扫一扫,分享给好友
每个模块的程序都是没有问题的 但是放在一起就打开时弹出上图对话框,求指点,不胜感激
楼主问题解决了不?我也遇上了同样的问题,困惑好几天了,
Reported In
Software LabVIEW Full Issue Details My LabVIEW program has been crashing with errors in image.cpp or drawmgr.cpp I have noticed in Windows Task Manager that the number of GDI Objects used by LabVIEW approaches 10,000 The error in inconsistent in when it occurs This happens during edit-time, run-time, and, startup Solution Try reducing the amount front panel objects This will help reduce the total amount of GDI objects used by LabVIEW Change the limit of GDI object handles A method for increasing the number of GDI objects in Windows (after 2000) is described in MSDN:GDI Objects (Windows) Install the latest video driver from the manufacturer This will generally fix the memory leaks that lead to GDI overflow Change palette loading setting. In any LabVIEW window go to the top tool bar and navigate to Tools»Options... This should open the options window. Navigate to Controls/Functions Palette At the top there should be options for loading, select Load palettes when needed to try mitigate crashing Remove unnecessary libraries from your LabVIEW uses a GDI object for each palette image, so large numbers of palette VIs will contribute to this crash Call National Instruments support |
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
211 浏览 0 评论
请教大神,在labview里面对实时扫描资源中的C系列模块NI9234进行配置发生非预期错误
1709 浏览 0 评论
1585 浏览 0 评论
LABVIEW 2023 Q1调用python后一直报错1671
1960 浏览 2 评论
5207 浏览 3 评论
/9
GMT+8, 2025-12-2 04:35 , Processed in 0.832191 second(s), Total 86, Slave 67 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
9251
