报错1:
Error : Cannot communicate with the tool. Wrong tool selection or check tool power supply or check that a previous session is closed. Error : < PROGRAM MEMORY programming failed. 1.检查ST-link V2灯是否为蓝色1秒闪一次:ST-linkV2重新插拔一次 2.驱动未成功安装:打开设备管理器>通用串行设备总线>看是否有STMicroelectronics STLink dongle 如果没有请重新安装驱动 3.更新硬件:开始>所有程序>ST Toolset>Setup>Upgrade STLink打开STLink-upgrade 点击Device connect>Yes 4.如果上一步连接失败:ST-LINK is nonexistent.Please connect is and then retry.请确认第2步驱动是否未安装成功 5.如果以上四步都试过了还不行建议关闭STVD重新打开试下,很多时候都能好 6.如果以上五步都试过了还不行建议换个下载器试试吧 报错2:
Error : Cannot communicate with the device ! Check the SWIM cable connection and check all the needed pin connections on the SWIM connector. If the application code uses Swim Disable and Reset pin as Output or has disabled SWIM Clock Divider: Try Now to SWITCH OFF and ON the application Power Supply while NRST Reset pin is forced low. Error : < PROGRAM MEMORY programming failed. Error : < Operation aborted. 检查STLINK是四根下载线是否连接可靠,特别注意如果第一次下载不成功,第二次下载成功的话一定是RST线断 报错3:
1477 浏览 1 评论
1137 浏览 0 评论
1001 浏览 0 评论
STM32F405驱动DS1302时钟模块,输出时间错乱该怎么排查?
5380 浏览 2 评论
stm32f405rgt6驱动DS1302ZN出现时间错乱问题
4168 浏览 1 评论
/9
GMT+8, 2025-12-15 13:47 , Processed in 0.574815 second(s), Total 47, Slave 38 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
