stm8s用硬件iic的时候,stvp需要做哪些设置?我设置了option byte的AFR6,除此之外还有哪些要改的?系统时钟应该是默认的HSI/8,2Mhz。
代码如下; #include "stm8s.h" #include "stm8s_conf.h" #define SN3731_IIC_ADDRESS_M 0xe8 //包括8桢的图片寄存器地址段选择和一个控制寄存器地址段的选择 #define Reg_MainAddress 0xFD//寄存器主地址 //寄存器地址段选择(定义数据区域为1-8桢的数据) #define Reg_Section_Fram(i) ((i)-1)//i=1-8 #define Reg_Section_CTRLReg 0x0B //一幅SN3731开关寄存器定义 //i=1-9 #define Reg_ON_OFF_CS 0x00 #define Reg_ON_OFF_CSA(i) (Matrix_ON_OFF_CS+2*(i)-2) //A屏亮灭行变量 #define Reg_ON_OFF_CSB(i) (Matrix_ON_OFF_CS+2*(i)-1) //B屏亮灭行变量 //一幅SN3731闪烁寄存器定义 //i=1-9 #define Reg_Blink_CS 0x12 #define Reg_Blink_CSA(i) (Matrix_Blink_CS+2*(i)-2) //A屏闪烁行变量 #define Reg_Blink_CSB(i) (Matrix_Blink_CS+2*(i)-1) //B屏闪烁行变量 //一幅SN3731每颗灯灰度寄存器定义 //1-144 #define Reg_PWM(i) (0x25+(i)-2) //PWM地址偏移变量 //控制寄存器地址定义 #define Reg_ModeConfig 0x00 //模式配置寄存器 #define Reg_PictureAddress 0x01 //图片选择寄存器 #define Reg_FramePlay 0x02 //画面自动播放寄存器 #define Reg_FrameTime 0x03 //画面延时寄存器 #define Reg_0x04H 0x04 //NC #define Reg_BlinkCtrl 0x05 //闪烁模式寄存器 #define Reg_AudioSync 0x06 //音乐同步寄存器 #define Reg_StatusReg 0x07 //画面状态寄存器(只读) #define Reg_BreathTime 0x08 //呼吸时间设置寄存器 #define Reg_Breath 0x09 //呼吸控制寄存器 #define Reg_ShutDown 0x0A //关断寄存器 #define Reg_AGC 0x0B //AGC控制寄存器 #define Reg_AudioADCRate 0x0C //音频采样寄存器 // #define Config_Mode_Picture 0x00 #define Config_Mode_Movie (0x01<3) #define Config_Mode_AudioSync (0x02<3) #define Software_Shutdown_Mode 0x00 #define Normal_Operation_Mode 0x01 //Start frame in Movie Mode and Picture Mode //第 i frame #define Config_Strat_Frame(i) (Config_Strat_Frame+(i)-1) //Num of Loop in Moive mode //第 i frame #define Config_LoopNum_Movie(i) ((Config_LoopNum_Movie+(i))<3) //Num of frame in Moive mode //第 i frame #define Config_FrameNum_Movie(i) (Config_FrameNum_Movie+(i)) //Delay between frame change in a movie //i=0-63,当i=0,时间最大,其他情况下时间为i*30ms,最大为30ms*63=1.89s #define Config_Delay_BetweenFrame_Movie(i) (i)//2.394s u8 all_led_on[18]= { 0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff // 0x00,0x00,0xff,0xff,0x00,0x00,0xff,0xff,0x00,0x00,0xff,0xff,0x00,0x00,0xff,0xff,0x00,0x00 }; void IIC_BufferWrite(u8 Address,u8 *DataBuff,u16 DataLen) { while(I2C_GetFlagStatus(I2C_FLAG_BUSBUSY));//等待空闲才能操作 // ___ //发送起始信号 |/__ I2C_GenerateSTART( ENABLE ); while(!I2C_CheckEvent( I2C_EVENT_MASTER_START_SENT)); //发送从机地址器件,I2C主设备为写模式 