Description: The RN-52 Bluetooth from Roving Networks is an audio module that makes it simple for you to create a hands free audio system for your car or remote control your media center. With this breakout board we’ve made it easy for you to drop it into any project you could use it for. All pertinent headers are broken out and labeled for your convenience. The RN-52 module combines a class 2 Bluetooth radio with an embedded digital signal processor (DSP). The module is programmed and controlled with a simple ASCII command language. It provides a UART interface, several user programmable I/O pins, stereo speaker outputs, microphone inputs, and a USB port. Features: Fully qualified Bluetooth module FCC Certified Fully configurable UART Dual-channel, differential audio input and output Supports iAP profile Low power sleep mode Maximum over air data rate of 3.0Mbps Compatible with all Bluetooth products that support SPP (almost all do) Embedded Bluetooth stack profiles: A2DP, AVRCP, HFP/HSP, and SPP 3.0 ~ 3.6V operation Bluetooth Technology v3.0 compatible Class 2 power output RN-52 Breakout_v11 SCH RN-52 Breakout_v11 PCBEasyEDA项目链接:https://easyeda.com/oshw/Audio_Bluetooth_Breakout_RN_52_Open_hardware-oOkCwO6oh EasyEDA链接:https://easyeda.com |
1 个讨论
谢谢!!!!···#
只有小组成员才能发言,加入小组>>
/9
GMT+8, 2025-12-1 10:35 , Processed in 0.689515 second(s), Total 49, Slave 37 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
4381
