#include "remote.h"
#include "delay.h" #include "usart.h" //红外遥控初始化 //设置IO以及定时器4的输入捕获 void Remote_Init(void) { GPIO_InitTypeDef GPIO_InitStructure; NVIC_InitTypeDef NVIC_InitStructure; tiM_TimeBaseInitTypeDef TIM_TimeBaseStructure; TIM_ICInitTypeDef TIM_ICInitStructure; RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA,ENABLE); //使能PORTB时钟 RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM5,ENABLE); //TIM5 时钟使能 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1; //PA1 输入 GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPD; //上拉输入 GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_Init(GPIOA, &GPIO_InitStructure); GPIO_SetBits(GPIOA,GPIO_Pin_1); //初始化GPIOA1 TIM_TimeBaseStructure.TIM_Period = 10000; //设定计数器自动重装值 最大10ms溢出 TIM_TimeBaseStructure.TIM_Prescaler =(72-1); //预分频器,1M的计数频率,1us加1. TIM_TimeBaseStructure.TIM_ClockDivision = TIM_CKD_DIV1; //设置时钟分割:TDTS = Tck_tim TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up; //TIM向上计数模式 TIM_TimeBaseInit(TIM5, &TIM_TimeBaseStructure); //根据指定的参数初始化TIMx TIM_ICInitStructure.TIM_Channel = TIM_Channel_2; // 选择输入端 IC2映射到TI5上 TIM_ICInitStructure.TIM_ICPolarity = TIM_ICPolarity_Rising; //上升沿捕获 TIM_ICInitStructure.TIM_ICSelection = TIM_ICSelection_DirectTI; TIM_ICInitStructure.TIM_ICPrescaler = TIM_ICPSC_DIV1; //配置输入分频,不分频 TIM_ICInitStructure.TIM_ICFilter = 0x03;//IC4F=0011 配置输入滤波器 8个定时器时钟周期滤波 TIM_ICInit(TIM5, &TIM_ICInitStructure);//初始化定时器输入捕获通道 TIM_Cmd(TIM5,ENABLE ); //使能定时器5 NVIC_InitStructure.NVIC_IRQChannel = TIM5_IRQn; //TIM5中断 NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 1; //先占优先级0级 NVIC_InitStructure.NVIC_IRQChannelSubPriority = 3; //从优先级3级 NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; //IRQ通道被使能 NVIC_Init(&NVIC_InitStructure); //根据NVIC_InitStruct中指定的参数初始化外设NVIC寄存器 TIM_ITConfig( TIM5,TIM_IT_Update|TIM_IT_CC2,ENABLE);//允许更新中断 ,允许CC2IE捕获中断 } //遥控器接收状态 //[7]:收到了引导码标志 //[6]:得到了一个按键的所有信息 //[5]:保留 //[4]:标记上升沿是否已经被捕获 //[3:0]:溢出计时器 u8 RmtSta=0; u16 Dval; //下降沿时计数器的值 u32 RmtRec=0; //红外接收到的数据 u8 RmtCnt=0; //按键按下的次数 //定时器5中断服务程序 void TIM5_IRQHandler(void) { if(TIM_GetITStatus(TIM5,TIM_IT_Update)!=RESET) { if(RmtSta&0x80)//上次有数据被接收到了 { RmtSta&=~0X10; //取消上升沿已经被捕获标记 if((RmtSta&0X0F)==0X00)RmtSta|=1<<6;//标记已经完成一次按键的键值信息采集 if((RmtSta&0X0F)<14)RmtSta++; else { RmtSta&=~(1<<7);//清空引导标识 RmtSta&=0XF0; //清空计数器 } } } if(TIM_GetITStatus(TIM5,TIM_IT_CC2)!=RESET) { if(RDATA)//上升沿捕获 { TIM_OC2PolarityConfig(TIM5,TIM_ICPolarity_Falling); //CC1P=1 设置为下降沿捕获 TIM_SetCounter(TIM5,0); //清空定时器值 RmtSta|=0X10; //标记上升沿已经被捕获 }else //下降沿捕获 { Dval=TIM_GetCapture2(TIM5);//读取CCR1也可以清CC1IF标志位 TIM_OC2PolarityConfig(TIM5,TIM_ICPolarity_Rising); //CC4P=0 设置为上升沿捕获 if(RmtSta&0X10) //完成一次高电平捕获 { if(RmtSta&0X80)//接收到了引导码 { if(Dval>300&&Dval<800) //560为标准值,560us { RmtRec<<=1; //左移一位. RmtRec|=0; //接收到0 }else if(Dval>1400&&Dval<1800) //1680为标准值,1680us { RmtRec<<=1; //左移一位. RmtRec|=1; //接收到1 }else if(Dval>2200&&Dval<2600) //得到按键键值增加的信息 2500为标准值2.5ms { RmtCnt++; //按键次数增加1次 RmtSta&=0XF0; //清空计时器 } }else if(Dval>4200&&Dval<4700) //4500为标准值4.5ms { RmtSta|=1<<7; //标记成功接收到了引导码 RmtCnt=0; //清除按键次数计数器 } } RmtSta&=~(1<<4); } } TIM_ClearFlag(TIM5,TIM_IT_Update|TIM_IT_CC2); } //处理红外键盘 //返回值: // 0,没有任何按键按下 //其他,按下的按键键值. u8 Remote_Scan(void) { u8 sta=0; u8 t1,t2; if(RmtSta&(1<<6))//得到一个按键的所有信息了 { t1=RmtRec>>24; //得到地址码 t2=(RmtRec>>16)&0xff; //得到地址反码 if((t1==(u8)~t2)&&t1==REMOTE_ID)//检验遥控识别码(ID)及地址 { t1=RmtRec>>8; t2=RmtRec; if(t1==(u8)~t2)sta=t1;//键值正确 } if((sta==0)||((RmtSta&0X80)==0))//按键数据错误/遥控已经没有按下了 { RmtSta&=~(1<<6);//清除接收到有效按键标识 RmtCnt=0; //清除按键次数计数器 } } return sta; } #include "led.h" #include "delay.h" #include "sys.h" #include "usart.h" #include "lcd.h" #include "remote.h" int main(void) { u8 key; u8 t=0; u8 *str=0; delay_init(); //延时函数初始? NVIC_Configuration(); uart_init(9600); //串口初始化为9600 LED_Init(); //初始化与LED连接的硬件接口 LCD_Init(); Remote_Init(); //红外接收初始化 POINT_COLOR=RED;//设置字体为红色 LCD_ShowString(60,50,200,16,16,"Mini STM32"); LCD_ShowString(60,70,200,16,16,"REMOTE TEST"); LCD_ShowString(60,90,200,16,16,"ATOM@ALIENTEK"); LCD_ShowString(60,110,200,16,16,"2014/3/12"); LCD_ShowString(60,130,200,16,16,"KEYVAL:"); LCD_ShowString(60,150,200,16,16,"KEYCNT:"); LCD_ShowString(60,170,200,16,16,"SYMBOL:"); while(1) { key=Remote_Scan(); if(key) { LCD_ShowNum(116,130,key,3,16); //显示键值 LCD_ShowNum(116,150,RmtCnt,3,16); //显示按键次数 switch(key) { case 0:str="ERROR";break; case 162:str="POWER";break; case 98:str="UP";break; case 2:str="PLAY";break; case 226:str="ALIENTEK";break; case 194:str="RIGHT";break; case 34:str="LEFT";break; case 224:str="VOL-";break; case 168:str="DOWN";break; case 144:str="VOL+";break; case 104:str="1";break; case 152:str="2";break; case 176:str="3";break; case 48:str="4";break; case 24:str="5";break; case 122:str="6";break; case 16:str="7";break; case 56:str="8";break; case 90:str="9";break; case 66:str="0";break; case 82:str="DELETE";break; } LCD_Fill(116,170,116+8*8,170+16,WHITE); //清楚之前的显示 LCD_ShowString(116,170,200,16,16,str); //显示SYMBOL }else delay_ms(10); t++; if(t==20) { t=0; LED0=!LED0; } } } 红外遥控是一种无线、非接触控制技术,具有抗干扰能力强,信息传输可靠,功耗低,成 本低,易实现等显著优点,被诸多电子设备特别是家用电器广泛采用,并越来越多的应用到计 算机系统中。 由于红外线遥控不具有像无线电遥控那样穿过障碍物去控制被控对象的能力,所以,在设 计红外线遥控器时,不必要像无线电遥控器那样,每套(发射器和接收器)要有不同的遥控频率 或编码(否则,就会隔墙控制或干扰邻居的家用电器),所以同类产品的红外线遥控器,可以有 相同的遥控频率或编码,而不会出现遥控信号“串门”的情况。这对于大批量生产以及在家用 电器上普及红外线遥控提供了极大的方面。由于红外线为不可见光,因此对环境影响很小,再 由红外光波动波长远小于无线电波的波长,所以红外线遥控不会影响其他家用电器,也不会影 响临近的无线电设备。 红外遥控的编码方式目前广泛使用的是:PWM(脉冲宽度调制)的NEC协议和Philips PPM(脉冲位置调制) 的 RC-5 协议的。ALIENTEK MiniSTM32 开发板配套的遥控器使用的是 NEC 协议,其特征如下: 1、8 位地址和 8 位指令长度; 2、地址和命令 2 次传输(确保可靠性) 3、PWM 脉冲位置调制,以发射红外载波的占空比代表“0”和“1”; 4、载波频率为 38Khz; 5、位时间为 1.125ms 或 2.25ms; NEC 码的位定义:一个脉冲对应 560us 的连续载波,一个逻辑 1 传输需要 2.25ms(560us 脉冲+1680us低电平),一个逻辑 0的传输需要1.125ms(560us脉冲+560us低电平)。而遥控 接收头在收到脉冲的时候为低电平,在没有脉冲的时候为高电平,这样,我们在接收头端收到 的信号为:逻辑1应该是560us低+1680us高,逻辑0应该是560us低+560us高。 NEC 遥控指令的数据格式为:同步码头、地址码、地址反码、控制码、控制反码。同步码 由一个9ms的低电平和一个 4.5ms的高电平组成,地址码、地址反码、控制码、控制反码均是 8 位数据格式。按照低位在前,高位在后的顺序发送。采用反码是为了增加传输的可靠性(可 用于校验)。 |
544 浏览 1 评论
1749 浏览 1 评论
1478 浏览 1 评论
MCU友好过渡MPU,米尔基于STM32MP135开发板裸机开发应用笔记
683 浏览 0 评论
自定义系统时钟频率后,用库函数和微带两种方式点亮LED灯,为什么灯的闪烁频率不一致?
1969 浏览 2 评论
GMT+8, 2024-5-9 03:10 , Processed in 0.614877 second(s), Total 69, Slave 51 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
