扫一扫,分享给好友
#include "reg52.h"
#include "absacc.h" // 0 1 2 3 4 5 6 7 8 9 熄灭 - code unsigned char tab[] = { 0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90,0xFF,0xBF}; unsigned char dspbuf[8] = {10,10,10,10,10,10,10,10}; //显示缓冲区 unsigned char dspcom = 0; unsigned char biaozhi = 0; unsigned char shi = 10,fen = 10,miao = 0; unsigned int counter = 0; unsigned int ms = 0; void display(void); // void cls_buzz(void) { XBYTE[0xA000] = 0x00; } // void cls_led(void) { XBYTE[0x8000] = 0xFF; } void Showxuehao (void) //41203129 { dspbuf[0] = 4; dspbuf[1] = 1; dspbuf[2] = 2; dspbuf[3] = 0; dspbuf[4] = 3; dspbuf[5] = 1; dspbuf[6] = 2; dspbuf[7] = 9; } void Showriqi(void) { dspbuf[0] = 1; dspbuf[1] = 5; dspbuf[2] = 11; dspbuf[3] = 1; dspbuf[4] = 2; dspbuf[5] = 11; dspbuf[6] = 1; dspbuf[7] = 0; } void Showshijian(void) { dspbuf[0] = shi/10; dspbuf[1] = shi%10; dspbuf[2] = 11; dspbuf[3] = fen/10; dspbuf[4] = fen%10; dspbuf[5] = 11; dspbuf[6] = miao/10; dspbuf[7] = miao%10; } //显示函数 void display(void) { XBYTE[0xE000] = 0xff; //消隐 XBYTE[0xC000] = (1< if(++dspcom == 8){ dspcom = 0; } } // 中断服务函数 void isr_timer_0(void) interrupt 1 //默认中断优先级 1 { unsigned char temp = 0; if(++ms == 1000){ ms = 0; counter++; } display(); //1ms执行一次 // temp = read_key(); if(temp != 0xff) { delay(); //按键消抖 temp = read_key(); if(temp != 0xff) { //返回按键处理 key_proc(temp); while(P3 != 0xff); //等待按键释放 } } } //延时函数 void delay(void) { unsigned char i, j, k; _nop_(); _nop_(); i = 9; j = 104; k = 139; do { do { while (--k); } while (--j); } while (--i); } //按键扫描函数 unsigned char read_key(void) { unsigned char temp; unsigned char key_value = 0xff; temp = P3&0x0f; switch(temp) { case 0x0e: key_value = 1; //S7 break; case 0x0d: key_value = 2; //S6 break; case 0x0b: key_value = 3; //S5 break; case 0x07: key_value = 4; //S4 break; } return key_value; } //按键处理函数 void key_proc(unsigned char key) { switch(key) { case 1: biaozhi = 1; break; case 2: biaozhi = 2; break; case 3: biaozhi = 3; break; case 4: biaozhi = 4; break; } } //主函数 void main(void) { TMOD &= 0xF0; //11.0592Hz,1ms TL0 = 0xCD; TH0 = 0xD4; TF0 = 0; TR0 = 1; ET0 = 1; EA = 1; cls_buzz(); cls_led(); //显示标志 if(biaozhi==0) Showxuehao(); if(biaozhi==1) Showriqi(); if(biaozhi==2) Showshijian(); if(biaozhi==3); // 时间 if (counter==1) { miao ++; if (miao >=60) { miao = 0; fen++; if (fen==60) { fen =0; shi++; if (shi==24) { shi=0; } } } } } compiling aa.c...AA.C(82): warning C206: 'read_key': missing function-prototypeAA.C(85): warning C206: 'delay': missing function-prototypeAA.C(90): warning C206: 'key_proc': missing function-prototypeAA.C(90): error C267: 'key_proc': requires ANSI-style prototypeAA.C(99): error C231: 'delay': redefinitionaa.c - 2 Error(s), 3 Warning(s). |
2个回答
read_key 没有事先声明过原型,前面也找不到这个实体
在调用时没有找到函数原型吧,建议在调用前先申明。
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
STM32F405驱动DS1302时钟模块,输出时间错乱该怎么排查?
2810 浏览 2 评论
stm32f405rgt6驱动DS1302ZN出现时间错乱问题
2420 浏览 1 评论
stm32用fsmc读取ad7606采集数据,数据不变,只有开发版复位才更新数据
2288 浏览 0 评论
2404 浏览 1 评论
1643 浏览 1 评论
/9
GMT+8, 2025-12-2 06:26 , Processed in 0.601504 second(s), Total 77, Slave 59 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1636
