把显示函数display()放在定时器中断T0里,把AD(PCF8591)读取放在主函数的while(1)循环里,就出了问题,我在AD函数里做了EA=0;EA=1;的避免干扰 还是不行 以下为代码: #include #include #define uchar unsigned char #define uint unsigned int uchar code table[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90,0xff,0xbf}; uchar discom[8]; uchar i; uchar num0; ***it sda=P2^1; ***it scl=P2^0; uchar ad; void buzz() { P2=(P2&0x1f)|0xa0; P0=0; P2&=0x1f; } /************************************************************************************** ****************************************************************************************/ void delay() {_nop_();} void i2cinit() { scl=1; delay(); sda=1; delay(); } void start() { EA=0; sda=1; delay(); scl=1; delay(); sda=0; delay(); EA=1; } void respons() { uchar i; EA=0; scl=1; delay(); while((sda==1)&&(i<255)) i++; scl=0; delay(); EA=1; } void stop() { EA=0; sda=0; delay(); scl=1; delay(); sda=1; delay(); EA=1; } void writebyte(uchar date) { uchar i; EA=0; for(i=0;i<8;i++) { scl=0; delay(); sda=(date< delay(); scl=1; delay(); } scl=0; delay(); sda=1; delay(); EA=1; } uchar readbyte() { uchar i,temp; EA=0; scl=0; delay(); for(i=0;i<8;i++) { temp=temp<<1; scl=1; delay(); if(sda)temp|=0x01; scl=0; delay(); } EA=1; return temp; } /************************************************************************************** ****************************************************************************************/ uchar read_add(uchar control) { uchar date; EA=0; start(); writebyte(0x90); respons(); writebyte(control); respons(); start(); writebyte(0x91); respons(); date=readbyte(); stop(); EA=1; return date; } void display() { P2=(P2&0x1f)|0xc0; P0=1< P2&=0x1f; P2=(P2&0x1f)|0xe0; P0=table[discom]; P2&=0x1f; if(i++==7) i=0; } void timeinit() { TMOD=0x01; TH0=(65536-1000)/256; TL0=(65536-1000)%256; EA=1; ET0=1; TR0=1; } void main() { buzz(); i2cinit(); timeinit(); while(1) { ad=read_add(0x43); //0100 0011 ËÄͨµÀµ¥¶ËÊäÈë Ñ¡ÔñͨµÀAIN3£º0011 discom[0]=ad/100; discom[1]=ad%100/10; discom[2]=ad%10; discom[3]=10; discom[4]=10; discom[5]=10; discom[6]=10; discom[7]=10; } } void t0() interrupt 1 { TH0=(65536-1000)/256; TL0=(65536-1000)%256; num0++; if(num0==2) { num0=0; display(); } } |
9个回答
试一下中断时间进行ad检测读取,while里进行显示看看能不能正常
那样是可以,但是如果必须要把显示放中断里 问题出在哪呢 |
那样的话你debug一下具体是测量不准确了还是显示不正常了
感觉写了太多的EA=0;EA=1;导致了测量时序不对了,可以试一下只在while读ad的位置上下加EA=0,EA=1;试试 |
还是不行啊...我也感觉是只加一个就行,但只加一个显示的更乱了
今天拿别人的I2C程序试了一下就没有问题,可能我这个I2C还是时序有点问题,自己跑还行,加个中断就出问题了,我再研究研究。。。谢谢哈 |
不客气,互帮互助 |
互帮互助,不要客气 |
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
185 浏览 0 评论
340 浏览 0 评论
367 浏览 0 评论
752 浏览 0 评论
RT-Thread与英飞凌(infineon)合作得板子PSOC 6 板子学习
737 浏览 0 评论
【youyeetoo X1 windows 开发板体验】少儿AI智能STEAM积木平台
16979 浏览 31 评论
/9
GMT+8, 2025-12-11 01:57 , Processed in 1.111927 second(s), Total 92, Slave 72 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1851
