= 1) { motorNumber--; switch (stepperNumber) { case 0: Coil_D1; stepperNumber++; break; case 1: Coil_C1; stepperNumber++; break; case 2: Coil_B1; stepperNumber++; break; case 3: Coil_A1; stepperNumber++; break; default: stepperNumber = 0; break; } } else { motorNumber = 2525; windowAngle++; } } else { Coil_OFF; } TR0 = 1; } void Timer_1(void) interrupt 3 { TH1 = 0xFC; //定时器1溢出周期1ms,延时 TL1 = 0x66; T1_number++; } |
1个回答
看来是沉了
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
Openharmony软件评估指南-米尔瑞芯微RK3568开发板
611 浏览 0 评论
STM32CUBEMX(7)--移植雅特力AT32F403AVGT(兼容STM32F103VGT6),DAC输出电压
1047 浏览 0 评论
【RA-Eco-RA0E1-32PIN-V1.0开发板试用】开发板简介与上电测试
970 浏览 0 评论
嵌入式学习-飞凌嵌入式ElfBoard ELF 1板卡-shell脚本编写之传参
538 浏览 0 评论
【xG24 Matter开发套件试用体验】点灯之后的UART测试
668 浏览 0 评论
【youyeetoo X1 windows 开发板体验】少儿AI智能STEAM积木平台
11041 浏览 31 评论
GMT+8, 2024-9-10 13:46 , Processed in 0.689816 second(s), Total 73, Slave 55 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