I2C_Send7bitAddress(SN3731_IIC_ADDRESS_M, I2C_DIRECTION_TX); //检测从器件返回一个应答信号 while(!I2C_CheckEvent( I2C_EVENT_MASTER_ADDRESS_ACKED )); //发送字地址 I2C_SendData( Address ); while(!I2C_CheckEvent(I2C_EVENT_MASTER_BYTE_TRANSMITTING)); while(DataLen--) { I2C_SendData(*DataBuff++); while (!I2C_CheckEvent(I2C_EVENT_MASTER_BYTE_TRANSMITTED)); I2C_AcknowledgeConfig(I2C_ACK_CURR); } // __ //发送停止信号 __/| | I2C_GenerateSTOP( ENABLE ); } void SN3731_SelectSection(u8 MainAddress,u8 SectionReg) { while(I2C_GetFlagStatus(I2C_FLAG_BUSBUSY));//等待空闲才能操作 // ___ //发送起始信号 |/__ I2C_GenerateSTART( ENABLE ); while(!I2C_CheckEvent( I2C_EVENT_MASTER_START_SENT)); //发送从机地址器件,I2C主设备为写模式 I2C_Send7bitAddress(SN3731_IIC_ADDRESS_M, I2C_DIRECTION_TX); //检测从器件返回一个应答信号 while(!I2C_CheckEvent( I2C_EVENT_MASTER_ADDRESS_ACKED )); //发送字地址 I2C_SendData( MainAddress ); while(!I2C_CheckEvent(I2C_EVENT_MASTER_BYTE_TRANSMITTING)); I2C_SendData( SectionReg ); while(!I2C_CheckEvent(I2C_EVENT_MASTER_BYTE_TRANSMITTING)); // __ //发送停止信号 __/| | I2C_GenerateSTOP( ENABLE ); } void SN3731_Write_Reg(u8 reg,u8 data) { while(I2C_GetFlagStatus(I2C_FLAG_BUSBUSY));//等待空闲才能操作 // ___ //发送起始信号 |/__ I2C_GenerateSTART( ENABLE ); while(!I2C_CheckEvent( I2C_EVENT_MASTER_START_SENT)); //发送从机地址器件,I2C主设备为写模式 I2C_Send7bitAddress(SN3731_IIC_ADDRESS_M, I2C_DIRECTION_TX); //检测从器件返回一个应答信号 while(!I2C_CheckEvent( I2C_EVENT_MASTER_ADDRESS_ACKED )); //发送字地址 I2C_SendData( reg ); while(!I2C_CheckEvent(I2C_EVENT_MASTER_BYTE_TRANSMITTING)); I2C_SendData( data ); while(!I2C_CheckEvent(I2C_EVENT_MASTER_BYTE_TRANSMITTING)); // __ //发送停止信号 __/| | I2C_GenerateSTOP( ENABLE ); } int main( void ) { I2C_DeInit(); I2C_Init(100000, 0x00, I2C_DUTYCYCLE_2, I2C_ACK_CURR, I2C_ADDMODE_7BIT, 2); while(1) { SN3731_SelectSection(Reg_MainAddress,Reg_Section_Fram(1)); IIC_BufferWrite(Reg_ON_OFF_CS,all_led_on,18); SN3731_SelectSection(Reg_MainAddress,Reg_Section_CTRLReg); SN3731_Write_Reg(Reg_ModeConfig,0x00); SN3731_Write_Reg(Reg_PictureAddress,0x00); } } |
1个回答
楼主解决了吗,我也遇到同样的问题了
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
2005 浏览 1 评论
AD7686芯片不传输数据给STM32,但是手按住就会有数据。
1858 浏览 3 评论
4442 浏览 0 评论
如何解决MPU-9250与STM32通讯时,出现HAL_ERROR = 0x01U
2007 浏览 1 评论
hal库中i2c卡死在HAL_I2C_Master_Transmit
2513 浏览 1 评论
GMT+8, 2024-12-20 11:59 , Processed in 0.949397 second(s), Total 73, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
