扫一扫,分享给好友
28335+epm3128+rtl8019as 例程地网口程序只能发送一次数据 代码如下 附件 请指教 另外 关于中断 复用一个 组时会发生冲突吗 原先三个可以用 现在 加了一个 就用不了了 如下代码: void Initisr() { //EnableInterrupts(); EALLOW; // This is needed to write to EALLOW protected registers PieVectTable.TINT0 = &ISRTimer0; PieVectTable.XINT1 = &xint1_isr; PieVectTable.XINT2 = &xint2_isr; PieVectTable.ADCINT=&ADC_isr; // PieVectTable.SCIRXINTC= &SCICR_isr;//SCI-C接收中断重定位 // PieVectTable.SCIRXINTB= &SCIBR_isr;//SCI-B接收中断重定位 EDIS; // This is needed to disable write to EALLOW protected registers InitCpuTimers(); // For this example, only initialize the Cpu Timers ConfigCpuTimer(&CpuTimer0, 150, 10000000); //定时器时间 修改 多加了1个0 // IER |= M_INT8; // Enable CPU int8 IER |= M_INT1; // Enable CPU int1 link to TIMER0/ADC // IER |= M_INT9; // Enable CPU int9 link to scic/scib PieCtrlRegs.PIECTRL.bit.ENPIE = 1; // Enable the PIE block // PieCtrlRegs.PIEIER8.bit.INTx5 = 1; // Enable PIE Gropu 8 SCIRXINTC SCI-C // PieCtrlRegs.PIEIER9.bit.INTx3 = 1; // Enable PIE Gropu 9 SCIRXINTB SCI-B PieCtrlRegs.PIEIER1.bit.INTx1 = 1; // Enable PIE Gropu 1 XINT1 PieCtrlRegs.PIEIER1.bit.INTx2 = 1; //Enable PIE Gropu 2 XINT2 PieCtrlRegs.PIEIER1.bit.INTx4 = 1; //ADC中断 PieCtrlRegs.PIEIER1.bit.INTx3 = 1; //定时器0 /*设置XINT1*/ EALLOW; GpioCtrlRegs.GPAMUX1.bit.GPIO15 = 0; // GPIO GpioCtrlRegs.GPADIR.bit.GPIO15 = 0; // input GpioCtrlRegs.GPAQSEL1.bit.GPIO15 = 2; // XINT1 Qual using 6 samples GpioCtrlRegs.GPACTRL.bit.QUALPRD1 = 0x80; // Each sampling window is 128*SYSCLKOUT EDIS; EALLOW; GpioIntRegs.GPIOXINT1SEL.bit.GPIOSEL = 15; // Xint1 is GPIO15 EDIS; XIntruptRegs.XINT1CR.bit.POLARITY = 1; // rising edge interrupt XIntruptRegs.XINT1CR.bit.ENABLE = 1; // Enable Xint1 /*设置XINT2*/ EALLOW; GpioCtrlRegs.GPAMUX1.bit.GPIO14 = 0; // GPIO GpioCtrlRegs.GPADIR.bit.GPIO14 = 0; // input GpioCtrlRegs.GPAQSEL1.bit.GPIO14 = 2; // XINT2 Qual using 6 samples GpioCtrlRegs.GPACTRL.bit.QUALPRD1 = 0x80; // Each sampling window is 128*SYSCLKOUT EDIS; EALLOW; GpioIntRegs.GPIOXINT2SEL.bit.GPIOSEL = 14; // Xint2 is GPIO14 EDIS; XIntruptRegs.XINT2CR.bit.POLARITY = 1; // rising edge interrupt XIntruptRegs.XINT2CR.bit.ENABLE = 1; // Enable Xint2 EINT; // Enable Global interrupt INTM ERTM; // Enable Global realtime interrupt DBGM } 这个都是同一个组 后面清除时都是一起清的 之前没加定时器前是好的可以用的 中断里就改变标志位, interrupt void ISRTimer0(void) { TCPTimeout=1; EALLOW; CpuTimer0Regs.TCR.bit.TIF=1; CpuTimer0Regs.TCR.bit.TRB=1; EDIS; PieCtrlRegs.PIEACK.all = PIEACK_GROUP1; } interrupt void xint1_isr(void)//外部中断1 采用GPIO口15 帧同步 { EPwm1Regs.TBCTR=0; t2=0; EALLOW; SysCtrlRegs.PCLKCR0.bit.TBCLKSYNC = 1; // Start all the timers synced EDIS; PieCtrlRegs.PIEACK.all = PIEACK_GROUP1; } interrupt void xint2_isr(void)//外部中断2 采用GPIO口14 窑同步 { static int i; Frame=1;//窑同步信号 r=1; ava=r; for(i=0;i<3;i++) /**这里MAX由于协议的问题 改为三个*/ { MAX=0; } PieCtrlRegs.PIEACK.all = PIEACK_GROUP1; } interrupt void ADC_isr(void) { AD0[t2]=0; AD0[t2++]=AdcRegs.ADCRESULT0>>4; if (t2==2500) { EALLOW; SysCtrlRegs.PCLKCR0.bit.TBCLKSYNC = 0; // Stop all the timers synced EDIS; ADflag=1;//采集数据结束标志 t2=0; // GpioDataRegs.GPATOGGLE.bit.GPIO1 = 1; // Toggle GPIO1 once LED2亮灭亮灭 } AdcRegs.ADCST.bit.INT_SEQ1_CLR=1;//清除中断标志位 AdcRegs.ADCTRL2.bit.RST_SEQ1=1;//复位排序器 PieCtrlRegs.PIEACK.all=PIEACK_GROUP1;//清除应答标志位 } |
相关推荐 |
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
TMS320C6748 板卡设计中是否一定需要有SDRAM或者DDR
2408 浏览 0 评论
1441 浏览 0 评论
4087 浏览 1 评论
【六岳微LY-F335开发板试用体验】epwm启动ADC并在OLED上显示结果
4958 浏览 0 评论
【六岳微LY-F335开发板试用体验】软件开发环境及调试下载
4977 浏览 0 评论
/9
GMT+8, 2025-12-11 23:45 , Processed in 0.573041 second(s), Total 71, Slave 54 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
7012
