- 名称:双色点阵
- 论坛:www.doflye.net
- 编写:shifang
- 修改:无
- 内容:使用hc595驱动双色点阵
- #include //包含头文件,一般情况不需要改动,头文件包含特殊功能寄存器的定义
- #include
- unsigned char segout[8]={0x01,0x02,0x04,0x08,0x10,0x20,0x40,0x80}; //8列
- unsigned char code tab[96]={
- 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, //空格
- 0x00,0x7E,0xFF,0xC3,0xC3,0xFF,0x7E,0x00, //字符0
- 0x00,0x00,0x43,0xFF,0xFF,0x03,0x00,0x00, //字符1
- 0x00,0x63,0xC7,0xCF,0xDB,0xF3,0x63,0x00, //字符2
- 0x00,0x42,0xDB,0xDB,0xDB,0xFF,0x66,0x00, //字符3
- 0x00,0x3E,0x46,0xFF,0xFF,0x06,0x06,0x00, //字符4
- 0x00,0xF6,0xF7,0xD3,0xD3,0xDF,0xDE,0x00, //字符5
- 0x00,0x7E,0xFF,0xDB,0xDB,0xDF,0x4E,0x00, //字符6
- 0x00,0xC0,0xC0,0xC7,0xFF,0xF8,0xC0,0x00, //字符7
- 0x00,0xFF,0xFF,0xDB,0xDB,0xFF,0xFF,0x00, //字符8
- 0x00,0x72,0xFB,0xDB,0xDB,0xFF,0x7E,0x00, //字符9
- 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00 //空格
- 硬件端口定义
- ***it LATCH = P1^0;
- ***it SRCLK= P1^1;
- ***it SER = P1^2;
- ***it LATCH_B = P2^2;
- ***it SRCLK_B= P2^1;
- ***it SER_B= P2^0;
- uS延时函数,含有输入参数 unsigned char t,无返回值
- unsigned char 是定义无符号字符变量,其值的范围是
- 0~255 这里使用晶振12M,精确延时请使用汇编,大致延时
- 长度如下 T=tx2+5 uS
- void DelayUs2x(unsigned char t)
- while(--t);
- mS延时函数,含有输入参数 unsigned char t,无返回值
- void DelayMs(unsigned char t)
- while(t--)
- //大致延时1mS
- DelayUs2x(245);
- DelayUs2x(245);
- 发送字节程序
- 带有方向参数,可以选择从高位节写入或者低位写入
- void SendByte(unsigned char dat,bit direction)
- unsigned char i,temp;
- if(direction==0)
- temp=0x80;
- else
- temp=0x01;
- for(i=0;i<8;i++)
- SRCLK=0;
- SER=dat&temp;
- if(direction==0)
- dat<<=1;
- else
- dat>>=1;
- SRCLK=1;
- 发送双字节程序
- void Send2Byte(unsigned char dat1,unsigned char dat2,bit direction)
- SendByte(dat1,direction);
- SendByte(dat2,direction);
- 595锁存程序
- void Out595(void)
- LATCH=0;
- _nop_();
- LATCH=1;
- 发送位码字节程序
- 使用另外一片单独595
- void SendSeg(unsigned char dat)
- unsigned char i;
- for(i=0;i<8;i++) //发送字节
- SRCLK_B=0;
- SER_B=dat&0x80;
- dat<<=1;
- SRCLK_B=1;
- LATCH_B=0; //锁存
- _nop_();
- LATCH_B=1;
- 主程序
- void main()
- unsigned char i,k,l;
- while(1)
- for(k=0;k<=88;k++) //所有的字符个数
- for(l=20;l>0;l--) //延时长度,改变此值可以改变流动速度
- for(i=0;i<=7;i++) //8列显示
- SendSeg(segout[i]);
- Send2Byte(~(*(tab+i+k)),0xff,0);
- Out595();
- DelayMs(1);
- Send2Byte(0xff,0xff,0);//delay(10); //防止重影
- Out595();
- SendSeg(segout[7-i]);
- Send2Byte(0xff,~(*(tab+i+k)),1); //写入字节方向改变
- Out595();
- DelayMs(1);
- Out595();
复制代码
这程序看不懂的就是它是怎么实现移动的功能的,里面我看不懂的只有这个表达式的含义,~(*(tab+i+k))以及 for(l=20;l>0;l--) 这个循环的意义,那个式子好像是指针类型,可前面又没有申明指针变量。。有谁能帮忙解答一下,小弟在此谢过了
3个回答
