学习开发板,最重要的目的就是控制,其中最普遍的就是控制电机的转速问题
关键程序: 1. static void TIM3_GPIO_Config(void) { GPIO_InitTypeDef GPIO_InitStructure; /* 设置TIM3CLK 为 72MHZ */ RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM3, ENABLE); /* GPIOA and GPIOB clock enable */ RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA | RCC_APB2Periph_GPIOB, ENABLE); /*GPIOA Configuration: TIM3 channel 1 and 2 as alternate function push-pull */ GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6 | GPIO_Pin_7; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; // 复用推挽输出 GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_Init(GPIOA, &GPIO_InitStructure); /*GPIOB Configuration: TIM3 channel 3 and 4 as alternate function push-pull */ GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0 | GPIO_Pin_1; GPIO_Init(GPIOB, &GPIO_InitStructure); } 2. static void TIM3_Mode_Config(void) { TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure; TIM_OCInitTypeDef TIM_OCInitStructure; /* PWM信号电平跳变值 */ u16 CCR1_Val = 500; u16 CCR2_Val = 375; u16 CCR3_Val = 250; u16 CCR4_Val = 125; /* ----------------------------------------------------------------------- TIM3 Channel1 duty cycle = (TIM3_CCR1/ TIM3_ARR+1)* 100% = 50% TIM3 Channel2 duty cycle = (TIM3_CCR2/ TIM3_ARR+1)* 100% = 37.5% TIM3 Channel3 duty cycle = (TIM3_CCR3/ TIM3_ARR+1)* 100% = 25% TIM3 Channel4 duty cycle = (TIM3_CCR4/ TIM3_ARR+1)* 100% = 12.5% ----------------------------------------------------------------------- */ /* Time base configuration */ TIM_TimeBaseStructure.TIM_Period = 999; //当定时器从0计数到999,即为1000次,为一个定时周期 TIM_TimeBaseStructure.TIM_Prescaler = 0; //设置预分频:不预分频,即为72MHz TIM_TimeBaseStructure.TIM_ClockDivision = TIM_CKD_DIV1 ; //设置时钟分频系数:不分频(这里用不到) TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up; //向上计数模式 TIM_TimeBaseInit(TIM3, &TIM_TimeBaseStructure); /* PWM1 Mode configuration: Channel1 */ TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM1; //配置为PWM模式1 TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable; TIM_OCInitStructure.TIM_Pulse = CCR1_Val; //设置跳变值,当计数器计数到这个值时,电平发生跳变 TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High; //当定时器计数值小于CCR1_Val时为高电平 TIM_OC1Init(TIM3, &TIM_OCInitStructure); //使能通道1 TIM_OC1PreloadConfig(TIM3, TIM_OCPreload_Enable); /* PWM1 Mode configuration: Channel2 */ TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable; TIM_OCInitStructure.TIM_Pulse = CCR2_Val; //设置通道2的电平跳变值,输出另外一个占空比的PWM TIM_OC2Init(TIM3, &TIM_OCInitStructure); //使能通道2 TIM_OC2PreloadConfig(TIM3, TIM_OCPreload_Enable); /* PWM1 Mode configuration: Channel3 */ TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable; TIM_OCInitStructure.TIM_Pulse = CCR3_Val; //设置通道3的电平跳变值,输出另外一个占空比的PWM TIM_OC3Init(TIM3, &TIM_OCInitStructure); //使能通道3 TIM_OC3PreloadConfig(TIM3, TIM_OCPreload_Enable); /* PWM1 Mode configuration: Channel4 */ TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable; TIM_OCInitStructure.TIM_Pulse = CCR4_Val; //设置通道4的电平跳变值,输出另外一个占空比的PWM TIM_OC4Init(TIM3, &TIM_OCInitStructure); //使能通道4 TIM_OC4PreloadConfig(TIM3, TIM_OCPreload_Enable); TIM_ARRPreloadConfig(TIM3, ENABLE); // 使能TIM3重载寄存器ARR /* TIM3 enable counter */ TIM_Cmd(TIM3, ENABLE); //使能定时器3 } 每行都有注释,应该可以看懂了。 |
是的,可以通过改变 u16 CCR1_Val = 500; u16 CCR2_Val = 375; u16 CCR3_Val = 250; u16 CCR4_Val = 125; 值的大小来根据自己的需求相应的改变占空比,进而实现速度的控制。 |
不仅仅局限于在中断里改变,在主函数里或者其他子函数中也是可以的。 |
谢谢分享 谢谢分享 谢
谢谢分享 谢谢分享 谢 谢谢分享 谢谢分享 分 谢谢分享 谢谢分享 享 谢谢分享 谢谢分享 谢 谢谢分享 |
谢谢分享谢谢分享谢谢分享
谢谢分享谢谢分享 谢谢分享 谢谢分享谢谢分享 谢谢分享 谢谢分享 谢谢分享谢谢分享谢谢分享 谢谢分享 谢谢分享 谢 谢 谢谢分享 谢谢分享 谢 谢 谢谢分享 谢谢分享 分 分 谢谢分享 谢谢分享 享 享 谢谢分享 谢谢分享 谢 谢 谢谢分享 谢谢分享 谢 谢 谢 谢谢分享 谢谢分享 分 分 谢谢 谢谢分享 谢谢分享 享 享 谢谢分 谢谢分享 谢谢分享 谢 谢 谢谢分 谢谢分享 谢 谢 谢谢分谢谢分享 谢 谢 谢谢谢谢 分 分 谢谢 享 享 |
不谢不谢 不谢不谢 不谢不谢 不谢不谢 不谢不谢 不谢不谢 不谢不谢 不谢不谢 不谢不谢 不谢不谢 |
xue xi xue xi,gan xie fen xiang
STM32F405驱动DS1302时钟模块,输出时间错乱该怎么排查?
2797 浏览 2 评论
stm32f405rgt6驱动DS1302ZN出现时间错乱问题
2403 浏览 1 评论
stm32用fsmc读取ad7606采集数据,数据不变,只有开发版复位才更新数据
2276 浏览 0 评论
2388 浏览 1 评论
1637 浏览 1 评论
/9
GMT+8, 2025-12-2 02:30 , Processed in 1.005680 second(s), Total 103, Slave 84 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
