通过Verilog HDL用数码管设计了一个40s倒计时,可以麻烦各位大神帮我加上一个10s之后的蜂鸣器吗,我初学FPGA,试了编辑一个之后,调试后蜂鸣器不响,下面是倒计时的代码,求大神们指教,急急急!!!
module led_rxd(clk,rst_n,SOS_En_Sig,led,led_seg); input clk,rst_n; output [7:0]led; output [5:0]led_seg; output SOS_En_Sig; parameter seg_num0=8'hc0, seg_num1=8'hf9, seg_num2=8'ha4, seg_num3=8'hb0, seg_num4=8'h99, seg_num5=8'h92, seg_num6=8'h82, seg_num7=8'hf8, seg_num8=8'h80, seg_num9=8'h90; parameter seg_en0=6'b111110, seg_en1=6'b111101, seg_en2=6'b111011, seg_en3=6'b110111, seg_en4=6'b101111, seg_en5=6'b011111; reg [26:0]count; reg [3:0] count1; reg [3:0] count2; reg [7:0] led_reg; reg [5:0] led_seg_reg; always@(posedge clk or negedge rst_n) if(!rst_n) count<=27'd0; else if(count==27'd49_999_999) count<=27'd0; else count<=count+1'b1; wire clk_div=(count==27'd49_999_999); always@(posedge clk_div or negedge rst_n) if(!rst_n) begin count1<=4'd0; count2<=4'd4; end else if((count1==4'd0)&&(count2==4'd0)) begin count1<=4'd0; count2<=4'd4; end else if(count1==4'd0) begin count2<= count2-1'b1; count1<=4'd9; end else count1<=count1-1'b1; reg [26:0]count_1ms;// always@(posedge clk or negedge rst_n) if(!rst_n) count_1ms<=27'd0; else if(count_1ms==27'd49_999) count_1ms<=27'd0; else count_1ms<=count_1ms+1'b1; wire clk_dis=(count_1ms==27'd49_999);// // reg [1:0]state; always@(posedge clk_dis or negedge rst_n) if(!rst_n) begin led_reg<=8'hff; led_seg_reg<=6'b111111; state<=2'b00; end else if(state==2'b00) begin state<=2'b01; led_seg_reg<=6'b111101; case(count2) 4'd0: led_reg<=seg_num0; 4'd1: led_reg<=seg_num1; 4'd2:led_reg<=seg_num2; 4'd3: led_reg<=seg_num3; 4'd4: led_reg<=seg_num4; 4'd5: led_reg<=seg_num5; 4'd6: led_reg<=seg_num6; 4'd7: led_reg<=seg_num7; 4'd8: led_reg<=seg_num8; 4'd9: led_reg<=seg_num9; default: led_reg<=seg_num0; endcase end else if(state==2'b01) begin state<=2'b00; led_seg_reg<=6'b111110; case(count1) 4'd0:led_reg<=seg_num0; 4'd1:led_reg<=seg_num1; 4'd2:led_reg<=seg_num2; 4'd3:led_reg<=seg_num3; 4'd4:led_reg<=seg_num4; 4'd5:led_reg<=seg_num5; 4'd6:led_reg<=seg_num6; 4'd7:led_reg<=seg_num7; 4'd8:led_reg<=seg_num8; 4'd9:led_reg<=seg_num9; default:led_reg<=seg_num0; endcase end reg isEn; always@(posedge clk or negedge rst_n) if(!rst_n) begin isEn<=1'b0; end else begin isEn<=1'b1; end assign led=led_reg; assign led_seg=led_seg_reg; assign SOS_En_Sig=isEn; endmodule
7个回答
你那assign SOS_En_Sig=isEn;应该是让蜂鸣器使能端吧,所以我加了一个频率输出端 至于那个10s才响,你就多判断几次吧,if(10s)~~~~balabala 可以:if(10s) 使能端赋1, if(使能端) 输出频率
最佳答案
wire carry;
reg[13:0]divider; output reg sp; assign carry=(divider==16383); always @(posedge count[2]) begin if(carry)//当divider为16383时,将origin的值赋给divider divider=11272; else divider=divider+1; end always@(posedge carry) sp =~sp; |
正在路上的 发表于 2016-4-13 18:00 对不起,我还以为没人看我的帖子,所以也回你,很抱歉。 |
其实我的主要疑问是,我那个10s要如何定义。就是if(10s) 这个10s我要如何表示出来,想了很久也没有想出来 |
我初学FPGA,太菜了。。。能麻烦你帮我写一下吗,谢谢您了, |
嘻嘻,对不起啊,麻烦你了 |
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
792 浏览 0 评论
NVMe over Fabrics 国产 IP:高性能网络存储解决方案
750 浏览 0 评论
130 浏览 0 评论
NVMe高速传输之摆脱XDMA设计54:如何测试队列管理功能2
437 浏览 0 评论
NVMe高速传输之摆脱XDMA设计53:如何测试队列管理功能
769 浏览 0 评论
4574 浏览 64 评论
/9
GMT+8, 2025-12-15 07:34 , Processed in 5.695394 second(s), Total 55, Slave 46 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2548
